查看: 1004|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2023 Q3 Win11 64bitENG RFmx蜂窝测试TD-SCDMA23.5.0
    14 小时前
     楼主| 发表于 2023-9-2 15:08:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2023/7/18
    包含的版本:2023 Q3完整版/运行版,版本号23.5.0
    64位完整版校验和:
    文件大小: 1386655744 字节 (1.29 GB)
    修改日期: 2023-07-19 09:56
    MD5: 220dba4b4b50072d853f3a925bf8d92f
    SHA1: a9fa9ed482d1d1dc8462f63cce9be7416cacc839
    SHA256: 5fb2f8a8d88c32c71b835046ad140fb4a34bdd4069e74826377c87d32d741d15
    CRC32: bc345425
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2023Q3.txt (544 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 671369216 字节 (640.27 MB)
    MD5: 3ae82a1e4825cf8bcb14931dcedda453
    SHA1: 1b489bcf87564018ad8d2a13413f0cfdded4d52d
    SHA256: f40117931c25cb29c91f7e20cce9906e8fae35c2ab3404b82ccb1129ddadff72
    CRC32: ce74f685
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA2023Q3Runtime.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx TD-SCDMA 2023 Q3 Readme
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    GMT+8, 2025-12-8 23:37
