查看: 1541|回复: 0
[NI软件产品] NI InstrumentStudio 2023 Q1 Win11 64bitEng NI仪器套件2023Q1 InstrumentStudio23.0.0
    9 小时前
     楼主| 发表于 2023-3-21 12:20:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    InstrumentStudio
    InstrumentStudio是一款免费的应用程序软件,提供了集成的交互式PXI测量方法。
    InstrumentStudio可帮助您统一显示数据,将仪器配置导出到代码,并监测和调试您的自动测试系统。 您可以使用大型高分辨率显示器在统一显示界面上查看数据,然后捕获多仪器屏幕截图和测量结果。 您还可保存项目级配置,以便针对特定的待测设备更轻松地重复进行测试,或将仪器配置导出到编程环境,以简化代码并保证测量相关性。您还可以同时使用代码和InstrumentStudio来监测和调试正在运行的测试应用程序。
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版,版本号23.0.0
    文件大小: 715026432 字节 (681.90 MB)
    修改日期: 2023-02-04 09:51
    MD5: c17626b5d86e70be7dbc755ca1f87300
    SHA1: 62e5a6cf71f3c2884158bdf139b074a44384d447
    SHA256: 4dabe6672e841690fb64d78269032f9a6c1cf3a1eedc71a11c7e680907f975b0
    CRC32: a34c679c
    请注册登录机器视觉论坛,购买附件后查看下载地址
    InstrumentStudio2023Q1.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    InstrumentStudio 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for InstrumentStudio 2023 Q1.
    • InstrumentStudio Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    InstrumentStudio 2023 Q1 has the following requirements:
    • 4 GB RAM
    • 10 GB disk space
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    InstrumentStudio 2023 Q1 supports the following operating systems:
    InstrumentStudio 2023 Q1 supports the creation of soft front panels with the following device drivers:
    Device Driver
    Minimum Version Supported by InstrumentStudio 2023 Q1
    NI-SCOPE20.7
    NI-FGEN19.1
    NI-DMM18.1
    NI-DCPOWER2023 Q1
    NI-RFSG2022 Q4
    RFmx2023 Q1
    Download the InstrumentStudio installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Added SMU measurement auto-range support for PXIe-4190 and PXIe-4190 (500 kHz).
    • Added LCR Meter impedance measurement auto-range support in sweep mode.
    • Added remote RF Signal Analyzer panel viewing as a preview feature.
    Refer to the online documentation for information about the hardware supported in InstrumentStudio.
    Refer to the InstrumentStudio documentation, accessible from ni.com/docs, for information about InstrumentStudio.
    InstrumentStudio no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-8 19:07
