查看: 1555|回复: 0
[NI驱动程序] NI PXI Platform Services 14.1 Driver Win32/64Eng PXI平台服务NI-PXIPS14.1下载
  • 签到天数: 3858 天
    连续签到: 51 天
     楼主| 发表于 2023-5-8 19:15:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    PXI Platform Services用于支持NI PXI机箱和控制器,遵循PXI软件规范,并为其他NI产品提供系统服务。
    PXI Platform Services用于识别NI PXI和PXI Express机箱和模块,以及允许触发路由。 对于特定NI模块,使用完整的模块功能仍需要适用的硬件驱动程序。 NI PXI Platform Services已包含在NI仪器驱动程序中,但有些情况下,某些应用程序只需要PXI Platform Services软件,例如在没有安装其他NI PXI硬件驱动程序的情况下使用NI MXI产品或使用NI PXI或PXI Express机箱。
    发布日期:2014
    版本号:14.1完整版
    Windows 10
    Windows 7
    Windows Server 2008 R2 64-bit
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Server 2003 R2 32-bit
    Windows XP (SP3) 32-bit
    Windows Vista
    语言:英文
    文件大小: 647647684 字节 (617.64 MB)
    修改日期: 2023-01-21 09:51
    MD5: fae1892bcf892eefc9f84ad539605eb4
    SHA1: 483fd57b75fb959d16f65a93cbac46372b366f91
    SHA256: 969a14cc32392b6132a0d61b9edcce6afb2e642e57d4b551ac3317a9eda12eb1
    CRC32: 7344b745
    请注册视觉论坛账号,登录购买附件查看,充值请联系在线客服
    PXI Platform Services14.1.txt (508 Bytes, 下载次数: 0, 售价: 10 圆)
    PXI Platform Services 14.1 Readme
    December 2014
    This file contains release notes, patent information, and last-minute information for the PXI Platform Services software. Some information in this file may be too recent to be included in the official documentation set.
    Parts of this document are only relevant to a full installation and do not apply to a runtime-only installation.
    This readme contains the following main sections:
    • Release Notes
    • Supported Interfaces
    • Compatible Software
    • PXI System Monitoring
    • Enhancements and Bug Fixes
    • NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003
    • How to Use NI Software with Microsoft Windows 8
    • Legal Information
    Release Notes
    PXI Platform Services 14.1 is the latest driver offering from National Instruments. Every attempt has been made to maintain backward compatibility with the installed base. For more information about changes in PXI Platform Services, review the Enhancements and Bug Fixes section.
    If you are using PXI Platform Services 14.1 to upgrade a Windows system that serves as a host for one or more LabVIEW Real-Time targets, it is highly recommended that you also update your targets to leverage new features and improved performance.
    Note: You cannot use PXI Platform Services 14.1 to configure a LabVIEW Real-Time target with a version of PXI Platform Services earlier than 2.0.
    Back to top
    PXI Platform Services supports PXI and PXI Express functionality on hardware found in KnowledgeBase 531FRFQ7, PXI Platform Services Hardware Support.
    Back to top
    Compatible Software
    This driver version is recommended for use with the following software:
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches.
    • Windows 8.0 (32-bit and 64-bit)
    • Windows Vista Service Pack 1 or later (32-bit and 64-bit)
    • Windows XP Service Pack 3 or later (32-bit)
    • Windows Server 2008 R2 with Service Pack 2 or later (64-bit)
    • Windows Server 2003 R2 with Service Pack 2 or later (32-bit)
    • LabVIEW Real-Time 2014
    • LabVIEW Real-Time 2013 SP1
    • LabVIEW Real-Time 2012 SP1
    • LabVIEW Real-Time 2011 SP1
    For the most up to date information, refer to KnowledgeBase 53399AQ7, PXI Platform Services Operating System Support.
    Unsupported PXI Platform Services Versions on Windows 8
    PXI Platform Services 3.2 was the first version to support Windows 8. If you installed a version of PXI Platform Services earlier than version 3.2 on Windows 8, you must uninstall it. To uninstall on Windows 8, go to the Control Panel, More settings, and select Uninstall a program.
    Unsupported PXI Platform Services Versions on Windows 7
    PXI Platform Services 2.5.3 was the first version to support Windows 7. If you installed a version of PXI Platform Services earlier than version 2.5.3 on Windows 7, you must uninstall it. To uninstall on Windows 7, go to the Control Panel and select Uninstall a Program.
    Unsupported PXI Platform Services Versions on Windows Vista
    PXI Platform Services 2.3 was the first version to support Windows Vista. If you installed a version of PXI Platform Services earlier than version 2.3 on Windows Vista, you must uninstall it. To uninstall on Windows Vista, go to the Control Panel and select Programs and Features. After uninstalling the unsupported driver on Windows Vista, you must run a clean-up utility. For this utility and more information, refer to KnowledgeBase 46BH366K, How Do I Remove Unsupported NI Software from Windows Vista to Install Officially Supported Versions?
