查看: 1184|回复: 0
[NI驱动程序] NI PXI Platform Services 2023 Q2 Win11 32/64bit多国语言 PXI平台服务NI-PXIPS23.3下载
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2023-5-6 12:40:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    PXI Platform Services用于支持NI PXI机箱和控制器,遵循PXI软件规范,并为其他NI产品提供系统服务。
    PXI Platform Services用于识别NI PXI和PXI Express机箱和模块,以及允许触发路由。 对于特定NI模块,使用完整的模块功能仍需要适用的硬件驱动程序。 NI PXI Platform Services已包含在NI仪器驱动程序中,但有些情况下,某些应用程序只需要PXI Platform Services软件,例如在没有安装其他NI PXI硬件驱动程序的情况下使用NI MXI产品或使用NI PXI或PXI Express机箱。
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    语言:中文, 德语, 日语, 法语, 英文, 韩语
    文件大小: 1440135168 字节 (1.34 GB)
    修改日期: 2023-04-12 09:52
    MD5: 3761ca335b59fad53561c58e20850eb7
    SHA1: 31ac49960653c76e8a78eea3b3fed63f8eb32981
    SHA256: 702b8f9d3f077680081a3658c9184279ad74f528df98e4ca2c6b0f02d425b3d5
    CRC32: ecb7cff1
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    PXI Platform Services2023Q2.txt (573 Bytes, 下载次数: 0, 售价: 10 元)
    2023 Q2版未更新自述文件,参考2023Q1版:
    PXI Platform Services 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for PXI Platform Services 2023 Q1.
    • PXI Platform Services Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • PXI Platform Services Documentation: New features, behavior changes, and other documentation
    PXI Platform Services 2023 Q1 supports the following operating systems:
    PXI Platform Services 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by PXI Platform Services
    LabVIEW2020 and later
    LabWindows™/CVI™2020 and later
    Download the PXI Platform Services installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    The "PXI Platform Services Support for LabVIEW" package supports applications using PXI Platform Services ​with LabVIEW 2022 or later. When installing PXI Platform Services, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    The PXI Platform Services 2023 Q1 release adds the following features:
    • Added support for a new PCIe peripheral module
    • Added support for a new cooling requirement
    • Added support for LabVIEW 2023 Q1
    PXI Platform Services supports PXI and PXI Express functionality. For a complete list of hardware that is compatible with PXI Platform Services, refer to NI PXI Platform Services Hardware Support.
    PXI Platform Services will no longer provide support for the following hardware:
    • PXIe-8105
    • PXIe-8106
    PXI Platform Services no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-7-23 12:12
