查看: 1538|回复: 0
[NI驱动程序] NI Linux Device Drivers 2023 Q1 Online Linux64Eng Linux设备驱动程序2023Q1DeviceDrivers在线安装
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2023-3-20 11:03:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Linux Device Drivers 2023 Q1 Online Linux64Eng Linux设备驱动程序NILinux2023Q1DeviceDrivers在线安装
    NI Linux仪器驱动程序
    NI Linux Device Drivers软件为采用Linux操作系统的NI和第三方硬件提供了所需的NI仪器驱动。
    NI Linux Device Drivers软件为各种NI测试和测量硬件提供了Linux桌面支持。该软件提供了一个存储库附加工具,下载该附加工具后,就可以指示Linux软件包管理器安装NI驱动软件包,如NI-DAQmx、NI-VISA、NI-488.2和NI-Sync。NI Linux Device Drivers软件也支持LabVIEW。
    发布日期:2023/2/9
    包含的版本:2023 Q1完整版
    RedHat
    SUSE
    Ubuntu
    程序位数:64位
    文件大小: 430477 字节 (420.39 KB)
    修改日期: 2023-02-07 09:52
    MD5: 2bda709c961ae4be9e14c37c4095ab70
    SHA1: f24d94bccb3a0ee56dab9d18112f26590753986f
    SHA256: 2079c1bde93a90c1ecf6e402d5910345884e91c15028558556de13ff2400f5d8
    CRC32: 0b808527
    百度网盘和NI官方下载地址(在线安装,需要连网支持,且能正常连接NI服务器):
    请注册登陆机器视觉论坛账号,购买附件查看下载地址
    Linux设备驱动程序2023Q1.txt (539 Bytes, 下载次数: 0, 售价: 5 圆)
    NI Linux Device Drivers 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for NI Linux Device Drivers 2023 Q1.
    • NI Linux Device Drivers Release Notes: for known issues, bugs fixed since the last release, and other release details.
    Package Repositories
    Supported Drivers
    NI Linux Device Drivers software provides Linux Desktop support for a variety of NI test and measurement hardware. It offers repository registration packages for each supported Linux distribution. Once the appropriate driver software repository is registered for the system, use the Linux distribution's native package manager to install NI driver software packages.
    • Red Hat Enterprise Linux 9 support for NI-DMM, NI-FGEN, FlexRIO, NI-SCOPE, NI-SWITCH, and NI-Sync
    • openSUSE 15.3 and openSUSE 15.4 support for NI-DMM, NI-FGEN, FlexRIO, NI-SCOPE, and NI-SWITCH
    • Ubuntu 22.04 support for NI-DCPower, NI-DMM, NI-FGEN, FlexRIO, NI-SCOPE, and NI-SWITCH
    • LV Host Interface API for FlexRIO, Rseries, cRIO, and RIO
    Refer to Download and Install NI Driver Software on Linux Desktop.
    NI Linux Device Drivers are installed from one of the following two options.
    • Static repository registration packages are labeled with a date-based suffix, such as ni-rhel8-drivers-2023Q1. Software from this repository is not intended to change, and it is updated only for critical patches. Use this kind of repository when you need to reproduce a specific software stack.
    • Stream repository registration packages are labeled with a -stream suffix, for example: ni-rhel8-drivers-stream. Software in this repository is updated regularly with the latest versions of each driver package as it is released. Running an update/upgrade command with a package manager will update installed NI packages to their latest released version for systems that have registered a stream repository. This kind of repository is the simplest way to keep NI driver software up to date.
    Firstlook is present in some repository registration package names, for example ni-ubuntu2204firstlook-drivers-2023Q1.deb. Firstlook identifies a newer repository that is now in an introductory roll-out phase as NI steadily adds and validates individual drivers over the course of multiple releases. Although not yet comprehensive, support for these repositories is progressing to the same level to that of other distributions.
    If you plan to upgrade to a new distribution and you see "firstlook" in its NI repository registration package name, refer to the Supported Drivers table to ensure that the NI products you need support the new distribution.
    Supported Drivers
    For a list of supported hardware, refer to the NI Hardware and Operating System Compatibility page. For details about a specific driver's system requirements, limitations, and so on, refer to the readme for the individual driver (linked below).
    The following table shows driver support for several Linux distributions. Use your Linux distribution's package manager to install the specified add-on files for an NI driver.
