查看: 1461|回复: 0
[LV工具模块] LabVIEW Sound and Vibration Measurement Suite 6.0 LabVIEW声音和振动测量套件6.0下载 适用LabVIEW8.5版
     楼主| 发表于 2023-5-9 12:40:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW声音和振动工具包提供了音频测试、声学测量和振动测量应用所需的函数和显示控件。
    LabVIEW声音和振动工具包是一个软件附加组件,包含易于使用的功率谱、正弦扫频和倍频程分析VI。它还可进行音频和失真测量、频率分析、频率响应测量和瞬态分析。该工具包还对分析解决方案进行了更新,以符合不断发展的IEC标准。LabVIEW声音和振动工具包提供了50多个可立即运行的LabVIEW示例,旨在帮助用户快速开始开发应用程序。
    在2019~2021版本,使用32位、64位分开安装文件的方式,在2018及之前的版本,2023Q3及之后版本则使用同一个安装文件,即同一安装文件可支持32位、64位LabVIEW,与VISION模块类似。具体的请查看下面的自述文件。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    文件名: Sound and Vibration Measurement Suite 6.0 LV8.5.zip
    文件大小: 587707175 字节 (560.48 MB)
    修改日期: 2023-05-09 12:06
    MD5: c1cd61d261254b4905dffda6a20a7c94
    SHA1: 0cdc80b1a1cc7c270838495babee80f203b9e986
    SHA256: b286d20b484eb76abed62a8b843c549354ba6f18f467b17a183e6d32dfe85548
    CRC32: c4a48880
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    SVMS6.0.txt (465 Bytes, 下载次数: 0, 售价: 20 圆)
    Sound and Vibration Software ReadmeVersion 6.0
    November 2007
    This file contains links to information that introduces you to the NI Sound and Vibration Assistant and to LabVIEW support for sound and vibration analysis.
    The NI Sound and Vibration Toolkit 6.0 provides the Sound and Vibration Assistant and LabVIEW support for sound and vibration analysis. The NI Sound and Vibration Measurement Suite 6.0 provides order analysis functionality for the Sound and Vibration Assistant and LabVIEW in addition to the Sound and Vibration Toolkit 6.0. The Sound and Vibration Measurement Suite 6.0 also provides additional functionality in LabVIEW such as human vibration filters, torsional vibration measurement VIs, and custom displays.
    Refer to the NI Sound and Vibration Assistant Readme for more information about the Sound and Vibration Assistant.
    Refer to the LabVIEW Sound and Vibration Analysis VIs Readme for more information about LabVIEW support for sound and vibration analysis.
    © 2007 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    LabVIEW Sound and Vibration Analysis VIs ReadmeVersion 6.0
    November 2007
    This file contains information about LabVIEW support for sound and vibration analysis. This file also provides you with help resources you can use while working with the software. This file contains the following information:
    Uninstalling Previous Versions
    Redistributing Executable Sound and Vibration Applications
    Documentation Additions
    The NI Sound and Vibration Toolkit includes a collection of VIs that you can use to perform typical measurements for audio, acoustic, or vibration applications. The Sound and Vibration Toolkit also includes the NI Sound and Vibration Assistant. The NI Sound and Vibration Measurement Suite provides order analysis functionality for the Sound and Vibration Assistant and LabVIEW in addition to the Sound and Vibration Toolkit. The Sound and Vibration Measurement Suite also provides additional functionality in LabVIEW such as human vibration filters, torsional vibration measurement VIs, and custom displays.
    Use the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite to perform the following sound and vibration measurements:
    • Scaling a signal to engineering units
    • Calibrating a measurement channel
    • Applying weighting filters
    • Integrating time-domain signals
    • Performing level measurements
    • Performing fractional-octave analysis
    • Performing frequency analysis
    • Performing single-tone measurements
    • Performing distortion analysis
    • Performing swept-sine measurements
    • Processing tachometer signals
    • Performing order analysis
    • Performing fault detection
    • Measuring torsional vibration
    • Performing transient analysis
    • Performing limit and mask testing
    • Displaying results
    • Loading or saving signals to UFF58 (universal file format) files
    The Sound and Vibration Measurement Suite includes the following new features in LabVIEW.
