查看: 1141|回复: 0
[NI驱动程序] NI System Configuration 2023 Q2 MAC64bitEng NI系统配置nisyscfg23.3苹果系统版
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2023-5-8 12:25:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    System Configuration系统配置
    发布日期:2023/4/11
    包含的版本:2023 Q2完整版,版本号23.3.0
    Mac OS
    语言:英文
    校验和
    文件大小: 14357098 字节 (13.69 MB)
    修改日期: 2023-04-08 09:49
    MD5: 9d3df1a910e91211d24f31084750634c
    SHA1: 5dcce6ab13fbab8fc6ea27ce4d96f565e62bae6d
    SHA256: 79296e475edf9f29c5333fd990791808ba509b01c8d2f1700fc565adfe396323
    CRC32: 739affd8
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    系统配置2023Q2MAC.txt (501 Bytes, 下载次数: 0, 售价: 10 元)
    System Configuration 2023 Q2 for macOS Readme
    April 2023
    This file contains installation instructions and compatibility information for System Configuration for macOS.
    List of Features not Supported in macOS
    System Configuration includes NI Measurement & Automation Explorer (MAX), a configuration utility that provides access to your NI devices.
    System Configuration has the following requirements:
    • OS versions: macOS 11, macOS 12 (x86_64 only)
      Note System Configuration was verified with the specified operating systems.
    • At least 60 MB of disk space
    The following table lists the NI application software versions, including service packs, supported by System Configuration.
    Versions Supported by System Configuration
    NI LabVIEW2019, 2020, 2021, 2022 Q3 and later
    The "System Configuration Support for LabVIEW" package supports applications using System Configuration ?with LabVIEW 2022 Q3 or later. When installing System Configuration, this package will be recommended if you have already installed LabVIEW 2022 Q3 or later and installs to the LVAddons directory.
    LVAddons directory location: /Library/Application Support/National Instruments/LVAddons
    The following VIs in the System Configuration API that are supported with RT targets on Windows are not supported on macOS:
    • Get Available Software VI
    • Install VI
    • Uninstall VI
    © 2014–2023 National Instruments Corporation. All rights reserved.
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    GMT+8, 2025-7-23 12:12
