查看: 1384|回复: 0
[NI软件产品] NI AudioMASTER 6.3.0 Win32Eng NI音频控制6.3下载
    9 小时前
     楼主| 发表于 2023-5-8 18:08:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    AudioMASTER
    AudioMASTER可帮助您执行模拟和数字音频信号的采集、分析和生成。
    AudioMASTER是一款可提供音频生成和分析测试解决方案的应用软件,适用于模拟和数字音频验证和生产测试。该软件中,单音、多音、幅度扫描、频率扫描和阶跃响应分析已针对自动化测试进行了优化,可用于获得50多种声音和电声测量结果。您可以将该软件与受支持的PXI声音和振动模块、PXI数字可重配置I/O模块以及PXI音频和视频分析仪搭配使用,进行各种模拟和数字音频测试。AudioMASTER还支持与TestStand测试管理软件集成。
    发布日期:2012/11/19
    包含的版本:6.3完整版
    Windows 7
    Windows Vista
    Windows XP 32-bit
    Windows 8
    语言:英文English
    应用程序位数:32位
    文件大小: 574569096 字节 (547.95 MB)
    修改日期: 2023-01-21 09:59
    MD5: f3f63ea2b1278005258969035441110e(官方正确)
    SHA1: abb9d7fd0a01d10ab1eb8280458d40e01172514d
    SHA256: 0f74f585fa33cebf87fdf8680b3c0969570afb73818f6fb30cfcf4eeec081f3b
    CRC32: fa5eabd2
    请注册登录视觉论坛账号,购买附件查看下载地址
    AudioMASTER6.3.txt (511 Bytes, 下载次数: 0, 售价: 10 圆)
    NI AudioMASTER Readme
    Version 6.3
    Thank you for using NI AudioMASTER. This file contains important information about NI AudioMASTER and is organized into the following sections:
    • New Features
    • System Requirements
      • Required Hardware
      • Software Requirements
    • Installing AudioMASTER
      • Software Installation
      • System Setup
    • Evaluation and Activation
    • Updates and Notifications
    • Uninstalling/Modifying AudioMASTER
    • Known Issues
    • Important Information
    AudioMASTER 6.3 includes the following new features:
    • Support for TestStand 2010 SP1 and TestStand 2012.
    • Support for the NI PXIe-1491, including the following features:
      • When you enable ARC in NI AudioMASTER for the NI PXIe-1491, you gain Ethernet access to/from the HEC/LAN connector through the HDMI IN connector to any HEC-enabled device. (ARC and HEC are combined in the HEAC functionality defined by HDMI specifications, so enabling ARC also enables HEC.)
      • VIs and example VIs for programming the NI PXIe-1491 in LabVIEW.
    • Implementation of an NI installer.
    • Implementation of NI licensing and activation. Under the new licensing, activation of the Analog Audio Analysis and/or Digital Audio Analysis licenses applies to both AudioMASTER and all AudioMASTER plug-ins, so AudioMASTER plug-ins no longer require their own licenses.
    • LimiTEST built as a DLL.
    • Live View built as a DLL.
    • Hardware configuration tool to edit registry settings.
    • Support for localized decimal point in LimiTEST.
    • Implementation of AudioMASTER VIs that you can use within TestStand to change measurement plug-in parameters on the fly.The VIs are supported for LabVIEW 2011 SP1 (32-bit) and 2012 (32-bit).
    • Support for listing multiple frequencies in a table for Coherent Sweep, Dual Tone, and Multiple Pure Tones measurement plug-ins.
    • Support for selecting individual harmonics for nth harmonic calculations in the Single Tone, Amplitude Sweep, Coherent Sweep, and Multiple Pure Tones measurement plug-ins.
    AudioMASTER 6.2 includes the following new features:
    • Improved load time of AudioMASTER by building AudioMASTER into a DLL.
    • New LabVIEW digital audio API, NI-DigAudio.
    • Support for eight-channel HDMI audio.
    • Improved memory usage.
    • Improved the algorithm for the Polarity plug-in. This plug-in still supports test sequences that use the previous algorithm.
    • Update to Step Response plug-in to use a more robust method.
    • Update to the data transfer between AudioMASTER and LimiTEST when executing in TestStand.
    AudioMASTER 6.1 includes the following new features:
    • Support for running AudioMASTER without administrator rights by changing reading Windows registry values to use read-only mode.
    • Change in step types for TestStand to show a better default axis on the LimiTEST Graph Limit graph.
    • Change in calibration measurement functions to set the time-out value of the hardware platform to at least 1.5 times the acquisition time.
    • AudioMASTER now returns an error message if you run with an empty setup and pass the Save Waveform global setting in run mode.
