查看: 1165|回复: 0
[NI软件产品] NI Analog Waveform Editor 1.2.1 Win32Eng NI模拟波形编辑器1.2.1
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2023-5-9 15:27:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Analog Waveform Editor可帮助您创建模拟波形。
    Analog Waveform Editor是一款软件工具,可打开并重新采样以二进制、ASCII或LabVIEW Measurement(.lvm)文件格式保存的数据文件,进而创建、导入、查看或编辑现有波形。该工具可通过加、减、乘、除运算合并波形,并提供一个包含20多个内置波形基元的库,可帮助用户创建新波形。您还可以通过输入数学表达式来创建新波形。此外,Analog Waveform Editor可与NI波形发生器、多功能I/O和模拟输出硬件无缝集成。
    发布日期:2007/5/14
    包含的版本:1.2.1完整版
    Windows 7
    Windows 2000
    Windows XP 32-bit
    Windows Vista
    语言:英文English
    应用程序位数:32位
    文件名: AWE121.exe
    文件大小: 228615264 字节 (218.02 MB)
    修改日期: 2023-01-21 09:52
    MD5: 1a15e309a8a4f3378ccaf0606711ee62(官方正确)
    SHA1: 0a40be9bf10766ff4c100323157a66ebe24197b9
    SHA256: 76a6e123f36c5fe0f09736dd6803d663da0ae8cec727e0dc960e0a4b1a75205f
    CRC32: cf305aa2
    请注册登录机器视觉论坛会员,购买附件查看下载地址
    AWE1.2.1.txt (510 Bytes, 下载次数: 0, 售价: 10 元)
    NI Analog Waveform Editor™ Readme
    Version 1.2.1
    April 2007
    Thank you for using the NI Analog Waveform Editor. This document contains important information regarding the NI Analog Waveform Editor and is organized into the following sections:
    • New Features in Version 1.2.1
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying the NI Analog Waveform Editor
    • Known Issues
    • Support for Windows Vista. For more information about Microsoft Windows Vista and NI products, refer to ni.com/vista.
    System RequirementsMinimum System Requirements
    • Processor: Pentium III 600 MHz or equivalent
    • RAM: 128 MB
    • A screen resolution of 800×600 with 256 colors
    Recommended System
    • Processor: Pentium III/Celeron 1 GHz or equivalent
    • RAM: 256 MB
      • Windows Vista
      • Windows XP
      • Windows 2000
    Installed File Names and LocationsSoftware
    The NI Analog Waveform Editor is installed by default in the Program Files\National Instruments\ directory. The Analog Waveform Editor is also accessible from Start»Programs»National Instruments»Analog Waveform Editor.
    The installer also installs NI Hierarchical Waveform Storage (NI-HWS), which you can use to programmatically load the files saved by NI Analog Waveform Editor. NI-HWS is installed by default in the Program Files\National Instruments\ directory. NI-HWS is also accessible from Start»Programs»National Instruments»NI-HWS.
    For more information about using the NI Analog Waveform Editor, refer to the NI Analog Waveform Editor Help (installed in the Program Files\National Instruments\\Documentation directory and accessible from Start»Programs»National Instruments»Analog Waveform Editor).
    Examples
    The NI Analog Waveform Editor installs examples of how to use saved waveforms with NI-DAQmx in both LabVIEW and LabWindows/CVI. Example waveforms are also installed and can be loaded into the NI Analog Waveform Editor.
    FilesInstallation Location on Windows XP/2000Installation Location on Windows Vista
    LabVIEW NI-DAQmx examplesDocuments and Settings\All Users\Documents\
    Examples\LabVIEW
    Users\Public\Documents\
    \Examples\LabVIEW
    LabWindows/CVI NI-DAQmx examplesDocuments and Settings\All Users\Documents\
    Examples\CVI
    \Examples\CVI
    NI Analog Waveform Editor example waveformsDocuments and Settings\All Users\Documents\
    Examples\Waveforms
    \Examples\Waveforms
    For Windows XP/2000, complete the following steps:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI Analog Waveform Editor 1.2.1 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any Analog Waveform Editor operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    • If you install the Analog Waveform Editor on a computer that contains paths with multi-byte characters (as in some non-English operating systems), the licensing evaluation period may expire immediately. If this occurs, you will need to activate the product using a valid serial number in order to use the Analog Waveform Editor. If you are using an evaluation copy, you will need to purchase the AWE to obtain a serial number. For more information on activating your software, launch the Analog Waveform Editor Help and refer to the Activating Your Software with the NI License Manager topic.
    © 2007 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-7-23 12:10