    Back to top
    PXI System MonitoringNI PXI Chassis System Monitoring
    PXI Platform Services 3.2.1 was the first version to support the NI PXI-8250 module via the NI System Configuration API.
    Note: NI System Configuration 5.4 (or later) is required for LabVIEW API support.
    NI PXI Express Chassis System Monitoring
    PXI Platform Services 3.1 was the first version to support system monitoring via NI Web-Based Monitoring and Configuration and NI System Configuration API.
    NI PXI Express Remote Controllers may require a firmware update in order to take advantage of the system monitoring features. For more information, refer to KnowledgeBase 5Z8ENB62, Why can I not use System Monitoring on my NI PXIe-1066DC or NI PXIe-1085 Chassis with a MXI(e) Controller?
    Note: NI Web-Based Monitoring and Configuration for RT systems require LabVIEW Real-Time Module 2010 SP1 or later.
    NI System Monitor Minimum Requirement
    If NI System Monitor is installed on your system, upgrading PXI Platform Services to version 3.1 or later also requires an upgrade of NI System Monitor to version 1.2 or later.
    Back to top
    • Version 14.1
    • Version 14.0
    • Version 4.0.1
    • Version 4.0
    • Version 3.2.3
    • Version 3.2.2
    • Version 3.2.1
    • Version 3.2
    • Version 3.1
    • Version 3.0.4
    • Version 3.0.3
    • Version 3.0.2
    • Version 3.0.1
    • Version 3.0
    • Version 2.5.6
    • Version 2.5.4
    • Version 2.5.3
    • Version 2.5.2
    • Version 2.5.1
    • Version 2.3
    Back to top
    Enhancements and Bug Fixes in Version 14.1New Hardware Support
    Added support for new PXI Express hardware.
    Fixed Issue: Could not create chassis item in Measurement & Automation Explorer (MAX)
    505008: When using LabVIEW Real-Time with some using older NI PXI controllers that are unable to automatically identify, the chassis could not be created in MAX. This issue has been fixed.
    Back to top
    Enhancements and Bug Fixes in Version 14.0Driver Version Naming Changes
    PXI Platform Services versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: PXI Platform Services 14.0. For example, PXI Platform Services 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is PXI Platform Services 4.0.1. The first version released under the new numbering scheme is PXI Platform Services 14.0.
    Runtime Installer
    Starting with version 14.0, PXI Platform Services is available as a runtime installer. PXI Platform Services Runtime is a minimal installer which does not include configuration through Measurement & Automation Explorer (MAX). When building an installer using National Instruments application development environments (ADEs) such as LabVIEW, you will now have the option of including this subset of PXI Platform Services in your distribution.
    System Monitor
    Support for System Monitor is deprecated in PXI Platform Services and will be removed in a future release. Monitoring capabilities are available through the NI System Configuration API. Customers using System Monitor should migrate their applications to NI System Configuration API.
    Fixed issue: Chassis not automatically identified in MAX
    41696: When using a PXI Express Chassis and controller under a heavy load, the chassis could sometimes fail to auto-identify in MAX. This issue has been fixed.
    Back to top
    Enhancements and Bug Fixes in Version 4.0.1New Hardware Support
    Back to top
    Enhancements and Bug Fixes in Version 4.0PXI Specification Updates
    PXI Platform Services 4.0 adds support for the new PXI-9 specification, revision 1.0. This version also includes updates to meet the requirements of the following PXISA specification versions:
    • PXI-2 Software Specification, revision 2.4
    • PXI-4 Module Description, revision 1.1
    • PXI-6 PXI Express Software Specification, revision 1.2
    The PXI Express chassis description files now list the PXI specification compliance version. For more information on PXI specifications, go to pxisa.org.
    PXI Platform Services on Real-Time Systems
    When deploying software to your Real-Time system, PXI Platform Services is now visible in the Add/Remove software tree in Measurement & Automation Explorer (MAX). If you have more than one version of PXI Platform Services 4.0 or later installed on your host, you may select which version of PXI Platform Services will be deployed to the target. For more information about deploying software to Real-Time targets, see the MAX Help, available on the Help menu in MAX.
    Fixes in Measurement & Automation Explorer
    PXI Platform Services 4.0 fixes the following issues in MAX:
    • 37850: In some instances, NI PXI-8360 and PXI-MXI-4 devices may not be visible in MAX.
    • 393204: In some cases, there could be stability issues with PXI hardware in MAX.
    Back to top
    Enhancements and Bug Fixes in Version 3.2.3New Hardware Support
    Back to top
    Enhancements and Bug Fixes in Version 3.2.2New Hardware Support
    Added support for new PXI and PXI Express hardware.