    Measuring Torsional Vibration
    Torsional vibration is a common phenomenon for rotating machinery such as engines, compressors, and turbines. High torsional vibration in a rotating system can cause the failure of rotating components or damage to the system. Use the Torsional Vibration Measurement VIs to measure and monitor torsional vibration in rotating systems. The Torsional Vibration Measurement VIs can calculate torsional vibration signals from both analog and digital tachometer signals. The Torsional Vibration Measurement VIs also can compensate for geometric imperfections that a tachometer system might have.
    Applying Weighting to Human Vibration Signals
    Human vibration refers to the effects of mechanical vibration on the human body. Measuring and analyzing human vibration signals can help control the negative effects of mechanical vibration on the human body. Use the SVT Human Vibration Weighting Filter (Fixed Rate) VI, the SVT Human Vibration Weighting Filter (frequency) VI, and the SVT Human Vibration Weighting Filter (octave) VI to apply weighting to human vibration signals in both the time and frequency domains. Applying weighting to human vibration signals can isolate the directional components that you are interested in and help you further analyze different types of human vibration.
    Performing Order Analysis on VxWorks Real-Time Targets
    The Sound and Vibration Measurement Suite now supports order analysis functionality on VxWorks Real-Time targets.
    To run the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite, your computer must meet the following minimum system requirements:
    • Windows Vista/XP/2000
    • Minimum of 512 MB of RAM
    • Pentium 4/M or equivalent processor
    • LabVIEW 8.2.1 or later Full Development System or Professional Development System installed and properly licensed
    • NI-DAQmx 8.5 or later installed for NI-DAQmx support
    You must uninstall previous versions of the Sound and Vibration Toolkit, the Sound and Vibration Measurement Suite, and the Order Analysis Toolkit before installing the Sound and Vibration Toolkit 6.0 or the Sound and Vibration Measurement Suite 6.0.
    Complete the following steps to uninstall previous versions of the Sound and Vibration Toolkit, the Sound and Vibration Measurement Suite, or the Order Analysis Toolkit.
    • Open the Add or Remove Programs dialog box from the Control Panel.
    • Select National Instruments Software and click the Change/Remove button.
    • From the Products list, select the following items and click the Remove button.
      • NI LabVIEW Sound and Vibration Toolkit or NI LabVIEW Sound and Vibration Analysis VIs
      • NI LabVIEW Order Analysis Toolkit or NI LabVIEW Order Analysis VIs
      • NI Sound and Vibration Assistant
    You must be logged in with administrator privileges to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite. Note the following considerations when installing these products.
    • If you have the Sound and Vibration Toolkit and multiple versions of LabVIEW installed, you can install the Sound and Vibration Measurement Suite only in the same version of LabVIEW in which the Sound and Vibration Toolkit is installed.
    • You cannot install the Sound and Vibration Toolkit 6.0 on a computer that has the Sound and Vibration Measurement Suite 5.0 installed. You must uninstall the Sound and Vibration Measurement Suite 5.0 before you install the Sound and Vibration Toolkit 6.0.
    • You cannot install the Sound and Vibration Toolkit 6.0 on a computer that has the Order Analysis Toolkit 2.1 or earlier installed. You must purchase and install the Sound and Vibration Measurement Suite 6.0 to use order analysis functionality with the Sound and Vibration Toolkit 6.0.
    Complete the following steps to install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite:
    • Remove any previously installed versions of the Sound and Vibration Toolkit, the Sound and Vibration Measurement Suite, or the Order Analysis Toolkit.
    • Insert the Sound and Vibration Toolkit CD or the Sound and Vibration Measurement Suite CD into the CD-ROM drive of the computer. If the CD startup screen does not appear, use Windows Explorer to run the autorun.exe program located in the top-level folder on the CD.
    • Follow the setup instructions that appear on the screen.
    You must restart the computer after you install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite.
    If you install the Sound and Vibration Toolkit 6.0 or the Sound and Vibration Measurement Suite 6.0 in LabVIEW 8.5 or later, you must mass compile the following directories to improve the loading speed of the Sound and Vibration VIs.
    • labview\vi.lib\addons\Sound and Vibration
    • labview\vi.lib\addons\_XControls
    • labview\vi.lib\addons\_NISVFA
    If you mass compile these directories but do not have NI-DAQmx installed, the Sound and Vibration VIs that use NI-DAQmx are broken.
    Refer to the Known Issues section of this document for installation known issues.
