查看: 1038|回复: 0
[NI驱动程序] NI RF Signal Analyzers 2023 Q1 Patch 1 Win11 32/64bitEng NI PXI矢量信号分析仪驱动NI-RFSA 23.0.1
    昨天 10:43
  • 签到天数: 3512 天
    连续签到: 6 天
     楼主| 发表于 2023-3-22 15:45:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSA
    NI-RFSA 2023 Q1 Patch 1
    发布日期:2023/3/9
    包含的版本:2023 Q1 Patch 1完整版,版本号23.0.1
    语言:英文English
    文件大小: 3907411968 字节 (3.64 GB)
    修改日期: 2023-03-09 21:52
    MD5: f905a3aee6c3a0a65f6842460db39eb6
    SHA1: 502c23f40163fb55b2803a34ad434efc0ff1c0b2
    SHA256: 1d0b777cb4a77a05524e6f950275f0318f23a5fe380f6a2091f0f3c1f744ab83
    CRC32: ce8e6898
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSA2023Q1 Patch1.txt (526 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RFSA 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSA 2023 Q1 Patch.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Documentation: New features, behavior changes, and other documentation
    NI-RFSA 2023 Q1 Patch includes the following new feature:
    NI-RFSA 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSA 2022 Q4 includes the following new feature:
    NI-RFSA 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    NI-RFSA 2023 Q1 Patch and NI-RFSA SFP 2023 Q1 support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSA
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "NI-RFSA Support for LabVIEW" package supports applications using NI-RFSA ​with LabVIEW 2023 Q1 or later. When installing NI-RFSA, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-4-13 10:16
