查看: 1936|回复: 0
[NI驱动程序] NI-VISA 2023 Q3 Win11 64bitEng 美国国家仪器虚拟仪器软件架构NI-VISA23.5驱动下载
  • 签到天数: 3792 天
    连续签到: 43 天
     楼主| 发表于 2023-8-30 08:59:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    NI-VISA 2023 Q3
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版,版本号23.5.0
    语言:英文English
    文件大小: 1613305856 字节 (1.50 GB)
    修改日期: 2023-07-19 10:03
    MD5: 593a7c226dee257b150a44d23a779868
    SHA1: 89c9fbcdfc47381ca48b273a9de71b369aaf2626
    SHA256: c59db6445a751471aba8f62b2bf283f51792d97104e30e3346f17aaf4e085483
    CRC32: c2121e1d
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    VISA2023Q3.txt (514 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-VISA 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-VISA 2023 Q3.
    • NI-VISA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-VISA Documentation: Detailed documentation about how to use your product
    NI-VISA is the NI implementation of the Virtual Instrument Software Architecture (VISA), a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, VXI, PXI, Serial, Ethernet, and/or USB interfaces.
    NI-VISA 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time
    While this distribution targets all of these platforms, you can run setup.exe only on the Windows variants.
    Visit NI Hardware and Software Operating System Compatibility and NI-VISA Features and OS Compatibility pages to view supported operating systems for different releases and feature support for various operating systems.
    NI-VISA 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-VISA 2023 Q3
    LabVIEW2020 SP1 and later
    Measurement Studio2019 and later
    If you are using the IVI-compliant NI-VISA .NET Class Library, the .NET 4.6.2 Framework (minimum) is required. You can use the NI-VISA .NET Class Library with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET 4.0 Framework or later. You can use the NI-VISA .NET Class Library in 32-bit or 64-bit applications.
    Microsoft Visual Studio Support for the VisaNS .NET Class Library
    Note: The Measurement Studio VisaNS .NET Class Library is being deprecated and superseded by an IVI-compliant NI-VISA .NET Class Library.
    Download the NI-VISA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Before you install NI-VISA 2023 Q3, NI recommends that you uninstall any versions of VISA prior to NI-VISA 2.0.1.
    Note: The NI-VISA installer does not notify that a reboot is required on NI Linux® Real-Time targets. After installation, the NI Linux® Real-Time target must be restarted for the NI-VISA Server to start.
    After uninstalling NI-VISA, some DLLs and executables may remain in the NI-VISA directories. To complete the uninstall process, you must restart your machine.
    Note: The uninstaller application does not notify you when rebooting is necessary. If you plan to reinstall NI-VISA, you always should reboot the machine after running the uninstaller.
    The "NI-VISA Support for LabVIEW" package supports applications using NI-VISA ​with LabVIEW 2022 or later. When installing NI-VISA, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    Agilent/HP Controller Support
    NI-VISA now works with Agilent/HP GPIB and VXI controller cards. To use this feature, go into MAX, select Tools»NI-VISA»VISA Options, choose the Passports tab, and enable the NiVisaTulip.dll Passport. NI-VISA automatically finds and accesses any GPIB or VXI devices. However, NI-VISA does not configure the Agilent/HP hardware; you still must do that with the Agilent/HP I/O Config utility.
    If you have both NI and Agilent/HP controllers in the same system, you must configure the cards at different system addresses, such as GPIB0 and GPIB1. If both vendors try to use the same interface address, NI-VISA reports an error from viFindRsrc or VISA Find Resources.
    Creating and Digitally Signing Catalog Files
    (Windows 10 or higher) If you generate an INF file using the NI-VISA Driver Wizard, you must create and digitally sign a Windows Catalog (.cat) file before you can install the INF file on a Windows 10 (or higher) machine. For more information about digitally signing a .cat file for Windows 10 (or higher), visit ni.com/r/infwin8.
    For more information about creating and signing catalog files, please refer to Creating a Catalog File for Test-Signing a Driver Package.
    Refer to the NI-VISA documentation, accessible from LabVIEW by selecting Help>>LabVIEW Help, for information about the NI-VISA.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-VISA are located in the labview\examples\Instrument IO\VISA directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    NI-VISA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-2-3 10:53