    Removed Hardware Support
    PXI Platform Services will no longer provide support for the following hardware:
    • NI PXI-1002 chassis
    • NI PXI-1006 chassis
    • NI PXI-1010 chassis
    • NI PXI-1011 chassis
    • NI PXI-1020 chassis
    • NI PXI-1025 chassis
    • NI PXI-8150 controller
    • NI PXI-8150B controller
    • NI PXI-8170 controller
    • NI PXI-8174 controller
    • NI PXI-8175 controller
    • NI PXI-8176 controller
    • NI PXIe-8103 controller
    Back to top
    Enhancements and Bug Fixes in Version 3.2.1Windows 8 Fixes
    Minor updates to improve the Windows 8 user experience.
    Back to top
    Enhancements and Bug Fixes in Version 3.2Windows 8 Support
    PXI Platform Services 3.2 adds support for Windows 8 (32-bit and 64-bit).
    The following are known issues with Windows 8:
    • The fast startup capability introduced in Windows 8 may cause improper functioning of your hardware and device drivers. To properly initialize drivers, choose Restart or Shut Down when prompted at the end of the installation. To prevent future problems with installing or removing hardware, National Instruments recommends disabling fast startup. Refer to ni.com/info and enter the Info Code Win8FastStartup for more information.
    • Upgrading from a Windows 7 (or older) system is not supported
    NI PXI Express Remote Controller Firmware Updater
    PXI Platform Services has enabled the ability to update NI PXI Express Remote Controller Firmware. For more information, refer to the documentation of the specific firmware.
    Back to top
    Enhancements and Bug Fixes in Version 3.1NI PXI Express Chassis Monitoring
    Added support for monitoring NI PXI Express chassis via:
    • NI Web-Based Monitoring and Configuration
    • NI System Configuration API
    LabVIEW Support
    Support for LabVIEW 8.6 and LabVIEW 2009 is discontinued in this release.
    Back to top
    Enhancements and Bug Fixes in Version 3.0.4New Hardware Support
    Back to top
    Enhancements and Bug Fixes in Version 3.0.3New Hardware Support
    Back to top
    Enhancements and Bug Fixes in Version 3.0.2New Hardware Support
    Back to top
    Enhancements and Bug Fixes in Version 3.0.1Addressed failure with RT Reboot of Hypervisor System
    313181 Fatal exception, Code:0xC0000005 error, detected when restarting RT side of a Hypervisor system. This has been fixed.
    Back to top
    Enhancements and Bug Fixes in Version 3.0Updates to Measurement & Automation Explorer Graphical User Interface
    PXI Platform Services has updated the user interface for PXI Systems in Measurement & Automation Explorer. The following changes were made:
    • Better error detection.
    • Improved performance.
    • Identify bus as a chassis function replaced with Create New Chassis Wizard.
    • Updated help.
    • Controllers and MXI Modules now appear inside Slot View and Devices and Interfaces.
    • Majority of National Instruments PXI embedded controllers are now automatically identified.
    • MXI connectivity information is provided through Devices and Interfaces.
    • Removed redundant PXI System tree under Devices and Interfaces.
    LabVIEW Support
    Support for LabVIEW 8.5 is discontinued in this release.
    Back to top
    Enhancements and Bug Fixes in Version 2.5.6New Software Support
    PXI Platform Services 2.5.6 adds support for PXI Express systems on NI Real-Time Hypervisor.
    LabVIEW 8.2 Support
    Support for LabVIEW 8.2 is discontinued in this release.
    Back to top
    Enhancements and Bug Fixes in Version 2.5.4Windows 2000
    PXI Platform Services 2.5.4 removes support for Windows 2000.
    Windows Server Support
    PXI Platform Services 2.5.4 adds support for Windows Server 2003 R2 (32-bit only) and Windows Server 2008 R2.
    Back to top
    Enhancements and Bug Fixes in Version 2.5.3Windows 7 Support
    PXI Platform Services 2.5.3 adds support for Windows 7 x86 (32-bit) and Windows 7 x64 (64-bit).
    Back to top
    Enhancements and Bug Fixes in Version 2.5.2Updates to Measurement & Automation Explorer Graphical User Interface
    PXI Platform Services has updated the user interface for PXI Systems in Measurement & Automation Explorer to add System View.
    Back to top
    Enhancements and Bug Fixes in Version 2.5.1New Software Support
    PXI Platform Services 2.5.1 adds support for PXI systems on NI Real-Time Hypervisor.
    Back to top
    Enhancements and Bug Fixes in Version 2.3Windows Vista Support
    PXI Platform Services 2.3 adds support for Windows Vista x86 (32-bit) and Windows Vista x64 (64-bit).
    Back to top
    NI PXI Platform Services Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments PXI Platform Services will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of PXI Platform Services that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Back to top
    Back to top
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Start screen or from within NI Launcher.
    Windows 8.x Start screenDesktop TaskbarRight-click application and select Pin to Taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and selecting All apps (Windows 8) or click the down arrow on the bottom left of the screen (Windows 8.1).
    Back to top
    © 1998–2014 National Instruments. All rights reserved.
    374995A-01
    GMT+8, 2026-4-16 11:04
