查看: 1473|回复: 0
[NI软件产品] NI RFmx Pulse 2023 Q4 Win11 64bitENG RFmx脉冲分析仪23.8.0
    9 小时前
     楼主| 发表于 2023-12-6 11:18:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx Pulse
    RFmx Pulse可帮助您执行交互式和自动化脉冲分析测量。
    RFmx Pulse是一款测量专用软件,可扩展NI RF仪器的脉冲分析功能,例如PXI矢量信号分析仪和PXI矢量信号收发器。借助RFmx Pulse,您可以通过脉冲轮廓测量(例如时间、电平、相位和频率)以及FM线性调频调制测量和幅度和相位的脉冲稳定性测量来分析脉冲信号。
    发布日期:2023/10/11
    包含的版本:2023 Q4完整版/运行版,版本号23.8.0
    64位完整版校验和:
    文件大小: 1388742656 字节 (1.29 GB)
    修改日期: 2023-10-12 09:45
    MD5: 89e1a401ecd11e97a249f007f6260cfc
    SHA1: 02eaa66f5064b18d822f38c88b6284eee8761d4c
    SHA256: df8d81387efc9efb763830b1382e85d5a7b4258150c1044d75a62782451d3e5b
    CRC32: c5912ae0
    NI官方下载和百度网盘下载地址:
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx Pulse 2023 Q4.txt (535 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 676691968 字节 (645.34 MB)
    MD5: 69b7ca8f71b75b856527ca2cb78b9afc
    SHA1: c23b1120800898d40eeddeeb7640deb11b8cdb13
    SHA256: fade2f9d5c7fb57dd08ed92c4a5d38c72c1986d567f287655ed3430ca6ae5d32
    CRC32: 6f0f8064
    NI官方下载和百度网盘下载地址:
    RFmx Pulse 2023 Q4 Runtime.txt (568 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Pulse 2023 Q3 Readme
    This file contains important information about the RFmx Pulse, including system requirements, and installation instructions.
    • RFmx Pulse Release Notes: Known issues, and other notes about this release
    • RFmx Pulse Manuals: Features overview and other documentation
    Overview of Features
    RFmx Pulse 2023 Q3 includes the following features:
    • Support for Pulse profile measurement results
      • Time
        • Rise Time, Fall Time, Pulse Width and PRI
      • Level
        • Top level, Base level, ON level, Droop, Overshoot, Ripple
      • Phase and Frequency
        • Average, Deviation and Error
    • Support for FM Chirp modulation results
    • Support for Pulse Stability measurements
      • Amplitude, Phase and Total
    • Support for Segmented and Single large record in Signal Acquisition methods
    RFmx Pulse has the following requirements:
    RFmx Pulse 2023 Q3 supports the following 64-bit operating systems:
    RFmx Pulse supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Pulse. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Pulse (64-bit only)
    If you are using the RFmx Pulse .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Pulse .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Pulse installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Pulse. For more information on RFmx Pulse activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.PulseMX.Fx40.dll
    RFmx Pulse palette VIs are available from the Functions » Measurement I/O » RFmx » Pulse palette.
    Documentation for RFmx Pulse is located at Start » National Instruments » RFmx Pulse Documentation.
    You can access all the installed RFmx Pulse examples at Start » National Instruments » RFmx Pulse Examples.
    GMT+8, 2025-12-8 18:22