    Redistributing Sound and Vibration Executables
    If you want to redistribute executables built with the Sound and Vibration Measurement Suite or any of its components, you must purchase the appropriate NI Sound and Vibration Software Run-Time License. The part number for the NI Sound and Vibration Software Run-Time License is 779875-01. Contact National Instruments to purchase the NI Sound and Vibration Software Run-Time License.
    The version of LabVIEW in which you install the Sound and Vibration Toolkit 6.0 or the Sound and Vibration Measurement Suite 6.0 determines the way in which you can access the help.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help in LabVIEW, for information about the Sound and Vibration VIs.
    LabVIEW 8.2.1
    Select Help»Sound and Vibration Measurement Suite Help in LabVIEW for information about the Sound and Vibration VIs.
    Note: The Sound and Vibration Concepts book contains the contents of the LabVIEW Sound and Vibration Analysis User Manual that ships with the Sound and Vibration Toolkit 5.0 and the Sound and Vibration Measurement Suite 5.0. The Sound and Vibration Toolkit 6.0 and the Sound and Vibration Measurement Suite 6.0 no longer provide the LabVIEW Sound and Vibration Analysis User Manual.
    You can find LabVIEW examples for the Sound and Vibration VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. You also can click the Find Examples link in the Getting Started window to launch the NI Example Finder.
    Use the Browse or Search page of the NI Example Finder to find an example VI. On the Browse page, the Sound and Vibration example VIs are located in the Toolkits and Modules»Sound and Vibration folder.
    The following list describes known issues at the time of release. Refer to the Knowledge Base at ni.com for the most recent information about known issues.
    Installation
    • If you want to install the Sound and Vibration Toolkit 6.0 or Sound and Vibration Measurement Suite 6.0 and the LabVIEW System Identification Toolkit, you must install the System Identification Toolkit 3.0.1 before you install the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite. If you already have the System Identification Toolkit 3.0.0 installed, you must uninstall any of the following software that you have installed: Sound and Vibration Toolkit or Sound and Vibration Measurement Suite, System Identification Toolkit, LabVIEW Control Design Toolkit, and LabVIEW SignalExpress. You then can install the System Identification Toolkit 3.0.1. Refer to the National Instruments Web site at ni.com for information about obtaining the System Identification Toolkit 3.0.1 upgrade CD.
    Waterfall and Colormap Displays
    • To color the 3D box decoration of Waterfall graphs and Octave Waterfall graphs, you must paint behind the two transparent graphs. If you color the hidden graphs, you cannot save those colors and the graphs return to transparent the next time you open the VI. Paint the bottom right corner of the decoration to ensure proper coloring of the decoration.
    • The shortcut menu of the Waterfall graph and the Octave Waterfall graph might seem unresponsive when the VI is running. Continual selection of the menu item eventually executes the selection.
    • The Waterfall graph, Octave Waterfall graph, and Colormap indicators might take some time to load when you use them for the first time. Click the indicator on the Sound & Vibration palette, wait until the dashed outline of the indicator appears, then click the front panel. The dashed outline appears when LabVIEW finishes loading the indicator.
    UFF58 File I/O
    • If you write to two UFF58 files in a loop or in two different VIs without changing the names of the files, LabVIEW returns error -2570, and you cannot flush data back to disk.
    General
    • If you have an application that uses the SVT Integration (frequency) VI that ships with the Sound and Vibration Toolkit 2.0 and the Sound and Vibration Toolkit 3.0, the application is broken in the Sound and Vibration Toolkit 6.0. To fix the application, replace the SVT Integration (frequency) VI with the SVL Integration (frequency) VI and reconnect the input and output terminals.
    • The Sound and Vibration Measurement Suite does not support the OAT Extract Most Significant Order Waveforms VI, the OAT Extract Order Waveforms VI, or the OAT Tachless Speed Profile Generator VI on a VxWorks Real-Time target.
    • If you open an Order Tracking Express VI saved in the Sound and Vibration Measurement Suite 5.0 and generate code, the wire to the error in control is broken. You must re-wire the error in control.
    • If you install the Sound and Vibration Toolkit or the Sound and Vibration Measurement Suite in LabVIEW 8.2.1 and access the help by selecting Help»Sound and Vibration Measurement Suite Help in LabVIEW, the buttons for opening example VIs in the help do not work. To use these buttons, access the help by opening svmain.chm from the labview\help directory.
