查看: 1573|回复: 0
[NI软件产品] NI RFmx WLAN 2023 Q1 Win11 64bitENG RFmx无线局域网络23.0
    10 小时前
  • 签到天数: 3764 天
    连续签到: 15 天
     楼主| 发表于 2023-3-22 11:22:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版,版本号23.0.0
    64位完整版校验和:
    文件大小: 1068169216 字节 (1018.69 MB)
    修改日期: 2023-02-04 09:48
    MD5: 36058ac27e58b8a2d0d2e5d10ae2e5b3
    SHA1: cdec3cb215ed1b0e7c3b11605468bc44892f7d4b
    SHA256: 326dfd748ec4b129a6acd79eece370710910215ba494063e4a54676adf0527e9
    CRC32: 78fb593f
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx WLAN2023Q1.txt (543 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 501856256 字节 (478.61 MB)
    修改日期: 2023-02-04 09:50
    MD5: 1f8ced062662d50735de69aea58372fe
    SHA1: 686637a59baf3e0f667a6a13e7529df591e3a21c
    SHA256: 685b30642b493cded9023a8ee6423a113f5e0023963e6e9706ab2251e49e49bb
    CRC32: 42b9fc20
    RFmx WLAN2023Q1RTE.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 2023 Q1 Readme
    January 2023
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2022 Q4 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D2.1.1
    • Support for calculating EVM for WLAN Preamble fields
    • Support for analyzing 320 MHz non-HT duplicate mode frame format
    • Support for PXIe-5842
    RFmx WLAN 2022 Q3 includes the following new features:
    • Support for LabVIEW 2022 Q3 (64-bit)
    • 802.11be standard support has been updated to comply with IEEE P802.11be/D2.0 specification
    • Support for dB Units in Common Pilot Error Magnitude trace
    RFmx WLAN 2023 Q1 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q1 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2026-1-6 19:24
