查看: 1009|回复: 0
[NI软件产品] NI RFmx Pulse 2023 Q3 Patch 2 Win11 64bitENG RFmx脉冲分析仪23.5.2
    9 小时前
     楼主| 发表于 2023-12-6 11:15:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Pulse
    RFmx Pulse可帮助您执行交互式和自动化脉冲分析测量。
    RFmx Pulse是一款测量专用软件,可扩展NI RF仪器的脉冲分析功能,例如PXI矢量信号分析仪和PXI矢量信号收发器。借助RFmx Pulse,您可以通过脉冲轮廓测量(例如时间、电平、相位和频率)以及FM线性调频调制测量和幅度和相位的脉冲稳定性测量来分析脉冲信号。
    发布日期:2023/9/12
    包含的版本:2023 Q3 Patch 2完整版/运行版,版本号23.5.2
    64位完整版校验和:
    文件大小: 1374720000 字节 (1.28 GB)
    修改日期: 2023-09-12 21:42
    MD5: 3ac2d3689ef9167063e68682f4c3dee4
    SHA1: 3cbc97ac4efe6ea1106c2e0041ac63bdfec664d6
    SHA256: 8167b7825b97e533e8c1342e4399058808f6d8587eb90c5bba372be3c2ec68c1
    CRC32: e05a2f8d
    NI官方下载和百度网盘下载地址:
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx Pulse 2023 Q3 Patch2.txt (543 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 665364480 字节 (634.54 MB)
    修改日期: 2023-09-13 21:42
    MD5: 82722c182cb41110f93b22c445aeced9
    SHA1: 32e4fb9d891dacecf3a117b832b4434d1c89e677
    SHA256: a8f6e430085949c03f4c5e527e5bcab4c67df7f1185d4fafbff238d9b8f18a00
    CRC32: 01181524
    NI官方下载和百度网盘下载地址:
    RFmx Pulse 2023 Q3 Patch2 Runtime.txt (576 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Pulse 2023 Q3 Readme
    This file contains important information about the RFmx Pulse, including system requirements, and installation instructions.
    • RFmx Pulse Release Notes: Known issues, and other notes about this release
    • RFmx Pulse Manuals: Features overview and other documentation
    Overview of Features
    RFmx Pulse 2023 Q3 includes the following features:
    • Support for Pulse profile measurement results
      • Time
        • Rise Time, Fall Time, Pulse Width and PRI
      • Level
        • Top level, Base level, ON level, Droop, Overshoot, Ripple
      • Phase and Frequency
        • Average, Deviation and Error
    • Support for FM Chirp modulation results
    • Support for Pulse Stability measurements
      • Amplitude, Phase and Total
    • Support for Segmented and Single large record in Signal Acquisition methods
    RFmx Pulse has the following requirements:
    RFmx Pulse 2023 Q3 supports the following 64-bit operating systems:
    RFmx Pulse supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Pulse. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Pulse (64-bit only)
    If you are using the RFmx Pulse .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Pulse .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Pulse installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Pulse. For more information on RFmx Pulse activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.PulseMX.Fx40.dll
    RFmx Pulse palette VIs are available from the Functions » Measurement I/O » RFmx » Pulse palette.
    Documentation for RFmx Pulse is located at Start » National Instruments » RFmx Pulse Documentation.
    You can access all the installed RFmx Pulse examples at Start » National Instruments » RFmx Pulse Examples.
    GMT+8, 2025-12-8 18:21
