查看: 1375|回复: 0
[NI软件产品] NI RFmx CDMA2000 2023 Q2 Full/Runtime Win11 64bitENG RFmxCDMA2K完整版运行版23.3下载
    9 小时前
     楼主| 发表于 2023-5-6 15:21:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版/运行版,版本号23.3.0
    64位完整版校验和:
    文件大小: 842133504 字节 (803.12 MB)
    修改日期: 2023-04-12 09:52
    MD5: 1c21064416df20e55f8725bf3f4faa0c
    SHA1: 8fdec37963aa71781e8dbfc7d66810f333ad2e24
    SHA256: 39aa16ee629f3f6dbb73432ee611a1bb8523168fcebb10e7e967c7a633793ae3
    CRC32: 3e97757a
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K2023Q2.txt (542 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 672311296 字节 (641.17 MB)
    MD5: 07e1c194584e6aabd8c6bcff230d008e
    SHA1: 12bd35e9ab595146d6bde30314a481374fddb373
    SHA256: 74d5e62c42e46b872cec25332a081a066ce819bf3423dcb5a03b303dee5a1d1e
    CRC32: f0d587a1
    RFmx CDMA2K2023Q2RTE.txt (574 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx CDMA2k 2023 Q2 Readme
    April 2023
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q2 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q2 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Versions Supported by RFmx CDMA2k (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2025-12-8 19:08
