查看: 1440|回复: 0
[NI软件产品] NI RFmx SpecAn/Power Amplifier/Phase Noise/Niose Figure 2023 Q1 Win11 64bitENG RFmx频谱分析仪/功率放大器/相位噪声/噪声系数23.0
    9 小时前
     楼主| 发表于 2023-3-22 10:27:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版/运行版,版本号23.0.0
    64位完整版校验和:
    文件大小: 1111693312 字节 (1.04 GB)
    修改日期: 2023-02-04 09:52
    MD5: 03e13f1020c2fe8607089545c3011b71
    SHA1: 8258706560e9d893b1b43b0170e6556c58f16b26
    SHA256: 487405001ca4e1c691933920f8a7ee3917e817ddab1e07a949e6906cc3552abc
    CRC32: d0770295
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx SpecAn2023Q1.txt (623 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 495607808 字节 (472.65 MB)
    MD5: 487d44305cb199192ca40bd54cfb2daf
    SHA1: 8e7df57316346ae65e6d08448d9dfd56d2ac6bde
    SHA256: aa9e396fa9573e110258b04bde02666f895ccd04f2662cbd727368e16b2c9ba3
    CRC32: d04304af
    RFmx SpecAn2023Q1RTE.txt (656 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx SpecAn 2023 Q1 Readme
    January 2023
    This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions.
    • RFmx SpecAn Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx SpecAn Manuals: New features, behavior changes, and other documentation
    RFmx SpecAn 2023 Q1 includes the following new feature:
    RFmx SpecAn 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx SpecAn 2022 Q3 includes the following new feature:
    RFmx SpecAn has the following requirements:
    RFmx SpecAn 2023 Q1 supports the following 64-bit operating systems:
    Note    RFmx SpecAn no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx SpecAn 2023 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx SpecAn 2023 Q1 to an unsupported OS. Additionally, after installing RFmx SpecAn 2023 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx SpecAn
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    LabWindows™/CVI™2019 or later
    • NI-RFSG 14.0.1 or later
    Download the RFmx SpecAn installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx SpecAn installs the following licensed products
      • RFmx Noise Figure: This will enable the Noise Figure measurement in RFmx SpecAn.
      • RFmx Phase Noise: This will enable the Phase Noise measurement in RFmx SpecAn.
      • RFmx Power Amplifier: This will enable the AMPM and DPD measurements and the Crest Factor Reduction (CFR) support in RFmx SpecAn.
    • Use the serial number that is included with your software to activate the product. Refer to the NI Software Activation for more information on product activation.
    Item
    Installed Location
    Import Library files
    Documentation for RFmx SpecAn is located at Start » National Instruments » RFmx SpecAn Documentation.
    You can access all the installed RFmx SpecAn examples at Start » National Instruments » RFmx SpecAn » RFmx SpecAn Examples.
    The following is the behavior change in RFmx SpecAn 2022 Q4 from RFmx SpecAn 2022 Q3:
    • RFmx SpecAn drops support for 32-bit user mode.
    The following is the behavior change in RFmx SpecAn 2022 Q3 from RFmx SpecAn 21.8.2:
    The following are the behavior changes in RFmx SpecAn 20.7 from RFmx SpecAn 20.6.
    GMT+8, 2025-12-8 19:08
