Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio Win11 64bitEng 用于NI InstrumentStudio的半导体设备控制附加软件23.3.0
InstrumentStudio的半导体设备控制附加软件提供了交互式的设备控制功能,可通过快速缩放来实现自动验证。
InstrumentStudio半导体设备控制附加软件是一个软件附加软件,可帮助您使用I2C、SPI或RFFE等标准数字协议或自定义协议来执行交互式寄存器读/写操作。您可以保存InstrumentStudio项目或导出设置,以便在LabVIEW、Python、.NET或TestStand中进行自动验证。InstrumentStudio可以与自动化应用程序并行使用,来实时监测和调试设备控制任务。InstrumentStudio的半导体设备控制附加软件也可与I2C/ SPI接口设备和PXI数字码型仪器配合使用,帮助您在执行交互式和自动化半导体验证时轻松完成常见的任务。
用于InstrumentStudio的半导体设备控制附加软件2023Q2
发布日期:2023/5/18
包含的版本:2023 Q2专业版、基本版 版本号23.3.0
文件大小: 518375424 字节 (494.36 MB)
修改日期: 2023-05-18 09:50
MD5: 4b456576475b670603640b3e19b3f7af
SHA1: 3ef1fff3aad810d9d6d877c8378e64796adb2ddf
SHA256: a0ea4a105815fd4034c6a98b795183ca942616c205153e65bf18f1bc29cf9348
CRC32: 9039c36f
请注册登录视觉论坛账号,购买附件查看下载地址
半导体设备控制附加软件2023Q2.txt
(574 Bytes, 下载次数: 0, 售价: 10 圆)
Semiconductor Device Control Add-On for InstrumentStudio 2023 Q2 ReadmeMay 2023 This file contains installation instructions and compatibility information for the Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio. You can find more release information on ni.com. - Semiconductor Device Control Add-On for InstrumentStudio Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- Semiconductor Device Control Add-On for InstrumentStudio Documentation: New features, behavior changes, and other documentation
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Supported Hardware and Functions Accessing the Documentation Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Unsupported Windows Operating Systems Legal Information OverviewThe Semiconductor Device Control Add-On for InstrumentStudio is a software add-on that helps you perform interactive register read/write operations using common or custom digital protocols. This InstrumentStudio add-on supports general hardware control tasks using static I/O and can be used in parallel with automated applications to monitor and debug device control tasks in real time. System RequirementsThe Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio has the following requirements: - Pentium 4 G1 equivalent or later (Intel i5 equivalent or later recommended)
- At least 10 GB of disk space
- 4 GB RAM
- 1024 x 768 screen resolution (1366 x 768 or higher recommended)
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2020 SP1 or later. Supported Operating SystemsThe Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio supports the following operating systems: - Windows 11 (64-bit only)
- Windows 10 (64-bit only)
Note The Semiconductor Device Control Add-On for InstrumentStudio no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Application Software SupportThe Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by the Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio | | InstrumentStudio | 2023 Q2 (64-bit only) | | LabVIEW | 2020, 2021, 2021 SP1, 2022 Q3, 2023 Q1 (all 64-bit only) | | TestStand | 2020, 2021, 2022 (all 64-bit only) | | Python | 3.6 to 3.9 (all 64-bit only) | | .NET framework | 4.6.2 or later (all 64-bit only) |
Device Drivers | Minimum Version Supported by the Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio | | NI-Digital Pattern Driver | 20.6.2 (64-bit only) | | NI-845x Driver Support | 20.0 (64-bit only) | Microsoft Visual Studio SupportIf you are using the Semiconductor Device Control Add-On for InstrumentStudio .NET Class Library, .NET Framework 4.0 (minimum) is required. The Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software. The Semiconductor Device Control Add-On for Visual Studio extensions support all Visual Studio 2019 and 2022 editions. Installation InstructionsDownload the Semiconductor Device Control Add-On for InstrumentStudio installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Before starting the installation, close all running Visual Studio and VSIX files. If these files are running when the Semiconductor Device Control Add-On is being installed, some Visual Studio templates in the Semiconductor Device Control Add-On might not install properly.
- If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
- Use the serial number that is included with your software to activate the Semiconductor Device Control Add-On for InstrumentStudio. For more information on Semiconductor Device Control Add-On for InstrumentStudio activation, refer to NI Software Activation.
Additional Installation Requirements for the Semiconductor Device Control Add-On Professional EditionThe Semiconductor Device Control Add-On 2023 Q2 Professional for InstrumentStudio has the following additional installation requirements: - To develop a custom interface or protocol, you must install Visual Studio before installing the Semiconductor Device Control Add-On Professional for InstrumentStudio.
- To develop a PXIe-657x protocol, you must install the NI-Digital Pattern Driver before installing the Semiconductor Device Control Add-On Professional for InstrumentStudio.
After installing the Semiconductor Device Control Add-On Professional for InstrumentStudio, you must activate the Semiconductor Device Control Add-On Professional for InstrumentStudio with a valid license. You can verify the installation of the VSIX extensions in the following location: %LocalAppData%\Temp\dd VSIXInstaller*.log. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Supported Hardware and FunctionsThe following table details the hardware models and functions supported in the Semiconductor Device Control Add-On 2023 Q2 for InstrumentStudio. Hardware Models | Protocols | Channels | Custom Timings | | PXIe-6570, PXIe-6571 | I2C, I3C®, 3-wire SPI, 4-wire SPI, MIPI® RFFE | DIO, PPMU | dEVM MIPI® RFFE, dEVM SPI | | USB-8451, USB-8452 | I2C, 4-wire SPI, DIO | DIO | — | Accessing the DocumentationRefer to the Semiconductor Device Control Add-On for InstrumentStudio Manual, accessible from ni.com/docs, for information about the Semiconductor Device Control Add-On for InstrumentStudio. Finding ExamplesThe Semiconductor Device Control Add-On for InstrumentStudio includes several example projects that you can use to learn key concepts or use as a starting point for applications you create. Navigate to %Public%\Documents\National Instruments\Semi Device Control (64-bit)\Examples in File Explorer to view the example projects that are installed with the Semiconductor Device Control Add-On for InstrumentStudio. LabVIEW API ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Semiconductor Device Control Add-On are located in the labview\examples\Semi Device Control directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager documentation. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Unsupported Windows Operating SystemsThe Semiconductor Device Control Add-On for InstrumentStudio no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012/2016/2019, or any 32-bit Windows operating system. Versions of this product that ship after May 10, 2023, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. Legal InformationCopyright © 2020–2023 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