    The following items are the IDs and titles of a subset of issues fixed in the Sound and Vibration Toolkit 6.0 and Sound and Vibration Measurement Suite 6.0. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Sound and Vibration Toolkit and the Sound and Vibration Measurement Suite.
    Bug IDFixed Issue
    46JFUHW9
    4579QD00
    Zoom FFT VIs do not coerce number of lines. These VIs now support zoom frequency resolutions finer or coarser than the baseband frequency resolution.
    4ADCS1W9Zoom Power Spectrum Express VI exports frequency range and number of lines as controls that can be input to the Express VI at run time.
    4BUMFR3RCode generation for multichannel Tone Measurement Express VI was modified to perform tone measurements on all channels.
    3ZOCOQW9SVT SNR without Harmonics VI uses a more robust algorithm that is less susceptible to underestimation of the level of the noise in the presence of high harmonic energy.
    4DBEARW9Getting Started with SVT example does not return error if example stopped before Playing WAV file because the sound task is only cleared if it is created.
    4APF9UW9Examples for DAQmx measurement devices support AC coupling and IEPE excitation through front panel controls, a popup dialog, or by setting a block diagram constant.
    4AD7IW9SVXMPL_Continuous Broadband Waveform VI and SVXMPL_Generate Excitation VI are executable because both VIs now call supported subVIs.
    497CM8W9UFF Write Express VI writes converted unit string to Record 9 when dB spectrum converted to linear spectrum.
    4D4CS4K9UFF Plugin version 2.2 writes correct number of bytes in the file header for all supported datatypes for both single- and double-precision writes.
    4BFCKEUCK
    46LEHQYV
    Sound and Vibration Toolkit and SignalExpress 2.5.1 can be installed to two different versions of LabVIEW on the same target machine.
    4DRCCVF3Support added for PXI-4498 and PXI-4496 in OAT Build Digital Tacho Info VI.
    3NDFI1YGOAT Convert to Even Angle Signal VI and other continuous processing VIs now automatically reset if the input signal is not continuously sampled.
    • The Cursor Lines option in the shortcut menu of the Colormap specifies to display the current order or frequency lines and to anchor the current order or frequency lines.
    NI Sound and Vibration Assistant ReadmeVersion 6.0
    November 2007
    file:///C:/Users/VISION~1/AppData/Local/Temp/7zO0DE13992/jpntext.gif
    This file contains information about NI Sound and Vibration Assistant 6.0. This file also provides you with help resources you can use while working with the Sound and Vibration Assistant. Refer to Getting Started with the NI Sound and Vibration Assistant for information about getting started with the Sound and Vibration Assistant. You can access this PDF by selecting Help»Getting Started with»Sound and Vibration Assistant in the Sound and Vibration Assistant.
    The Sound and Vibration Assistant is a powerful interactive tool that extends existing NI LabVIEW SignalExpress technology. The Sound and Vibration Assistant simplifies the process of acquiring, analyzing, and displaying sound and vibration signals by offering the following:
    • A drag-and-drop, interactive acquisition and analysis environment
    • Rapid measurement configuration
    • Extended functionality through NI LabVIEW
    • Analysis:
      • FFT analysis support for multichannel power spectrum and zoom power spectrum, and frequency response (1xN)
      • Spectrum measurements support for peak search, power in band, and limit test measurements
      • Level measurements support for sound level and vibration level
      • Fractional-octave analysis
      • Audio measurements support for single-tone (distortion and channel evaluation) and noise measurements, and tone extraction
    • Displaying and logging:
      • Octave graph
      • Harmonic and peaks tables
      • Engineering unit support
      • Logging and playback of time-domain signals
      • UFF58 (universal file format) file support to load and save time-domain data
      • Data snap shots and documentation
      • Export to Microsoft Excel
    Use the Getting Started with the NI Sound and Vibration Assistant manual to familiarize yourself with Sound and Vibration Assistant features and functionality.
    The Sound and Vibration Assistant 6.0 provides the following new features:
    • Order analysis steps, including Tachometer Processing, Order Tracking, Order Spectrum, Spectral Map, and Order Waveform
    • Colormap display
    • Waterfall graph display
    Note  The order analysis steps and colormap display features are only available in the NI Sound and Vibration Measurement Suite 6.0.
