查看: 972|回复: 0
[NI驱动程序] NI RF Signal Analyzers 2023 Q2 Win11 32/64bitEng NI PXI矢量信号分析仪驱动NI-RFSA 23.3.0
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2023-5-8 10:41:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSA
    NI-RFSA 2023 Q2
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    语言:英文English
    文件大小: 4057143296 字节 (3.78 GB)
    修改日期: 2023-04-12 09:50
    MD5: d7ce2a2190c45a3882ab124e0f2bc9de
    SHA1: 3cdd9bf250dcf0674920c2aab80b3d1b999d494b
    SHA256: 83c1efce7cc4ad6b954035040716c6261e962068510e8d0384dead6482d4116e
    CRC32: 351106ed
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSA2023Q2.txt (514 Bytes, 下载次数: 0, 售价: 10 元)
    RFSA2023Q2版本未更新自述文件,参考2023Q1Patch版本的自述说明:
    NI-RFSA 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSA 2023 Q1 Patch.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Documentation: New features, behavior changes, and other documentation
    NI-RFSA 2023 Q1 Patch includes the following new feature:
    NI-RFSA 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSA 2022 Q4 includes the following new feature:
    NI-RFSA 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    NI-RFSA 2023 Q1 Patch and NI-RFSA SFP 2023 Q1 support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSA
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "NI-RFSA Support for LabVIEW" package supports applications using NI-RFSA ​with LabVIEW 2023 Q1 or later. When installing NI-RFSA, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-7-23 12:08
