查看: 1332|回复: 0
[NI软件产品] NI RFmx 2023 Q2 Win11 64bitEng NI Wireless Test Standard Software ni-rfmx-suite_23.3
    9 小时前
     楼主| 发表于 2023-5-6 16:57:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    NI RFmx 2023 Q2
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版/运行版,版本号23.3.0
    RFmx Full完整版
    文件大小: 2788265984 字节 (2.60 GB)
    修改日期: 2023-04-12 09:53
    MD5: 1d836e8b04c81b2d44ff1ad23f64e631
    SHA1: 02b83959c6d9acc293b916e66ebcd435b482d906
    SHA256: 0a2b4eda88a2d3674ef3bf0799674e60e3b3b3baa37aafed9c5676c36d92a6cb
    CRC32: 0d60c7c4
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx2023Q2.txt (555 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx RTE运行版
    文件大小: 885835776 字节 (844.80 MB)
    MD5: 8c83a231ffaf8140fda331d6cd7ddecf
    SHA1: 5e0b4287f5b70c2d9c3ac0fb83e0b9feb7a60064
    SHA256: f2df0b69dce86080a0b527a083cbabe3bac5c6853a6a6a4c75dee847dd6c37a6
    CRC32: 063c0525
    RFmx2023Q2RTE.txt (588 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx 2023 Q2 Readme
    April 2023
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 2023 Q2 supports the following 64-bit operating systems:
    Note  RFmx no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    RFmx 2023 Q2 supports the following application software versions, including service packs.
    Versions Supported by RFmx (64-bit Only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, or 2023 Q1
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    RFmx Runtime (64-Bit) 2023 Q2 Readme
    April 2023
    This file contains important information about the RFmx Runtime (64-Bit), including system requirements, and installation instructions.
    • RFmx Runtime (64-Bit) Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx Runtime (64-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx SpecAn Runtime (64-Bit)
    • RFmx Demod Runtime (64-Bit)
    • RFmx WLAN Runtime (64-Bit)
    • RFmx for Bluetooth® Test Runtime (64-Bit)
    • RFmx NR Runtime (64-Bit)
    • RFmx LTE Runtime (64-Bit)
    • RFmx WCDMA Runtime (64-Bit)
    • RFmx TD-SCDMA Runtime (64-Bit)
    • RFmx EV-DO Runtime (64-Bit)
    • RFmx CDMA2k Runtime (64-Bit)
    • RFmx GSM Runtime (64-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    RFmx Runtime (64-Bit) has the following requirements:
    RFmx Runtime (64-Bit) 2023 Q2 supports the following 64-bit operating systems:
    Download the RFmx Runtime (64-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    GMT+8, 2025-12-8 19:09
