查看: 1020|回复: 0
[NI软件产品] NI RFmx WLAN 2023 Q3 Win11 64bitENG RFmx无线局域网络23.5
    14 小时前
     楼主| 发表于 2023-9-2 14:44:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版,版本号23.5.0
    64位完整版校验和:
    文件大小: 1487515648 字节 (1.39 GB)
    修改日期: 2023-07-19 09:56
    MD5: 3d7c68cfb8bd5a4b1266da3c438a5498
    SHA1: 9779c6cdf02ed76405e4e61882121bceb10fb827
    SHA256: 4a71016f1c3b81229354a412ade15181654e34688cdcecc977079fa419f3b776
    CRC32: afea054c
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx WLAN2023Q3.txt (531 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 683937792 字节 (652.25 MB)
    MD5: 8c60d3d6a71469f98bed7931ecd1b810
    SHA1: 4a5c56f45b28ca8e010b5997119d7734a89942e2
    SHA256: 621003e91ad04694b8c814df75a3ac9a6f17279261d3ab1b521cc88e6a37ac09
    CRC32: 649a07b7
    RFmx WLAN2023Q3Runtime.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 2023 Q3 Readme
    RFmx WLAN 2023 Q3 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D3.2
    • Support for auto detection of signal in Analysis-Only Mode
    RFmx WLAN 2023 Q2 includes the following new features:
    • Support for Combined Signal Demodulation across all MIMO standards
    • Support for 802.11be Standard IEEE P802.11be/D3.0
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following is the behavior change in RFmx WLAN 2023 Q3 from RFmx WLAN 2023 Q2
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-12-8 23:37
