查看: 1920|回复: 0
[NI软件产品] NI RFmx CDMA2000 2023 Q1 Full/Runtime Win11 64bitENG RFmxCDMA2K完整版运行版23.0下载
    9 小时前
     楼主| 发表于 2023-3-22 09:43:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版/运行版,版本号23.0.0
    64位完整版校验和:
    文件大小: 659634176 字节 (629.08 MB)
    修改日期: 2023-02-04 09:51
    MD5: bff26ff1b223dd5e53784f04f7620a03
    SHA1: 93334522ca2fd35877292330dfd209550e0e72ea
    SHA256: 51f1d7bd41dd245eda0a3e8394e993671cff72b1845b2e11828bc80aa101dda5
    CRC32: 2bc45aae
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA20002023Q1.txt (551 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 489533440 字节 (466.86 MB)
    MD5: e41e2a9ff594aeeb4ee6bcd3eb54871f
    SHA1: ab4753bab9ba869ae79d70da26c0732e95ab760a
    SHA256: 2a158e1b4bcd9f8881f116ffd099f87006ccff6df7a131506bae44879776a049
    CRC32: 1043d400
    RFmx CDMA20002023Q1RTE.txt (574 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx CDMA2k 2023 Q1 Readme
    January 2023
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2022 Q3 includes the following new feature:
    RFmx CDMA2k 2023 Q1 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q1 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Versions Supported by RFmx CDMA2k (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2025-12-8 19:08
