查看: 992|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2023 Q2 Win11 32/64bitEng NI-RFSG回放库23.3
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2023-5-8 11:16:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    语言:英文English
    32/64位完整版校验和:
    文件大小: 599801856 字节 (572.02 MB)
    修改日期: 2023-04-12 09:54
    MD5: 2465faeec6f8c93d893d69b6818295d9
    SHA1: 3880347bf8615e434cb75d53690fb03c49e98675
    SHA256: dff51998711a942f9f2e196b111e0800a33a5ac770fc9c7617a8f57a6bd75bb3
    CRC32: a659e9c7
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFSGPlayback2023Q2.txt (583 Bytes, 下载次数: 0, 售价: 10 元)
    32/64位运行版校验和:
    文件大小: 447406080 字节 (426.68 MB)
    MD5: a8bbb4e55d5095cce0842a0771b87089
    SHA1: 48b8d1349056da97867002bcc8f7a7297e06949a
    SHA256: 6da6a5a62bfd3f034ec22b106c0404927bde3e37efff7f41f0fdcb1205eaee81
    CRC32: 27a7f725
    RFSGPlayback2023Q2RTE.txt (615 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFSG Playback Library 2023 Q2 Readme
    April 2023
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    NI-RFSG Playback Library 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1 (32-bit and 64-bit)
    NI-RFSG Playback Library 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    NI-RFSG Playback Library 2022 Q3 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 2023 Q2 supports the following 64-bit operating systems:
    Note    NI-RFSG Playback Library no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-RFSG Playback Library 2023 Q2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 2023 Q2 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 2023 Q2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library (32-bit and 64-bit)
    LabVIEW2020 SP1, 2021, 2022 Q3, 2023 Q1
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library Documentation.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library Examples.
    GMT+8, 2025-7-23 12:12
