查看: 1750|回复: 0
[NI软件产品] NI RFmx for Bluetooth Test 2023 Q1 Win11 64bitEng RFmx蓝牙测试NIRFmxBluetooth23.0
  • 签到天数: 3858 天
    连续签到: 51 天
     楼主| 发表于 2023-3-22 12:05:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版/运行版,版本号23.0.0
    64位完整版校验和:
    文件大小: 995444736 字节 (949.33 MB)
    修改日期: 2023-02-04 09:51
    MD5: 51dab3fbba44fe682e14d9ef83d563ec
    SHA1: 1da59029b181c8e2336ad80cc9b6298088ed1954
    SHA256: 4ead054763cfcedd928fca8d825a7a012e18948df9f32d2a0956aa202aece4d3
    CRC32: 9d07de17
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx for Bluetooth Test2023Q1.txt (570 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 528771072 字节 (504.28 MB)
    MD5: 2c27f827e094f89f24b0471c82d65ba0
    SHA1: 7277e216f1dbaa1de02f20d0653fdbd7210cd907
    SHA256: 9e0467250659f81a8af3cba47d9418197385f7c6d11e0eaca0564f4949094410
    CRC32: 20ce18d0
    RFmx for Bluetooth Test2023Q1RTE.txt (597 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx for Bluetooth® Test 2023 Q1 Readme
    January 2023
    This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions.
    • RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
    RFmx for Bluetooth® Test 2023 Q1 includes the following new feature:
    RFmx for Bluetooth® Test 2022 Q4 includes the following new feature:
    • Support for DF2 and CFO measurements for Bluetooth LE 500kbps (S=2) packets
    • Support for PXIe-5842
    RFmx for Bluetooth® Test 2022 Q3 includes the following new feature:
    RFmx for Bluetooth® Test has the following requirements:
    RFmx for Bluetooth® Test 2023 Q1 supports the following 64-bit operating systems:
    Note    RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 2023 Q1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 2023 Q1 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 2023 Q1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx for Bluetooth® Test (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    If you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » RFmx » BT palette.
    Documentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx for Bluetooth® Test Documentation.
    You can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx for Bluetooth® Test Examples.
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q4 from RFmx for Bluetooth® Test 2022 Q3:
    • RFmx for Bluetooth® Test drops support for 32-bit user mode.
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q3 from RFmx for Bluetooth® Test 21.8.2:
    The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7.
    • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
    GMT+8, 2026-4-16 11:04