    The Sound and Vibration Assistant requires a minimum of 512 MB of RAM and a Pentium 4/M or equivalent processor.
    If you use the Sound and Vibration Assistant with National Instruments data acquisition hardware, you must install NI-DAQmx 8.5 or later.
    Refer to the Getting Started with the NI Sound and Vibration Assistant manual for information about installing the Sound and Vibration Assistant. National Instruments strongly recommends that you restart the computer after installing the Sound and Vibration Assistant.
    You can access the Sound and Vibration Assistant Help, part of the LabVIEW SignalExpress Help, by selecting Help»Sound and Vibration Assistant Help and navigating to the LabVIEW SignalExpress Step Reference»Sound and Vibration Assistant Steps book on the Contents tab. You also can view the step and control-level help in the dynamic help and hover help windows in the right pane of a Sound and Vibration Assistant project.
    You can access the Sound and Vibration Assistant example projects by selecting Help»Open Example»Sound and Vibration Assistant in the Sound and Vibration Assistant. Use the example projects in the Tutorial subdirectory with the Getting Started with the NI Sound and Vibration Assistant manual.
    The Sound and Vibration Assistant example projects are intended for use with National Instruments dynamic signal acquisition hardware. If you use any other device that does not support the specific measurements in the example project, you must change the Measurement Type to a measurement type supported by the device you want to use. You can change the Measurement Type on the Channel View tab or on the DAQmx Acquire Step Setup tab.
    • The Sound and Vibration Assistant extends existing NI LabVIEW SignalExpress technology. The LabVIEW SignalExpress readme, located in the Program Files\National Instruments\SignalExpress directory, lists known issues that you might encounter as you use the Sound and Vibration Assistant.
    • Sound and Vibration Assistant example projects that acquire data require the device name to be Dev1. If you want to use the example projects with your hardware, verify the device name is Dev1 in the Measurement & Automation Explorer. If you need to rename your hardware, right-click the device in MAX and select Rename from the shortcut menu.
    • If you want to install the Sound and Vibration Toolkit 6.0 or Sound and Vibration Measurement Suite 6.0 and the System Identification Toolkit 3.0.0, you must install the System Identification Toolkit 3.0.1 before you install the Sound and Vibration Toolkit or Sound and Vibration Measurement Suite. If you already have the System Identification Toolkit 3.0.0 installed, you must uninstall any of the following software that you have installed: Sound and Vibration Toolkit or Sound and Vibration Measurement Suite, System Identification Toolkit, Control Design Toolkit, and LabVIEW SignalExpress. You then can install the System Identification Toolkit 3.0.1. Refer to ni.com for information about obtaining the System Identification Toolkit 3.0.1 upgrade CD.
    • You lose the buffered data of a colormap, speed profile, XY graph, or waterfall graph if you switch from Playback mode to Monitor / Record mode and then switch back to Playback mode.
    • When you export colormap or waterfall graph data to an Excel spreadsheet, you might lose some of the data if you use Microsoft Excel 2003 or earlier. Microsoft Excel 2003 has a maximum limit of 256 columns for a worksheet.
    • (Windows Vista) If you install the Sound and Vibration Measurement Suite 6.0 or Sound and Vibration Toolkit 6.0 with LabVIEW 8.2.1, and you have LabVIEW 8.5 installed, you cannot generate LabVIEW block diagram code from the Sound and Vibration Assistant. Refer to the Knowledge Base (4BAC1SUK) at ni.com for a workaround.
    The following table lists the bugs fixed in the Sound and Vibration Assistant 6.0.
    Bug IDFixed Issue
    47FC1MK9Fixed the code generation templates issue so that calibration example projects can be converted to executable LabVIEW VIs.
    46JFUHW9
    4579QD00
    Fixed an issue where the Zoom Power Spectrum step does not coerce number of lines. This step now supports zoom frequency resolutions finer or coarser than the baseband frequency resolution.
    497CM8W9Fixed an issue where the Save to UFF58 step writes converted unit string to Record 9 when dB spectrum is converted to linear spectrum.
    4BFCKEUCK
    46LEHQYV
    Fixed an issue where Sound and Vibration Assistant and SignalExpress cannot be installed to two different versions of LabVIEW on the same target machine.
    GMT+8, 2025-12-8 07:36
