NI RFmx GSM/EDGE+ 2023 Q4 Win11 64bitEng GSM/EDGE/EDGE Evolved蜂窝测试软件23.8
RFmx GSM/EDGE+
发布日期:2023/10/11
包含的版本:2023 Q4完整版/运行版,版本号23.8.0
64位完整版校验和:
文件大小: 1380528128 字节 (1.29 GB)
修改日期: 2023-10-12 09:45
MD5: 0e933f020384a53114bc78ace77b61d2
SHA1: 9ddc2117d5c48fc23fa325c3d88bca7b0e44886d
SHA256: 1398ba31eaf476a3bd094c2af29926eb8211055982f9aa0a067a984eeb4f2ce6
CRC32: 82b42bea
NI官方下载和百度网盘下载地址:
请注册登录视觉论坛账号,购买附件查看下载地址
RFmx GSM 2023 Q4.txt
(533 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 667027456 字节 (636.13 MB)
MD5: ce2298b5734813a08bb87631f0ad4c4a
SHA1: 45e3132eda0b391da959de7feb6ea302c6722168
SHA256: 9bd30811934fac53e2b9ca274d4e0ffdee25735869c8d251c9a5caf6a608a3d2
CRC32: 5ec9f448
NI官方下载和百度网盘下载地址:
RFmx GSM 2023 Q4 Runtime.txt
(566 Bytes, 下载次数: 0, 售价: 5 圆)
RFmx GSM 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx GSM, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx GSM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx GSM Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx GSM 2023 Q2 includes the following new feature: - Speed improvements for Composite and Spectral measurements
RFmx GSM 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
RFmx GSM 2022 Q4 includes the following new features: - Support for PXIe-5842
- Support for configurable RBW in PVT measurement.
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx GSM has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx GSM 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx GSM no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx GSM 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx GSM 2023 Q3 to an unsupported OS. Additionally, after installing RFmx GSM 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx GSM supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx GSM. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx GSM (64-bit only) | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx GSM .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx GSM .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx GSM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx GSM. For more information on RFmx GSM activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | DLLs | | Header files | \Shared\ExternalCompilerSupport\C\include | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| .NET Class Libraries | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.GsmMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx GSM palette VIs are available from the Functions » Measurement I/O » RFmx » GSM palette. Accessing the DocumentationDocumentation for RFmx GSM is located at Start » National Instruments » RFmx GSM Documentation. Finding ExamplesYou can access all the installed RFmx GSM examples at Start » National Instruments » RFmx GSM Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx GSM 2023 Q3 from RFmx GSM 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx GSM 2022 Q4 from RFmx GSM 2022 Q3 - RFmx GSM drops support for 32-bit user mode.
The following is the behavior change in RFmx GSM 2022 Q3 from RFmx GSM 21.8.2 - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following items are behavior changes in RFmx GSM 20.7 from RFmx GSM 20.6. - Obsoleted RFmxInstr Configure Automatic SG SA Shared LO API and RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11.
