查看: 1697|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2023 Q1 Win11 64bitENG RFmx蜂窝测试TD-SCDMA23.0
    9 小时前
     楼主| 发表于 2023-3-22 11:00:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版/运行版,版本号23.0.0
    64位完整版校验和:
    文件大小: 1000310784 字节 (953.97 MB)
    修改日期: 2023-02-04 09:52
    MD5: 174d213b31ed6c596990b3ec9e11abb8
    SHA1: edee72b0a755cf9959887633f9e6ce39c144dc7f
    SHA256: 72c7ae11fdb37362c291adb08e62772dcb6e65ec8b46090b202ff8fcc6a842d4
    CRC32: f42442cf
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFm TD-SCDMA2023Q1.txt (555 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 489723904 字节 (467.04 MB)
    MD5: c2abe59b71742b1065acea2a5e039313
    SHA1: c1d95360c85d97a8461e33d93baa6c2de6b08857
    SHA256: a8e337a7b708a9d41d57272cc324db69a4f138a834601545461129184886fd77
    CRC32: 0800ebc7
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFm TD-SCDMA2023Q1RTE.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx TD-SCDMA 2023 Q1 Readme
    January 2023
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA 2022 Q3 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q1 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    GMT+8, 2025-12-8 19:07
