查看: 1745|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite 2023 Q1 Win11 64bitEng 嵌入式控制和监控软件套件2023Q1英文版ECMSS23.0-64位
     楼主| 发表于 2023-3-17 11:00:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Embedded Control and Monitoring Software Suite是一组用于工业设备或设计智能机器的软件和工具集合。
    Embedded Control and Monitoring Software Suite包含了LabVIEW以及推荐用于开发嵌入式控制和监测系统的附加工具。该套件可帮助您在设计周期的每个阶段,从建模和仿真到原型设计、验证和部署,都能通过一个高度优化的工具链快速响应系统不断变化的需求。
    套件包含:
    LabVIEW专业版
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW MathScript模块
    LabVIEW高级信号处理工具包
    LabVIEW数字滤波器设计工具包
    视觉采集软件
    视觉开发模块
    LabWindows/CVI执行评测工具包
    LabWindows/CVI Real-Time模块
    LabWindows/CVI SQL工具包
    LabWindows/CVI完整版
    Measurement Studio企业版
    发布日期:2023/2/7
    包含的版本:2023 Q1专业版,版本号23.0.0
    语言:英文English
    文件大小: 36945704960 字节 (34.41 GB)
    修改日期: 2023-02-17 21:47
    MD5: ba7f93459afaddc100625a1efb2a5c83
    SHA1: 8f6413b2b3e15d21411cb8e7f79ff1afa17d7753
    SHA256: b9987a97b263f80654f04688def54396913ee213ef464c8bc5d2c6f8f61bdd58
    CRC32: 768e6349
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    ECMSS2023Q1x64Eng.txt (692 Bytes, 下载次数: 0, 售价: 40 圆)
    Embedded Control and Monitoring Software Suite 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for Embedded Control and Monitoring Software Suite 2023 Q1.
    • Embedded Control and Monitoring Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Embedded Control and Monitoring Software Suite
    Embedded Control and Monitoring Software Suite 2023 Q1 supports the following operating systems:
    The following products are included in the Embedded Control and Monitoring Software Suite installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    LabVIEW2023 Q132-bit and 64-bit
    Note: This product no longer supports LabVIEW NXG. Refer to LabVIEW NXG on ni.com for more information about LabVIEW NXG Life-Cycle Dates and driver version support.
    Add-ons
    Version
    Bitness
    FPGA Interface C API202032-bit and 64-bit
    JKI VI Package Manager2023 Q132-bit and 64-bit
    LabVIEW FPGA Compilation Tool for Vivado 2021.12022 Q364-bit
    LabVIEW FPGA Compile Farm Toolkit2023 Q132-bit and 64-bit
    LabVIEW FPGA Module2023 Q132-bit and 64-bit
    LabVIEW Real-Time Module2023 Q132-bit and 64-bit
    Vision Development Module2023 Q132-bit and 64-bit
    Note: The LabVIEW Professional Development System installs the LabVIEW Advanced Signal Processing Toolkit, LabVIEW Desktop Execution Trace Toolkit, LabVIEW Digital Filter Design Toolkit, LabVIEW Unit Test Framework Toolkit, LabVIEW VI Analyzer Toolkit, LabVIEW Database Connectivity Toolkit, and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory.
    Drivers
    Version
    Bitness
    FlexRIO with Integrated I/O2023 Q132-bit and 64-bit
    FlexRIO with Modular I/O2023 Q132-bit and 64-bit
    NI CompactRIO2023 Q132-bit and 64-bit
    NI-DAQmx2023 Q132-bit and 64-bit
    NI-Industrial Communications for EtherNet/IP2022 Q332-bit and 64-bit
    NI-Serial21.532-bit and 64-bit
    NI-Sync2023 Q132-bit and 64-bit
    NI-XNET2023 Q132-bit and 64-bit
    R-Series2023 Q132-bit and 64-bit
    Note: Some drivers included with previous versions of Embedded Control and Monitoring Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
    If you are using the Embedded Control and Monitoring Software Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The Embedded Control and Monitoring Software Suite 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Embedded Control and Monitoring Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Embedded Control and Monitoring Software Suite. For more information on Embedded Control and Monitoring Software Suite activation, refer to Activating a Product.
    Refer to the readme of each product for where to find examples.
    Embedded Control and Monitoring Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-8 08:21
