查看: 3321|回复: 0
[DataPlugin] FlexLogger插件开发套件1.5 Win11 64bitEng NI Flexlogger Plugin Development Kit 23.0.0
    4 小时前
  • 签到天数: 3810 天
     楼主| 发表于 2023-3-19 16:03:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    FlexLogger插件开发套件扩展了FlexLogger软件,以从第三方硬件设备获取数据并控制第三方硬件设备。
    FlexLogger插件开发套件是一个附加软件工具,用于开发LabVIEW插件来实现与第三方仪器的通信。FlexLogger软件可自动生成所需的用户界面来配置插件测量。如果要编译这些插件,使其能够与FlexLogger软件一起使用,需要先安装LabVIEW和LabVIEW应用程序生成器模块。
    发布日期:2023/1/19
    包含的版本:1.5完整版,版本号23.0.0
    受支持的操作系统
    文件大小: 170557440 字节 (162.66 MB)
    修改日期: 2023-01-20 09:50
    MD5: a27622bfbb8240c0693179a3e28c7912
    SHA1: 393e4b0745f4a730b4ac66ac914031157f5f1984
    SHA256: 3c4e025339c8aa42f3cb57dc3f317bf91403050518ae925e49ea7cc3731cd48d
    CRC32: ab913b59
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    FlexLogger插件开发套件1.5.txt (616 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexLogger Plug-In Development Kit 1.5 Readme
    January 2023
    This file contains installation instructions and compatibility information for FlexLogger Plug-In Development Kit 1.5.
    • FlexLogger Plug-In Development Kit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • FlexLogger Plug-In Development Kit Documentation: New features, behavior changes, and other documentation
    The FlexLogger IO Plug-in Development Kit consists of the following components:
    Component
    Where to Find
    FlexLogger Plug-in Development Kit documentation for information on installation, development, debugging, and importing FlexLogger I/O plug-ins.:\Program Files\National Instruments\LabVIEW 2022\resource\FlexLogger\SDK\FlexLogger Plug-in Development Kit Manual
    LabVIEW FlexLogger IO Plug-in templates for a basic projects to either consume or produce data from or to FlexLogger.In LabVIEW, create a project and select FlexLogger IO Plug-in from the Create Project window.
    LabVIEW APIs for your plug-inIn LabVIEW on the Functions»FlexLogger palette.
    Examples of LabVIEW-based FlexLogger IO plug-ins.:\Program Files\National Instruments\LabVIEW 2022\examples\FlexLogger
    Plugin Environment Simulator:\Program Files\National Instruments\LabVIEW 2022\resource\FlexLogger\SDK\PluginEnvironmentSimulator
    Refer to the FlexLogger 2023 Q1 Readme and the LabVIEW 2022 Readme for system requirements.
    FlexLogger Plug-In Development Kit 1.5 supports the following operating systems:
    Note  FlexLogger Plug-In Development Kit no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    FlexLogger Plug-In Development Kit 1.5 supports the following application software versions, including service packs.
    Versions Supported by FlexLogger Plug-in Development Kit 1.5
    LabVIEW2022 (64-bit)
    (Optional) FlexLogger2023 Q1 or higher
    Download the FlexLogger Plug-In Development Kit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Install LabVIEW 2022 (64-bit).
    • Install FlexLogger 2023 Q1.
    • Install the FlexLogger Plug-in Development Kit.
    • Added support for LabVIEW 2022
    Refer to the FlexLogger Plug-in Development Kit documentation, accessible from :\Program Files\National Instruments\LabVIEW 2022\resource\FlexLogger\SDK\FlexLogger Plug-in Development Kit Manual or on ni.com/docs.
    For more information about using FlexLogger, refer to the FlexLogger documentation, accessible from Help»Online manual in FlexLogger or on ni.com/docs.
    For more information about using LabVIEW, refer to the LabVIEW documentation, accessible from Help»LabVIEW Help in LabVIEW or on ni.com/docs.
    Navigate to :\Program Files\National Instruments\LabVIEW 2021\examples\FlexLogger to find LabVIEW examples for the FlexLogger Plug-in Development Kit.
    FlexLogger Plug-In Development Kit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-2-27 13:32
