查看: 905|回复: 0
[NI驱动程序] NI RF Signal Generators 2023 Q2 Win11 32/64bitEng NI RF信号发生器NI-RFSG23.3
    7 小时前
  • 签到天数: 3534 天
     楼主| 发表于 2023-5-8 10:48:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2023 Q2
    发布日期:2023/4/20
    包含的版本:2023 Q2完整版,版本号23.3.0
    文件大小: 4572248064 字节 (4.26 GB)
    修改日期: 2023-04-21 21:50
    MD5: 465f62f9405c08bc0371d9aa5ce97238
    SHA1: 82ea9049526a0898f8420e03c6e95e9783319e2c
    SHA256: fe9fea529b25c5e57cef044eb929c3caef1f569c37c7dab44b0420c730368dc3
    CRC32: 39678f5b
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSG2023Q2.txt (514 Bytes, 下载次数: 0, 售价: 10 元)
    RFSG2023Q2未更新自述文件,参考2023Q1Patch版的自述说明:
    NI-RFSG 2023 Q1 Patch Readme
    March 2023
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q1 Patch.
    • NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Documentation: New features, behavior changes, and other documentation
    NI-RFSG 2023 Q1 Patch includes the following new feature:
    NI-RFSG 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q4 includes the following new feature:
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022 Q3
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q1 Patch is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q1 Patch.
    NI-RFSG and NI-RFSG SFP support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    The "NI-RFSG Support for LabVIEW" package supports applications using NI-RFSG ​with LabVIEW 2023 Q1 or later. When installing NI-RFSG, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-5-9 14:13