    NI Driver Support for Linux Distributions
    Driver
    Packages
    RHEL18
    RHEL1 9
    openSUSE2 15.3
    openSUSE2 15.4
    Ubuntu3 20.04
    Ubuntu3 22.04
    Driver
    Release Notes
    Tested Kernel
    4.18
    5.14
    5.3
    5.14
    5.13
    5.13
    NI-488.2
    ni-488.2
    libni4882-devel
    ni-488.2-iotrace-support
    OOOOOONI-488.2 2022 Q4
    Automotive Diagnostic
    Command Set Toolkit
    ni-adcs
    ni-adcs-labview-20xy-support
    libnidiagcs-devel
    OOOOOOAutomotive Diagnostic Command Set Toolkit 2022 Q4
    NI-DAQmx
    ni-daqmx
    ni-daqmx-labview-20xy-support
    ni-daqmx-labview-support
    libnidaqmx-devel
    OOOOOONI-DAQmx 2023 Q1
    NI-DCPower
    ni-dcpower
    ni-dcpower-daqmx
    ni-dcpower-labview-20xy-support
    ni-dcpower-labview-support
    ni-dcpower-devel
    OOOOOONI-DCPower 2023 Q1
    NI-DMM
    ni-dmm
    ni-dmm-daqmx
    ni-dmm-labview-20xy-support
    ni-dmm-labview-support
    ni-dmm-devel
    OOOOOONI-DMM 2023 Q1
    ECU Measurement and
    Calibration Toolkit
    ni-ecumc
    ni-ecumc-labview-20xy-support
    libniemcc-devel
    OOOOOOECU Measurement and Calibration Toolkit 2022 Q4
    NI-FGEN
    ni-fgen
    ni-fgen-daqmx
    ni-fgen-devel
    ni-fgen-labview-support
    ni-fgen-labview-20xy-support
    OOOOOONI-FGEN 2023 Q1
    FlexRIO
    ni-flexrio
    ni-flexrio-795x
    ni-flexrio-796x
    ni-flexrio-797x
    libniflexrioapi-devel
    ni-flexrio-modulario-libs-devel
    OOOOOOFlexRIO 2023 Q1
    Hardware Configuration
    Utility
    ni-hwcfg-utilityOOOOOOHardware Configuration Utility 2022 Q4
    PXI Platform
    Services
    ni-pxiplatformservices
    ni-pxiplatformservices-labview-20xy-support
    ni-pxiplatformservices-labview-support
    ni-pxiplatformservices-devel
    OOOOOOPXI Platform Services 2023 Q1
    NI-RIO5
    ni-fpga-interface
    ni-rio-mxie
    OOOOOONI-RIO 2023 Q1
    NI R Series
    ni-rseriesOOOOOONI R Series 2023 Q1
    NI-RFSA
    ni-rfsa
    ni-rfsa-daqmx
    ni-rfsa-labview-20xy-support
    ni-rfsa-devel
    OOOOOONI-RFSA 2023 Q1
    NI-RFSG
    ni-rfsg
    ni-rfsg-daqmx
    ni-rfsg-labview-20xy-support
    ni-rfsg-devel
    OOOOOONI-RFSG 2023 Q1
    NI-SCOPE
    ni-scope
    ni-scope-daqmx
    ni-scope-labview-20xy-support
    ni-scope-labview-support
    ni-scope-devel
    OOOOOONI-SCOPE 2023 Q1
    NI-Serial
    ni-serialOOOOOONI-Serial 21.5
    NI-SWITCH
    ni-switch
    ni-switch-daqmx
    ni-switch-daqmx-config
    ni-switch-labview-support4
    ni-switch-labview-20xy-examples4
    ni-switch-devel
    OOOOOONI-SWITCH 2023 Q1
    NI-Sync
    ni-sync
    ni-sync-devel
    ni-sync-labview-20xy-support
    ni-sync-labview-support
    OOOOOONI-Sync 2023 Q1
    System
    Configuration
    ni-syscfg-runtime
    ni-syscfg-labview-20xy-support
    ni-syscfg-labview-support
    ni-iotrace
    ni-syscfg-devel
    OOOOOOSystem Configuration 2022 Q3
    NI USRP-RIO
    ni-usrp-rioOOOOOODriver Info
    NI-VISA
    ni-visa
    ni-visa-labview-20xy-support
    ni-visa-labview-support
    ni-visa-devel
    OOOOOONI-VISA 2022 Q3
    NI-XNET
    ni-xnet
    ni-xnet-labview-20xy-support
    libnixnet-devel
    OOOOOONI-XNET 2023 Q1
    1 Red Hat Enterprise Linux
    2 openSUSE Leap
    3 Ubuntu LTS
    4 LabVIEW support is not available on Ubuntu distributions for current versions of NI-SWITCH
    5 Enables connections via the FPGA Interface API to remote RIO devices such as CompactRIO, Single-Board RIO, and Ethernet RIO
    For additional information about supported operating systems, refer to the NI Operating System Support Roadmap.
    GMT+8, 2025-12-5 14:01
