查看: 1597|回复: 0
[NI驱动程序] NI System Monitor 1.2 Win32Eng NI系统监控1.2(PXI Platform Services前身)
    前天 16:03
     楼主| 发表于 2023-5-8 19:03:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件名: NI System Monitor 1.2.0.iso
    文件大小: 469086208 字节 (447.36 MB)
    修改日期: 2023-02-22 08:20
    MD5: ef66845eaf2ae388c960aab88fe64c95
    SHA1: dbf280474c432993487193a647892463fc796e36
    SHA256: c7049e6900428a61d303136d3195dcbc3d4786340a4c617bfb68312a7b7f2d2d
    CRC32: ea3194b6
    System Monitor 1.2.txt (421 Bytes, 下载次数: 0, 售价: 10 圆)
    NI System Monitor 1.2 ReadmeAugust 2012
    Thank you for using NI System Monitor 1.2.
    This file contains release notes, patent information, and last-minute information for NI System Monitor. Some information in this file may be too recent to be included in the official documentation set.
    This readme contains the following main sections:
    • About NI System Monitor
    • Supported Interfaces
    • Release Notes
    • Enhancements and Bug Fixes
      • Version 1.2.0
    • Contacting National Instruments
    • Important Information
    NI System Monitor is an API for monitoring PXI chassis and controllers. Use NI System Monitor to monitor the following aspects of your PXI system:
    • Chassis intake temperature
    • Chassis exhaust temperature
    • Chassis fan speed
    • Chassis fan health
    • Chassis voltages
    • Controller CPU utilization
    • Controller CPU temperature
    • Controller memory utilization
    Supported LabVIEW versions:
    • LabVIEW 2009 SP 1 (32 bit)
    • LabVIEW 2010 SP 1 (32 bit)
    • LabVIEW 2011 SP 1 (32 bit)
    • LabVIEW 2012 (32 bit)
    Supported chassis:
    • PXI-1042 (with PXI-8250)
    • PXI-1042Q (with PXI-8250)
    • PXI-1045 (with PXI-8250)
    • NI PXIe-1062Q
    • NI PXIe-1065
    • NI PXIe-1075
    • NI PXIe-1078
    • NI PXIe-1082
    Supported controllers:
    • NI PXI-8101
    • NI PXI-8102
    • NI PXI-8105
    • NI PXI-8106
    • NI PXI-8108
    • NI PXI-8110
    • NI PXIe-8101
    • NI PXIe-8102
    • NI PXIe-8105
    • NI PXIe-8106
    • NI PXIe-8108
    • NI PXIe-8130
    Supported operating systems:
    • Windows XP SP3
    • Windows Vista x86 (32 bit)
    • Windows Vista x64 (64 bit)
    • Windows 7 x86 (32 bit)
    • Windows 7 x64 (64 bit)
    • LabVIEW Real-Time 2009 SP1
    • LabVIEW Real-Time 2010 SP1
    • LabVIEW Real-Time 2011 SP1
    • LabVIEW Real-Time 2012
    Release NotesSystem Monitor RT target minimum version
    Both the RT host and RT Target need Sysmon 1.2 or higher. Errors may occur if the RT Target has a version earlier than Sysmon 1.2.
    CPU Properties - Windows Only
    CPU properties, with the exception of the CPU temperatures, are supported on Windows operating systems only. On Vista, administrator access is required to get CPU utilization.
    Suspend/Hibernate not supported
    Functional issues may occur when placing your PC in Suspend or Hibernate mode when the System Monitor application is running.
    Virtual memory query
    Querying the amount of free virtual memory may return unreliable values.
    Notes on Supported Hardware
    • Under normal operating conditions, PXI fan speed may vary up to 50 percent between fans in the same chassis.
    • PXI chassis values are updated in 2-3 second intervals. Querying for data at a faster rate may not be beneficial.
    Enhancements and Bug Fixes in Version 1.2.0
    Updated support for LabVIEW versions:
    • LabVIEW 8.2.1 - Support is discontinued in this release
    • LabVIEW 8.5.1 - Support is discontinued in this release
    • LabVIEW 8.6.1 - Support is discontinued in this release
    • LabVIEW 2010 SP1 - Support is added in this release
    • LabVIEW 2011 SP1 - Support is added in this release
    • LabVIEW 2012 - Support is added in this release
    Thank you for your interest in PXI Platform Services. We appreciate communicating with the people who use our products. We are also very interested in hearing about the applications you develop using our products. Our Web site, ni.com, provides advanced support and services and contact information.
    © 2007–2012 National Instruments. All rights reserved.
    FireWire® is the registered trademark of Apple Computer, Inc.
    Handle Graphics®, MATLAB®, Real-Time Workshop®, Simulink®, Stateflow®, and xPC TargetBox® are registered trademarks, and TargetBox™ and Target Language Compiler™ are trademarks of The MathWorks, Inc.
    Tektronix® and Tek are registered trademarks of Tektronix, Inc.
    The Bluetooth® word mark is a registered trademark owned by the Bluetooth SIG, Inc.
    GMT+8, 2026-2-25 01:06
