查看: 1378|回复: 0
[NI软件产品] NI RFmx WLAN 2023 Q2 Win11 64bitENG RFmx无线局域网络23.3.0
    9 小时前
     楼主| 发表于 2023-5-6 17:55:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    64位完整版校验和:
    文件大小: 1287948288 字节 (1.20 GB)
    修改日期: 2023-04-12 09:53
    MD5: 2a9b70eb290784e2732551c95334215f
    SHA1: 0fa1ed828abae74d4e5076844f491e7d5cfb8197
    SHA256: 677caa8797cfcb32ce0434d74f0fd5e6095d337c4ef779da244822ae7ccac9bc
    CRC32: b70ed3c6
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx WLAN2023Q2.txt (531 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 684718080 字节 (653.00 MB)
    MD5: 235dd7205861e9d08af5cf0d1bda6484
    SHA1: 569bcbecab7bb167fe52ae7fd184a25936473b43
    SHA256: 36210629b4431728fd7d91a6fe1635ecfdf4463275b357401bd99d0a0bcdcee9
    CRC32: d160bd81
    RFmx WLAN2023Q2RTE.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 2023 Q2 Readme
    April 2023
    RFmx WLAN 2023 Q2 includes the following new features:
    • Support for Combined Signal Demodulation across all MIMO standards
    • Support for 802.11be Standard IEEE P802.11be/D3.0
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2022 Q4 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D2.1.1
    • Support for calculating EVM for WLAN Preamble fields
    • Support for analyzing 320 MHz non-HT duplicate mode frame format
    • Support for PXIe-5842
    RFmx WLAN 2023 Q2 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q2 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    LabVIEW2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-12-8 19:09
