查看: 1543|回复: 0
[NI软件产品] LabVIEW 2013 Remote Development Target Support Win32Eng NI LabVIEW远程开发硬件支持RDTS2013
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2023-5-11 18:05:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2013 Remote Development Target Support Win32Eng NI LabVIEW远程开发硬件支持RDTS2013LVRDEV
    LabVIEW Remote Development Target Support可帮助您在远程NI硬件上开发、运行、调试和部署LabVIEW VI。
    LabVIEW Remote Development Target Support是一个驱动软件,用于支持运行Windows Embedded Standard操作系统的NI硬件。您可以在主机上使用LabVIEW开发、运行和调试Windows Embedded Standard硬件上的VI。您可以使用主机内置的安装程序将VI部署到Windows Embedded Standard硬件上。
    发布日期:2013/08/5
    包含的版本:2013,13.0.0
    受支持的操作系统
    Windows Embedded
    语言:英语
    应用程序位数:32位
    文件大小: 421782304 字节 (402.24 MB)
    修改日期: 2023-05-11 16:51
    MD5: f40c74a285bde72713ff312bddb9f479
    SHA1: 7c36a8c519e17975a2a80aa196cdb638241c8b2b
    SHA256: 7b09180298984a0284d195062f1527716f856168c663701f6d193faafebfddf4
    CRC32: 9746ef85
    百度网盘下载和NI官方下载地址:
    请注册登录视觉论坛账号,购买附件查看下载地址,充值请联系在线客服
    LVRDEV2013.txt (433 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW 2013 Remote Development Target Support Readme
    Version 13.0.0
    June 2013
    This file contains important information about NI LabVIEW Remote Development Target Support, including installation instructions, configuration instructions, troubleshooting, and known issues.
    Remote Development Requirements
    Enabling LabVIEW Remote Development
    Troubleshooting Guide
    NI LabVIEW Remote Development Target Support enables you to develop, run, and debug LabVIEW VIs on National Instruments hardware running the Windows Embedded Standard operating system. You develop, run, and debug the VIs on the Windows Embedded Standard target from a host computer with the LabVIEW Development System. The following National Instruments hardware is supported:
    • NI cRIO-9081
    • NI cRIO-9082
    LabVIEW Remote Development Target Support has system requirements for the host computer and target.
    Host ComputerTarget
    The host computer must meet the following system requirements:
    • LabVIEW Professional Development System (32-bit)
    • Additional drivers required for your application.
      Note  The version of drivers you install on the host computer and target must match.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the LabVIEW Development System.
    The target must meet the following system requirements:
    • Windows Embedded Standard 7 operating system
    • LabVIEW Remote Development Target Support, which installs the LabVIEW Run-Time Engine. The version of the LabVIEW Run-Time Engine matches the version of LabVIEW Remote Development Target Support.
      Note  The version and bitness of the LabVIEW Development System on the host computer must match the version and bitness of the LabVIEW Run-Time Engine on the target.
    If you purchased National Instruments hardware running the Windows Embedded Standard operating system on or after August 2013, your hardware comes pre-installed with LabVIEW Remote Development Target Support.
    If you purchased National Instruments hardware running the Windows Embedded Standard operating system prior to August 2013, you can install LabVIEW Remote Development Target Support and additional software by downloading the installer from the National Instruments website.
    LabVIEW Remote Development Target Support Updates and Notifications
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter info code updates to access this information.
    After installing LabVIEW Remote Development Target Support on the target, the target must meet the following requirements before you can develop applications remotely from a host computer:
    • A user with administrator privileges is logged into the target.
    • LabVIEW Remote Development is enabled on the target.
    Complete the following steps to enable LabVIEW Remote Development on the target. You must restart and log into the target for changes to take effect.
    Note  By default, LabVIEW Remote Development is enabled if you manually install LabVIEW Remote Development Target Support. If the target comes pre-installed with LabVIEW Remote Development Target Support, you must complete the following steps.
    • Right-click the NI MAX icon on the desktop and select Run as administrator.
    • Select My System in the configuration tree if it is not selected.
    • On the Settings page, ensure that LabVIEW Remote Development in the Remote Development Settings section contains a checkmark.
