查看: 1397|回复: 0
[NI软件产品] NI RFmx GSM/EDGE+ 2023 Q2 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件23.3
    9 小时前
     楼主| 发表于 2023-5-6 15:47:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx GSM/EDGE+
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版/运行版,版本号23.3.0
    64位完整版校验和:
    文件大小: 1200261120 字节 (1.12 GB)
    修改日期: 2023-04-12 09:50
    MD5: 2665933af7f3cea8f2e1b9647194d5c2
    SHA1: 9789b4a4a85c1d317ec3a69f1542d2c741942647
    SHA256: c3fb8df5411b5ff6d4f8eb79b2aae7d9c5675c02b58833d9e64538f67fde3e42
    CRC32: 3eef0655
    NI官方下载和百度网盘下载地址:
    注册登录视觉论坛账号,购买附件查看下载地址
    RFmx GSM EDGE2023Q2.txt (533 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 657092608 字节 (626.65 MB)
    修改日期: 2023-04-12 09:52
    MD5: 633ad151dcab1f8f75b2c3aea61b0113
    SHA1: 7ceeef1905ab05a92b560caa4184366b59c4f6bc
    SHA256: 2aaf6cf25713e5ea977aa53b975ab90a575ce8656920556be7eca9f06175abd6
    CRC32: b16ac966
    NI官方下载和百度网盘下载地址:
    RFmx GSM EDGE2023Q2RTE.txt (566 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx GSM 2023 Q2 Readme
    April 2023
    This file contains important information about the RFmx GSM, including system requirements, and installation instructions.
    • RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx GSM Manuals: New features, behavior changes, and other documentation
    RFmx GSM 2023 Q2 includes the following new feature:
    RFmx GSM 2023 Q1 includes the following new feature:
    RFmx GSM 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for configurable RBW in PVT measurement.
    RFmx GSM has the following requirements:
    RFmx GSM 2023 Q2 supports the following 64-bit operating systems:
    Note    RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2023 Q2 to an unsupported OS. Additionally, after installing RFmx GSM 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx GSM (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    If you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette.
    Documentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation.
    You can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples.
    The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3
    • RFmx GSM drops support for 32-bit user mode.
    The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2
    The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6.
    GMT+8, 2025-12-8 19:07
