查看: 1711|回复: 0
[NI软件产品] NI RFmx 2023 Q1 Win11 64bitEng NI Wireless Test Standard Software ni-rfmx-suite_23.0
  • 签到天数: 3820 天
    连续签到: 13 天
     楼主| 发表于 2023-3-22 10:49:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    NI RFmx 2023 Q1
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版/运行版,版本号23.0.0
    Full完整版
    文件大小: 2441127936 字节 (2.27 GB)
    修改日期: 2023-02-04 09:52
    MD5: 839b1a1b0ed6d5834dbb37c1e15a8527
    SHA1: ad13f2a3d7b0a597723bd0f1fed749c466eb1a27
    SHA256: cd18c2dded23fd537c7814afd9182630ce9c5953f2af0cdcbbb483c5eda82841
    CRC32: dccf5fc8
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFm2023Q1.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    RTE运行版
    文件大小: 702025728 字节 (669.50 MB)
    MD5: 96160e67b1a56e3172e6f834705bcc9a
    SHA1: dc93070f2c2a7f3ba8b92aeb832ebda4c9b0214e
    SHA256: c826a053aa26cd9be05dd129597200093c82f7b8bd24a3a53f6b93443b0d0a5a
    CRC32: 5ce945f7
    RFm2023Q1RTE.txt (588 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 2023 Q1 Readme
    January 2023
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 2023 Q1 supports the following 64-bit operating systems:
    Note  RFmx no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RFmx 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by RFmx (64-bit Only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, or 2023 Q1
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx Runtime (64-Bit) 2023 Q1 Readme
    January 2023
    This file contains important information about the RFmx Runtime (64-Bit), including system requirements, and installation instructions.
    • RFmx Runtime (64-Bit) Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx Runtime (64-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx SpecAn Runtime (64-Bit)
    • RFmx Demod Runtime (64-Bit)
    • RFmx WLAN Runtime (64-Bit)
    • RFmx for Bluetooth® Test Runtime (64-Bit)
    • RFmx NR Runtime (64-Bit)
    • RFmx LTE Runtime (64-Bit)
    • RFmx WCDMA Runtime (64-Bit)
    • RFmx TD-SCDMA Runtime (64-Bit)
    • RFmx EV-DO Runtime (64-Bit)
    • RFmx CDMA2k Runtime (64-Bit)
    • RFmx GSM Runtime (64-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    RFmx Runtime (64-Bit) has the following requirements:
    RFmx Runtime (64-Bit) 2023 Q1 supports the following 64-bit operating systems:
    Download the RFmx Runtime (64-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    GMT+8, 2026-3-9 13:37