    • Addition of signal info text that indicates the number of tones and the duration on plug-ins such as Amplitude sweep, Coherent sweep, Dual tone, and Multiple pure tone that generate stepped tone sweeps.
    • Addition of the mxAM Plug-in Queue Time Out GLOBAL VI to enable tuning performance for plug-in selection changes to avoid Error 1026.
    • Support for an Initial delay longer than the specified measure time by changing the signal calculation of delay segments. This change might also affect Pre-delay and Post-delay segments in the AmplSweep, CoSweep, and Flex sweep measurement functions.
    • Change in Single-tone plug-in to write Status bits in Digital Audio mode.
    • Support for a LimiTEST direct data transfer that enables you to select which vector result to use for evaluation by graph limits and key parameters. You can now include key parameter values and limits in the standard report.
    • Support for Live View in TestStand.
    • Support in Plug-in shell user interface for automatically selecting linear or logarithmic mapping.
    • Support for disabling the auto-mapping feature by setting auto scale on the x-axis to the unlocked state.
    • Support in Plug-in shell for writing the list of selected vector results and vectors to the mxAM Last Exec Data VI when a measurement is executed. LimiTEST uses this feature to browse for available results by name and immediately display recent results.
    • Support in Plug-in shell for saving output and/or input waveforms that pass to or from the hardware platform. Use the mxAM Save wfm GLOBAL VI to control this feature.
    • Support in FlexAUDIO-D1 platform driver for digital audio generation including AC3 encoded surround sound, and extension of advanced options for output and the selectable trigger connector. The platform driver does not support continuous output modes.
    • New Single tone plug-in that provides measurements on a single detected tone and includes support for digital audio (S/PDIF) and audio file output.
    • Support in Amplitude sweep plug-in for a selectable input filter on each input.
    • Support in BT-Headset plug-in to avoid error when using averaging as the first measurement, and to handle empty input signals such as Play only.
    • Support in Coherent sweep plug-in to include a selectable input filter on each input.
    • Support in Multiple pure tone plug-in to include a selectable input filter on each input.
    • Support in Multi-tone plug-in to select individual tone amplitudes on each output.
    • Improved the algorithm for the Step response plug-in.
    • Support in Waveform analyzer plug-in to select an individual tone or waveform on each output, and to have an input filter option and selectable windowing function on each input. Changed the amplitude ratio measurement to an impedance measurement by adding a resistor value.
    AudioMASTER 6.0 includes the following new features:
    • Product name change from HearMASTER to AudioMASTER. HearMASTER now refers to legacy test functions for hearing aid tests using SequenTEST.
    • The following updates to the plug-in shell:
      • Include the advanced platform settings within the configuration, eliminating the need to open and set values on a global variable.
      • Select channel range based on the range value rather than the index, so that AudioMASTER selects the most appropriate range automatically when you select a platform.
      • Allow the flexible selection of the number of signals to analyze and the number of results to return. This is also an update to the plug-ins.
      • Handle platform drivers with no output channels, such as FlexAUDIO-D1 and DAQmx-4462. This is also an update to the plug-ins.
    • Support for multiple input and output channels in all measurement plug-ins except Polarity and Rubb'n'Buzz. Each plug-in requires a new license.
    • Support for Relative unit selector for Amplitude ratio calculation in Amplitude sweep, Coherent sweep, Multiple pure tones, and Multi-tone plug-ins.
    • Support for Initial-delay parameter in Amplitude sweep, Coherent sweep, and Multiple pure tones plug-ins.
    • Support for measuring the frequency of a test signal within 5% of the specified generator frequency in the Amplitude sweep, Coherent sweep, and Multiple pure tones plug-ins. The previous version of these plug-ins used 5% of the sample rate.
    • Inclusion of channel and platform settings in the Calibration tool, Calibration manager, and Copy calibration data.
    • Support in the Calibration tool for setting advanced timing parameters and IEPE delay for calibration measurements to enable the use of an IEPE-powered microphone.
    • Addition of the ability to accept limits for the Calibration manager automatic mode.
    • Change of calibration file format to binary format and support for old calibration files to be automatically loaded and converted into the binary format.
    • Addition of a new platform option to support the input section of the FlexAUDIO-D1 digital audio interface, the NI PXI/PCI-78x3R, and the FlexSPDIF-01 digital audio interface. As a result, the SPDIF platform that previously supported the FlexSPDIF-01 digital audio interface is no longer needed and has been deleted.
    • Support in the FlexAUDIO-D1 platform for licensed decoder software for AC3 decoding. The new DirectShow functions might interfere with the previous demo decoder, the AC3-Filter.
    • Addition of the NI USB-9233 platform with four inputs, a legacy platform included for demonstration purposes.
