查看: 1145|回复: 0
[NI驱动程序] NI-SWITCH 2023 Q3 Win11 32/64bitEng/Jpn NI开关产品驱动程序23.5下载
     楼主| 发表于 2023-8-31 09:17:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH 2023 Q3
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版,版本号23.5.0
    语言:英语,日语
    文件大小: 2433368064 字节 (2.27 GB)
    修改日期: 2023-07-19 09:57
    MD5: f6d0f3a0fff98bf7789adec58dfbfed8
    SHA1: 3c6dbbd3aa0214df025f8750effd32b0c120581f
    SHA256: 6a198c903a835913bec34c88c748c216701e4306858c8bf6086b6d3953653ab9
    CRC32: 71cc6610
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    SWITCH2023Q3.txt (522 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-SWITCH 2023 Q3.
    • NI-SWITCH Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SWITCH Documentation: Detailed documentation about how to use your product
    Include this section if your product supports Phar Lap ETS. NI no longer supports Phar Lap ETS Real-Time Operating System
    NI-SWITCH 2023 Q3 has the following requirements:
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    NI-SWITCH 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time
    NI-SWITCH 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-SWITCH 2023 Q3
    LabVIEW2020 and later
    LabVIEW Real-Time Module 32-bit2020 and later
    LabVIEW Real-Time Module 64-bit2021 and later
    LabWindows™/CVI™ Real-Time Module2019 and later
    If you are using the NI-SWITCH .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-SWITCH 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Python Support
    For more information on installing and using the NI-SWITCH Python API, refer to the niswitch module.
    Download the NI-SWITCH installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "NI-SWITCH Support for LabVIEW" package supports applications using NI-SWITCH ​with LabVIEW 2022 or later. When installing NI-SWITCH, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    Refer to the NI-SWITCH documentation, accessible from Start»National Instruments»NI-SWITCH»NI-SWITCH Documentation, for information about the NI-SWITCH.
    You can access all the installed NI-SWITCH examples at Start»National Instruments»NI-SWITCH»NI-SWITCH Examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SWITCH are located in the labview\examples\instr\niSwitch directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate examples by task at Hardware Input and Ouput»Modular Instruments»NI-SWITCH or by directory structure at instr»niSwitch.
    • Click the Search tab to search all installed examples by keyword. For example, search for "SWITCH" to locate all NI-SWITCH examples.
    NI-SWITCH no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI No Longer Supports Phar Lap ETS Real-Time Operating SystemInclude this section if your product supports Phar Lap ETS.
    GMT+8, 2025-12-8 08:25
