查看: 1433|回复: 0
[NI软件产品] NI Analog Waveform Editor 1.1 Win32Eng NI模拟波形编辑器1.1
    9 小时前
     楼主| 发表于 2023-5-9 15:23:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Analog Waveform Editor可帮助您创建模拟波形。
    Analog Waveform Editor是一款软件工具,可打开并重新采样以二进制、ASCII或LabVIEW Measurement(.lvm)文件格式保存的数据文件,进而创建、导入、查看或编辑现有波形。该工具可通过加、减、乘、除运算合并波形,并提供一个包含20多个内置波形基元的库,可帮助用户创建新波形。您还可以通过输入数学表达式来创建新波形。此外,Analog Waveform Editor可与NI波形发生器、多功能I/O和模拟输出硬件无缝集成。
    发布日期:2004/9/22
    包含的版本:1.1完整版
    Windows 2000
    Windows XP 32-bit
    Windows Vista
    语言:英文English
    应用程序位数:32位
    文件名: AWE110.zip
    文件大小: 124956833 字节 (119.17 MB)
    修改日期: 2023-05-09 10:20
    MD5: 985b4e87675e21329cd2c7f4caa4a2b7
    SHA1: 2cefd486c56050fc471fb885d15c15183ec7d8fb
    SHA256: ab6fd827a037b48eb86619d095111b4d6c72fb1d1964a92347f40167c67ae1e3
    CRC32: e96cad70
    请注册登录机器视觉论坛会员,购买附件查看下载地址
    AWE1.1.txt (373 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Analog Waveform Editor Version 1.1 Readme
    CVI™, LabVIEW™, National Instruments™, NI™, and NI-DAQ™ are trademarks of National Instruments Corporation.
    Product and company names mentioned herein are trademarks or trade names of their respective companies.
    © 2004 National Instruments Corporation. All rights reserved.
    Thank you for using the NI Analog Waveform Editor (AWE). This document contains important information regarding the NI Analog Waveform Editor and is organized into the following sections:
    • System Requirements
    • Uninstalling NI Analog Waveform Editor
    • Examples
    System RequirementsMinimum System Requirements
    • Processor: Pentium III 600 MHz or equivalent
    • RAM: 128 MB
    • A screen resolution of 800×600 with 256 colors
    Recommended System
    • Processor: Pentium III/Celeron 1 GHz or equivalent
    • RAM: 256 MB
      • Windows 2000
      • Windows NT 4.0 SP6A
      • Windows XP
    The NI Analog Waveform Editor is installed by default in the /Analog Waveform Editor directory.
    The installer also installs NI Hierarchial Waveform Storage (NI-HWS), which you can use to programmatically load the files saved by NI Analog Waveform Editor. For more information about using NI-HWS with files created or modified by the NI Analog Waveform Editor, refer to the NI Analog Waveform Editor Help, which you can access at Start»Programs»National Instruments»Analog Waveform Editor.
    Uninstalling the NI Analog Waveform Editor
    For Windows 2000/NT/XP, complete the following steps:
    • Launch the Control Panel from the Start»Settings menu.
    • Double-click Add/Remove Programs.
    • Click Change or Modify.
    • Select NI Analog Waveform Editor 1.1.
    • Click Uninstall.
    Examples
    The NI Analog Waveform Editor installs examples of how to use saved waveforms with NI-DAQmx in both LabVIEW and LabWindows/CVI. Example waveforms are also installed and can be loaded into the NI Analog Waveform Editor.
    LabVIEW NI-DAQmx examples are installed in the \Examples\LabVIEW directory.
    LabWindows/CVI NI-DAQmx examples are installed in the \Examples\CVI directory.
    NI Analog Waveform Editor example waveforms are installed in the \Examples\Waveforms directory.
    GMT+8, 2025-12-8 19:07