    System RequirementsRequired Hardware
    NI recommends using the following hardware with AudioMASTER:
    • Required Hardware for Analog Audio
      • NI PXI/PCI-4461/4462—for generating and/or acquiring analog audio signals
    • Required Hardware for S/PDIF Digital Audio
      • NI PXI/PCI-7813R—for generating and/or acquiring S/PDIF digital audio signals
        NOTE:AudioMASTER also includes NI-DigAudio, which includes additional driver functionality for the NI PXI/PCI-7813R.
      • NI CB-2180 or NI CB-2181—for generating and/or acquiring S/PDIF digital audio signals
    • Required Hardware for HDMI Digital Audio
      • NI PXIe-1491–for acquiring HDMI digital audio signals
        NOTE: AudioMASTER installs the driver for the NI PXIe-1491.
    NOTE: AudioMASTER includes a Simulate platform that allows you to use the software without any hardware.
    AudioMASTER supports the following legacy hardware:
    • NI USB-9233—for analog audio acquisition
    • Sound Card—for demonstration use
    • NI PXI-2172—for HDMI digital audio acquisition.
      NOTE: The NI PXIe-1491 has replaced the NI PXI-2172 in NI AudioMASTER test systems for acquiring HDMI digital audio signals. While NI AudioMASTER still installs the driver for the NI PXI-2172 and supports NI PXI-2172 legacy hardware solutions, NI does not recommend using this hardware solution in new test systems.
    The following sections describe the NI driver, operating system, minimum system, and recommended system requirements for using AudioMASTER.
    NI Driver Requirements
    When you install NI AudioMASTER you are prompted to insert the August 2012 - NI Devices Driver DVD in order to install the following required drivers:
    • NI-DAQmx 9.3.5 or later
    • NI-RIO 12.0.0 or later—for using a digital hardware platform such as the NI 7813R
    • NI-HSDIO 1.7.5 or later—for using a digital hardware platform such as the NI 7813R
    You can find the latest versions of all required drivers on the National Instruments website at ni.com.
    NI AudioMASTER 6.3 and later supports the following operating systems:
    • Windows XP Service Pack 3 (SP3) (32-bit)
    Note  NI AudioMASTER 6.3 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed.
    Minimum System Requirements
    • Processor—Pentium 4, 2 GHz or equivalent
    • RAM—512 MB
    • A screen resolution of 1024 x 768 with 256 colors
    • Windows 7/XP, with all available critical updates and service packs
    Recommended System
    • Processor—Pentium 4 dual core or equivalent
    • RAM–1 GB or more
    • A screen resolution of 1024 x 768 with 16K colors
      NOTE: The performance of the system depends on the performance of the graphic adapter, so a better graphic adapter will make test programs run faster.
    Application Environments
    • LabVIEW 2011 SP1 (32-bit), or 2012 (32-bit)
    • NI TestStand 4.2.0, 4.2.1, 2010, 2010 SP1, and 2012
    The following sections describe how to install software and set up hardware for AudioMASTER.
    Install the required software for AudioMASTER in the following order:
    • Install any application environments in which you will use AudioMASTER.
    • Install the required drivers for any hardware you will use.
    • If you are upgrading from AudioMASTER 6.2 or earlier, uninstall the existing version of AudioMASTER before installing AudioMASTER 6.3.
    • Install AudioMASTER.
    • Activate AudioMASTER using the NI License Manager.
    • If you are upgrading from AudioMASTER 6.1 or earlier, update your sequence files in NI TestStand using the procedure described in the NI AudioMASTER Help.
    After you have installed all required software for AudioMASTER, set up your system as described in the System Setup section.
    System Setup
    Complete the following steps to set up your AudioMASTER system:
    • After installing the required application environments, drivers, and AudioMASTER, install all hardware that you will use, including any recommended hardware.
    • Launch the NI AudioMASTER Hardware Configuration panel and configure the hardware to use with AudioMASTER.
      • Launch the NI AudioMASTER Hardware Configuration panel using one of the following methods:
        • Launch the configuration panel from the Start menu at Start»All Programs»National Instruments»AudioMASTER»NI AudioMASTER Hardware Configuration.
        • Select the AudioMASTER Setup step in your test sequence in TestStand and click Hardware configuration tool in the AudioMASTER Setup tab under Step Settings for AudioMASTER.
      • Configure the hardware to use with AudioMASTER. Refer to the NI AudioMASTER Help for more information about hardware configuration for AudioMASTER.
    • Launch the NI AudioMASTER Configuration panel and configure your AudioMASTER tests.
      • Select Start»All Programs»National Instruments TestStand to launch NI TestStand.
      • Add an AudioMASTER Setup step (Step Types»NI AudioMASTER»AudioMASTER Setup).
