查看: 1430|回复: 0
[NI软件产品] NI RFmx NR 2023 Q2 Win11 64bitENG RFmx 5G新空口蜂窝测试23.3
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2023-5-6 16:43:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    NI RFmx NR 2023 Q2
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版/运行版,版本号23.3.0
    64位完整版校验和:
    文件大小: 1568233472 字节 (1.46 GB)
    修改日期: 2023-04-12 09:53
    MD5: ccf55666c42da816ff2c9fcaab942eb1
    SHA1: 6eb341101fc94573225a754b144e2a4fef94af2f
    SHA256: 9f9d293c96d2ccb7f475921ddd707e8049fbf65c1a8386e673b44e58ebc30e22
    CRC32: d97149c7
    NI官方下载和百度网盘下载地址:
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR2023Q2.txt (523 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 703676416 字节 (671.08 MB)
    MD5: 7a4766f83954358097c401c10d2661fd
    SHA1: edb9d1ab6425d071b6b585571029feae358eebfa
    SHA256: 4905d32dd598d34650b9aa3a1a82f1a1fbed20cb024ca5222adb4f1c286c079a
    CRC32: 471738ae
    NI官方下载和百度网盘下载地址:
    RFmx NR2023Q2RTE.txt (556 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 2023 Q2 Readme
    April 2023
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    • RFmx NR Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx NR Manuals: New features, behavior changes, and other documentation
    RFmx NR 2023 Q2 includes the following new features:
    • Support for Phase Offset measurement
    • Support for Test Tolerance for NR-U band n46 in SEM measurement as per 3GPP Release 17 (December-2022)
    RFmx NR 2023 Q1 includes the following new features:
    • Support for EVM Measurement including symbols with Transient Period
    • Support for shared spectrum channels for n46, n96, and n102 bands in the SEM Measurement
    • Support for Power Class 6 in the IBE Measurement
    RFmx NR 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for bands n100 and n104 based on 3GPP Release 17 (June-2022)
    • Support for new bandwidths for SEM measurement in NS_27 and NS_04 based on 3GPP Release 17 (June-2022)
    • Support for Cell ID Auto Detection
    RFmx NR has the following requirements:
    RFmx NR 2023 Q2 supports the following 64-bit operating systems:
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx NR (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx NR installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    RFmx NR palette VIs are available from the Functions » Measurement I/O » RFmx » NR palette.
    Documentation for RFmx NR is located at Start » National Instruments » RFmx NR Documentation.
    You can access all the installed RFmx NR examples at Start » National Instruments » RFmx NR Examples.
    The following are the behavior changes in RFmx NR 2022 Q3 from RFmx NR 21.8:
    • RFmx Soft Front Panel has been replaced by InstrumentStudio.
    The following are the behavior changes in RFmx NR 21.8 from RFmx NR 21.5:
    • RFmx NR drops support for 32-bit user mode.
    • Deprecated PDSCH present in SSB Resource Block.
    • Deprecated Subblock Freq Definition property. Use Subblock Freq (Hz) property for configuring subblock frequency offset from the center frequency.
    The following are the behavior changes in RFmx NR 21.3 from RFmx NR 20.7/20.7.1:
    • Updated downlink subblock integration bandwidth for ACP, CHP, and SEM measurements as per 38.104 CR0262.
    • Increased acquisition length for ModAcc measurement in the case of DFT-s-OFDM with SCS 60 kHz, and above with trigger types other than digital and sync mode other than Frame.
    GMT+8, 2026-2-3 05:26
