查看: 1678|回复: 0
[NI驱动程序] LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2 Win11 32/64bitEng LabVIEW可重配置示波器仪器设计库NIREOSCIDL23.3
    7 小时前
  • 签到天数: 3851 天
    连续签到: 44 天
     楼主| 发表于 2023-5-6 13:02:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW可重配置示波器仪器设计库
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes可帮助您使用用户可编程的FPGA为PXI示波器开发所需的应用程序。
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    语言:英文English
    文件大小: 1275471872 字节 (1.19 GB)
    修改日期: 2023-04-12 09:52
    MD5: 564fcd1390871bc3d872487855589fa7
    SHA1: be7efc9e3d7d2487ac0458bdb893c93e5f59f9c1
    SHA256: ae57628d3178d645a625171fd151ebee1e9a7e8cc07a0bc9c50ada58b166bcbd
    CRC32: 4a9fef73
    请注册登陆机器视觉论坛账号,购买附件查看下载地址
    NIREOSCIDL2023Q2.txt (644 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2.
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Documentation: Detailed documentation about how to use your product
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2 provides support for customers using the PXIe-5164, PXIe-5170, PXIe-5171, and PXIe-5172 reconfigurable oscilloscopes with LabVIEW 2023 Q1 and later.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2 has the following requirements:
    • Pentium 4 or equivalent processor
    • 2 GB RAM
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for a specific version of LabVIEW.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2 supports the following operating systems:
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2 supports the following application software versions, including service packs.
    Versions Supported by LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes 2023 Q2
    LabVIEW2023 Q1 and later
    LabVIEW FPGA Module (recommended)2023 Q1 and later
    Download the LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Uninstalling the LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes
    As part of the LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes, the following software is installed. To completely remove the LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes installation from your system, you must also remove all of the following packages:
    • NI PXI Platform Services
    • NI System Configuration Runtime
    • NI-RIO
    The "LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Support for LabVIEW" package supports applications using LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes ​with LabVIEW 2023 Q1 or later. When installing LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    • Support for LabVIEW 2023 Q1 and later
    • PXIe-5164
    • PXIe-5170
    • PXIe-5171
    • PXIe-5172
    Refer to the LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes documentation, accessible from Start»All Programs»National Instruments»Reconfigurable Oscilloscopes»Reconfigurable Oscilloscope Documentation, for information about the LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes.
    LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-4-9 16:03