      • Click Edit configuration in the AudioMASTER Setup tab under Step Settings for AudioMASTER to launch the NI AudioMASTER Configuration panel.
      • Configure your AudioMASTER tests.
      • Windows 7/Vista: Users\Public\Public Documents\National Instruments
      • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\National Instruments
      • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\National Instruments
    ItemInstalled Location on Windows 7 (32-bit)/7 (64-bit)*/Vista (32-bit)/Vista (64-bit)*/XP
    NI AudioMASTER DLL (32-bit)\AudioMASTER
    LimiTEST DLL (32-bit)\Shared\AVTest\LimiTEST
    Live View DLL (32-bit)\Shared\AVTest\LiveView
    NI AudioMASTER Examples for NI TestStand and LabVIEW†\TestStand \Examples\AudioMASTER
    *These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64).
    † Because AudioMASTER VIs can only be used within a TestStand step, the AudioMASTER example VI is installed with the AudioMASTER examples for TestStand.
    Refer to the NI-DigAudio Readme for NI-DigAudio installed file locations.
    AudioMASTER installs AudioMASTER documentation as well as documentation for NI-DigAudio and the NI PXIe-1491. Visit ni.com/manuals for the latest versions of product documentation. The following documentation installs with NI AudioMASTER:
    • NI AudioMASTER Readme
    • NI AudioMASTER Help—HTML help format. Contains NI AudioMASTER fundamentals and programming information.
    • NI-DigAudio Readme—Select Start»All Programs»National Instruments»NI-DigAudio»Documentation to view this document after installing AudioMASTER.
    • NI-DigAudio Help—HTML help format. Contains NI-DigAudio measurement concepts and LabVIEW reference sections. Select Start»All Programs»National Instruments»NI-DigAudio»Documentation to view this document after installing AudioMASTER.
    • NI PXIe-1491 Specifications—Printed and PDF format. Contains specifications for the NI PXIe-1491 device. Select Start»All Programs»National Instruments»NI AudioMASTER»Documentation to view this document after installing NI AudioMASTER.
    • NI PXIe-1491 Getting Started Guide—Printed and PDF format. Contains installation and configuration information for the NI PXIe-1491 device. Select Start»All Programs»National Instruments»NI AudioMASTER»Documentation to view this document after installing NI AudioMASTER.
    • NI Multimedia Test LabVIEW Reference Help—Contains information about NI Multimedia Test VIs. Select Start»All Programs»National Instruments»NI AudioMASTER»Documentation to view this document after installing NI AudioMASTER.
    After installation, NI AudioMASTER offers up to 45 days of full functionality for evaluation purposes. After this period, NI AudioMASTER is unable to perform measurements unless activated. For information about license options for NI AudioMASTER, refer to the NI License Manager at Start»All Programs»National Instruments»NI License Manager.
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Uninstalling/Modifying NI AudioMASTER
    Perform the following procedure to uninstall NI AudioMASTER 6.3:
    • Click Change/Remove.
    • Select NI AudioMASTER 6.3 from the dialog box that appears.
    As part of the NI AudioMASTER installation, the following software may be installed. To completely remove the NI AudioMASTER installation from your system, you must also remove all of the following packages and files:
    Packages:
    • NI IO Trace 3.0.2
    • NI Measurement & Automation Explorer 5.3.3
    • NI PXI Platform Services 3.0.3
    • NI PXI Platform Services 3.0.3 Configuration Support
    • NI System Configuration Runtime 5.3.2
    • NI Update Service 2.2.1
    • NI-RIO 12.0
    Files:
    • C:\ProgramData\National Instruments\AudioMASTER\AM Calib data.dat*
    Caution  The software package listed above is shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Note  Do not attempt to uninstall by manually deleting files, except for files in the above list marked with asterisks (*).
    The following are known issues for AudioMASTER 6.3:
    • Software support for the PXIe-1491 includes the following issues:
      • Transmitting data through the MONITOR OUT connector on the NI PXIe-1491 is not supported.
      • When acquiring a signal that is protected by HDCP encryption, the waveform data is not available for test. Please refer to the HDCP Encryption section in the Signal properties topic in the AudioMASTER help for details
    • If you click an f(x) button in the Key Parameter Editor to open an expression browser dialog box, then click inside the Key Parameter Editor, you cannot reselect the expression browser dialog box. Solve this problem by clicking anywhere on the screen outside of TestStand, then reclicking inside the expression browser dialog box.
    © 2004–2012 National Instruments. All rights reserved.
    The terms, HDMI™ and HDMI High-Definition Multimedia Interface™, and the HDMI Logo are trademarks or registered trademarks of HDMI Licensing LLC in the United States and other countries.
    GMT+8, 2025-12-8 19:07
