查看: 1389|回复: 0
[NI软件套件] NI Battery Test System Software 2023 Q2 x64Win10 64bitEng 电池测试系统软件套件BTSS23.0.0
    昨天 09:54
  • 签到天数: 3808 天
     楼主| 发表于 2023-8-16 10:19:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    电池测试系统软件可帮助您使用电池测试系统硬件创建和执行测试。
    电池测试系统软件是一款应用程序软件,其可用于创建用于电池测试的软件架构并优化电池测试工作流程。该软件包括针对电池测试应用程序的附加软件、设备驱动程序、示例和分析IP,可与电池测试系统硬件配合使用。此外,该电池测试系统软件还包括TestStand和VeriStand软件。
    发布日期:2023/4/29
    包含的版本:23.0.0完整版
    文件大小: 14067828736 字节 (13.10 GB)
    修改日期: 2023-04-29 09:53
    MD5: 529ac0874b8909e5d3c3675d07498e30
    SHA1: a3a3d175130d90b5a9e9d8be03a9dedce9bae28e
    SHA256: b92eca537b2a1a93f1a81c2bd7c1f032ee1e1b2e1f21bfddbaacd36edaee78f0
    CRC32: 46d58707
    请注册登录视觉论坛账号,购买附件查看下载地址
    Battery Test System Software Suite2023Q2.txt (653 Bytes, 下载次数: 0, 售价: 30 圆)
    Battery Test System Software 2023 Q2 Readme
    April 2023
    This file contains important information about Battery Test System Software 2023 Q2.
    Refer to the Battery Test System Software Release Notes for additional information about this release, such as known issues and bugs fixed since the last release.
    Refer to the Battery Test Software User Manual for more information about using the Battery Test System software.
    Included Components
    Battery Test System Software is a collection of NI software for developing, executing, debugging, and deploying test programs to an NI Linux Real-Time CompactRIO target in the Battery Test System measurement rack.
    Battery Test System Software 2023 Q2 includes the following new feature:
    • Added support for the Battery Test System Software Toolkit 2023 Q2
    Included Components
    Battery Test System Software 2023 Q2 includes the following major components:
    • Required Components:
      • TestStand 2021 (64-bit)
      • VeriStand 2021
      • Battery Test System Software Toolkit 2023 Q2
        • SystemLink Client 2022 Q1 Patch 2
        • NI SystemLink Test Monitor Support for TestStand 2021 (64-bit)
      • NI-DAQmx 21.3.0
      • NI CompactRIO 21.0.0
      • NI Industrial Communications for EtherCAT 21.5.0
      • NI-VISA 21.5.0
      • NI-XNET 21.5.0
      • NI-SLSC 21.3.0
      • NI R Series Multifunction RIO 21.5.0
      • NI GPIB-Serial Converter 19.0.0
    • Optional Components:
      • LabVIEW 2021 SP1 (64-bit)
      • NI-Sync 21.3
    • LabVIEW is not included in the Battery Test System Software license.
    • You must have a dedicated SystemLink server. Refer to the Battery Test System User Manual for more information.
    • Several VeriStand Custom Devices are also installed with the Battery Test System Software Toolkit. Refer to the Battery Test System Software Toolkit Readme for more information.
    Battery Test System Software supports Windows 10 (64-bit).
    Download the Battery Test System Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Use the serial number that is listed on the Certificate of Ownership that shipped with your system to activate VeriStand, TestStand, NI-VCOM, and the Battery Test System Software Toolkit.
    • For more information on Battery Test System Software activation, refer to Activating a Product.
    • You can also install the Battery Test System Software Toolkit separately from ni.com/downloads. You can deselect items for installation, however the default selected items are required to use the Battery Test System Software Toolkit. If you do not currently have a license for VeriStand and TestStand, NI recommends that you use the default installation process using the evaluation period to obtain the appropriate license.
    • Refer to the Battery Test System User Manual for more information about installing and configuring your software.
    Refer to the following documents to learn more about the Battery Test System, Battery Test System Software, Battery Test System Server Software, and measurement rack. You can find these documents online at Battery Test System Documentation.The content available there includes the following:
    • Battery Test Software User Manual. Covers Battery Test System software setup, configuration, and usage.
    • Battery Test Hardware User Manual. Covers site preparation and uncrating instructions, hardware reference information, as well as maintenance and service procedures.
    • BTS-16101 Battery Test System Measurement Rack Specifications. Lists the technical specifications for the Battery Test System.
    • BTS-16101 Battery Test System Measurement Rack Safety, Environmental, and Regulatory Information. Details important compliance precautions and connection information for your measurement rack.
    • Battery Test System Server Software Readme. Provides installation instructions, system requirements, and other information for the Battery Test System Software Toolkit.
    • Battery Test System Software Toolkit Readme. Provides installation instructions, system requirements, and other information for Battery Test System Software Toolkit.
    © 2020–2023 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-26 06:12
