查看: 1383|回复: 0
[NI驱动程序] NI FlexRIO 2023 Q1/Patch1 Driver Win11 32/64bitEng NI-FlexRIO设备驱动程序23.0
    昨天 08:12
  • 签到天数: 3646 天
    连续签到: 8 天
     楼主| 发表于 2023-3-20 17:24:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    FlexRIO
    FlexRIO驱动程序为使用NI FlexRIO设备的客户提供支持。
    FlexRIO驱动是用于支持FlexRIO设备的NI仪器驱动。该驱动为基于集成I/O和模块化I/O的FlexRIO设备提供硬件支持,包括用于FlexRIO的PXI FPGA模块以及FlexRIO的各种适配器模块。对于基于集成I/O的FlexRIO设备,FlexRIO驱动还提供用于数据流传输的API以及NI-TClk同步支持。
    NI FlexRIO 2023 Q1/Patch1(NI官方提供了2023及2023 Patch1两个版本,但是看其下载地址和校验和都是一样的,所以是指一个版本)。
    发布日期:2023/2/3
    包含的版本:23.0.0完整版,版本号23.0.0
    程序位数:32/64位
    文件大小: 10103822336 字节 (9.41 GB)
    修改日期: 2023-02-08 09:53
    MD5: 4b38a0414ecc1ac418ac2b78c2d1dd98
    SHA1: 2b5994aa7f1343200cd347d1d5b00d10f5252ea7
    SHA256: 592842e8705ba578eb935ea33513affbfebcd19af5cef01a4466bd066c046c41
    CRC32: 887fed4f
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    FlexRIO2023Q1.txt (562 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexRIO 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for FlexRIO 2023 Q1.
    • FlexRIO Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • FlexRIO Documentation: New features, behavior changes, and other documentation
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2023 Q1.
    FlexRIO 2023 Q1 supports the following operating systems:
    Note: FlexRIO 2023 Q1 does not support Windows Server non-R2 editions.
    FlexRIO 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by FlexRIO 2023 Q1
    LabVIEW2020 or later
    LabVIEW Real-Time2020 or later
    LabVIEW FPGA2020 or later
    Installation InstructionsDownload the FlexRIO 2023 Q1 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Notes:
    The tables below list the hardware supported by FlexRIO 2023 Q1 and specify LabVIEW support for that hardware.
    FlexRIO with Integrated I/O
    LabVIEW Version Requirements
    FlexRIO FPD-Link Interface Modules
    PXIe-1486LabVIEW 2020 or later
    FlexRIO GMSL Interface Modules
    PXIe-1487LabVIEW 2020 or later
    FlexRIO High-Speed Serial Modules
    PXIe-6594LabVIEW 2021 or later
    PXIe-6593LabVIEW 2020 or later
    FlexRIO Coprocessor Modules
    PXIe-7911None
    PXIe-7912None
    PXIe-7915None
    FlexRIO Digitizer Modules
    PXIe-5763LabVIEW 2020 or later
    PXIe-5764LabVIEW 2020 or later
    PXIe-5775LabVIEW 2020 or later
    PXIe-5774LabVIEW 2020 or later
    PCIe-5774LabVIEW 2020 or later
    PCIe-5763LabVIEW 2020 or later
    PCIe-5764LabVIEW 2020 or later
    PCIe-5775LabVIEW 2020 or later
    FlexRIO Signal Generator Modules
    PXIe-5745LabVIEW 2020 or later
    FlexRIO IF Transceiver Modules
    PXIe-5785LabVIEW 2020 or later
    PCIe-5785LabVIEW 2020 or later
    FlexRIO Digital Modules
    PXIe-6569LabVIEW 2021 or later
    FlexRIO with Modular I/O
    LabVIEW Version Requisites
    Controllers for FlexRIO
    NI-7931RNone
    NI-7932RNone
    NI-7935RNone
    FlexRIO FPGA Modules
    PXI-7951RNone
    PXI-7952RNone
    PXI-7953RNone
    PXI-7954RNone
    PXIe-7961RNone
    PXIe-7962RNone
    PXIe-7965RNone
    PXIe-7966RNone
    PXIe-7971RNone
    PXIe-7972RNone
    PXIe-7975RNone
    PXIe-7976RNone
    FlexRIO Adapter Modules
    NI 5731LabVIEW 2021 or later
    NI 5732LabVIEW 2021 or later
    NI 5733LabVIEW 2021 or later
    NI 5734LabVIEW 2021 or later
    NI 5741LabVIEW 2021 or later
    NI 5742LabVIEW 2021 or later
    NI 5751/5751BLabVIEW 2021 or later
    NI 5752/5752BLabVIEW 2021 or later
    NI 5753LabVIEW 2021 or later
    NI 5761LabVIEW 2021 or later
    NI 5762LabVIEW 2021 or later
    NI 5771LabVIEW 2021 or later
    NI 5772LabVIEW 2021 or later
    NI 5781LabVIEW 2021 or later
    NI 5782LabVIEW 2021 or later
    NI 5783LabVIEW 2021 or later
    NI 5791LabVIEW 2021 or later
    NI 5792LabVIEW 2021 or later
    NI 5793LabVIEW 2021 or later
    NI 6581/6581BLabVIEW 2021 or later
    NI 6583LabVIEW 2021 or later
    NI 6584LabVIEW 2021 or later
    NI 6585/6585BLabVIEW 2021 or later
    NI 6587LabVIEW 2021 or later
    NI 6589LabVIEW 2021 or later
    Refer to the FlexRIO documentation, accessible from the FlexRIO Help, for information about the FlexRIO.
    In LabVIEW, select Help»Find Examples to launch the NI Example Finder. Use one of the following methods to locate FlexRIO examples:
    • Click the Browse tab, select the Task radio button, then open Hardware Input and Output»FlexRIO.
    • Click the Search tab to search all installed examples by keyword. For example, search "FlexRIO" to locate all FlexRIO examples.
    Note:To access FlexRIO with Integrated I/O examples, open Hardware Input and Output»FlexRIO»Integrated IO»Getting Started»Getting Started FlexRIO Integrated IO.vi to view the FlexRIO with Integrated IO Project Creator.
    Note: FlexRIO examples are classified by keyword, so you can also use the Search tab to search for a particular device or measurement function.
    To access more FlexRIO examples and the join the FlexRIO community, visit ni.com/examples and search by category for "FlexRIO."
    FlexRIO no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-9-9 03:21