      Note  Ensure that the Run-Time Engine Version matches the version and bitness of the LabVIEW Development System on the host computer.
    • Ensure the Startup Type in the RIO Service Settings section specifies Automatic to use FPGA on the target remotely.
    • Click Save and restart the target. You must log into the target for changes to take effect.
    The target is now enabled for remote development. Refer to the Fundamentals»Working with Projects and Targets»Concepts»Working with Windows Embedded Standard Targets topic on the Contents tab of the LabVIEW Help for more information about developing applications on Windows Embedded Standard targets.
    Target Security
    National Instruments recommends that you disable LabVIEW Remote Development after deploying applications to targets that are not used for development. To disable LabVIEW Remote Development, complete the following steps.
    • In the Remote Development Settings section of the System Configuration page, remove the checkmark from LabVIEW Remote Development.
    • In the RIO Service Settings section, specify Manual or Disabled for the Startup Type.
    • Restart the target for changes to take effect.
    Refer to the NI Developer Zone at ni.com for more information about security when developing and deploying applications to a target remotely.
    Use the following table to find solutions when using LabVIEW Remote Development Target Support and developing applications on a Windows Embedded Standard target.
    IssueSolution
    I cannot discover my target in Measurement & Automation Explorer (MAX) on the host computer.On the host computer, MAX does not support discovering Windows Embedded Standard targets.
    I cannot discover the target in the LabVIEW Development System using the Add Targets and Devices dialog box.Ensure that the target meets the requirements necessary to discover a device for remote development:
    I cannot connect to the target in a LabVIEW project, although I can discover the target using the Add Targets and Devices dialog box.Ensure that the version and bitness of the LabVIEW Run-Time Engine on the target match the version and bitness of the LabVIEW Development System on the host computer.
    How do I verify that LabVIEW Remote Development is enabled on my target?Launch MAX and select My System in the configuration tree. In the Remote Development Settings section of the System Configuration page, ensure that LabVIEW Remote Development contains a checkmark.
    How do I determine the version of the LabVIEW Run-Time Engine enabled for remote development on the target?Launch MAX and select My System in the configuration tree. In the Remote Development Settings section of the System Configuration page, refer to the Run-Time Engine Version. Ensure that the version and bitness match the version and bitness of the LabVIEW Development System on the host computer.
    How do I verify that the LabVIEW Remote Development application is running on the target?Launch the Windows Task Manager. In the Processes page, verify that the list of processes contains niLVRemoteDev.exe. If the list does not contain niLVRemoteDev.exe, you must restart the LabVIEW Remote Development application.
    How do I restart the LabVIEW Remote Development application?Restart the target or select Start»All Programs»Startup»NI LabVIEW Remote Development.
    Windows Firewall blocked the LabVIEW Remote Development application. What should I do?You must authorize the LabVIEW Remote Development application to allow access through the Windows Firewall.
    Can I automatically log into the target?You can configure automatic logon to the target.
    Can I configure remote development settings for my target from the host computer?From the host computer, you can configure remote development settings by completing the following steps:
    • On the host computer, open a Web browser and enter the following URL to access the NI Web-Based Monitoring & Configuration page: http://localhost:3582.
    • Click Network Browser on the left and double-click the row that contains your target. The NI Web-Based Monitoring & Configuration page for your target opens in a Web browser.
    • Click Login in the top-right corner of the page.
    • Enter Admin in the User name field.
    • Leave the Password field blank. The default password is blank. Set the password to establish security.
    • Click OK.
    • On the System Configuration page, configure the remote development settings for your target.
    • Click Save to save changes.
    • Click Restart in the top-right corner of the page to restart the target. You must log into the target for changes to take effect.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in LabVIEW Remote Development Target Support.
    Refer to the Fundamentals»Working with Projects and Targets»Concepts»Working with Windows Embedded Standard Targets topic on the Contents tab of the LabVIEW Help for more information about developing applications on Windows Embedded Standard targets. The LabVIEW Help is accessible by selecting Help»LabVIEW Help from the LabVIEW Development System on the host computer.
    Important Information
    © 2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-6 05:07
