查看: 1461|回复: 0
[NI驱动程序] NI-RF Device Drivers 2013 Win32/64Eng/Jpn NI-RF设备驱动程序13.0
    14 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2023-5-14 14:45:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RIO Device drivers 2013 Win32/64Eng/Jpn NI-RIO设备驱动程序13.0
    • NI-RFSA 2.7
    • NI-RFSG 1.9
    • Instrument Design Libraries
      • NI PXIe-5644R/5645R Instrument Design Libraries 2012.1
    • Toolkits:
      • Modulation Toolkit:
        • NI LabVIEW Modulation Toolkit 4.3.3
        • NI LabWindows/CVI Modulation Toolkit 4.1
      • Spectral Measurements Toolkit:
        • NI LabVIEW Spectral Measurement Toolkit 2.6.3
        • NI LabWindows/CVI Spectral Measurement Toolkit 2.6.3
    文件名: NI-RF Device Drivers 2013.iso
    文件大小: 4740417536 字节 (4.41 GB)
    修改日期: 2013-09-23 17:12
    MD5: dae66fba0c4ac25f1625154297657f9d
    SHA1: c79f2c563c8ccb0fe290fcf7fca06d959cd93af0
    SHA256: 7bb948f5c7ebd3d83c7603e9d6d49ae99d42e518f086d156413704988c5376d6
    CRC32: 0440e9b2
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RF设备驱动2013.txt (816 Bytes, 下载次数: 0, 售价: 20 圆)
    National Instruments RF Device Drivers ReadmeApril 2013RF Device Driver Readme Files
    To help you decide which software to install, refer to the following descriptions:
    NI-RSFG 1.9—This software installation provides support for customers using NI RF signal generators or the RF output subsystem of vector signal transceivers (VSTs). To program the NI RF signal generator or NI RF VST, use the NI-RFSG API. The getting started guide for your device provides information about how to install, configure, test, and begin using an NI RF signal generator or vector signal transceiver.
    Modulation Toolkit (LabVIEW and LabWindows/CVI)—This software installation provides additional modulation scheme software functionality for customers using NI RF vector signal generators, NI arbitrary waveform generators, NI RF vector signal analyzers, and NI high-speed digitizers.
    When you insert the driver software DVD, the NI RF Device Drivers window appears. In this window, click Install RF Driver Software to begin installation. If the NI RF Device Drivers window does not appear, launch autorun.exe from the root directory of the driver software DVD.
    • Windows 8 (32-bit and 64-bit) *
    • Windows Server 2003 R2 (32-bit) **
    • Windows Server 2008 R2
    ** Visit KnowledgeBase 54D9I6M6 for additional information about known issues using National Instruments driver software on Windows Server 2003 R2 (32-bit).
    Refer to your product-specific readme file for additional requirements.
    Uninstallation Instructions
    • For more information about silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
    Windows 8 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar.
    Windows 8 DesktopStart screenRight-click application and select Pin to Start.
    Windows 8 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen.
    Finding All Programs
    GMT+8, 2026-4-8 22:48
