查看: 1395|回复: 0
[NI驱动程序] NI-Sync 2023 Q4 Win11 32/64bitEng NI PXI同步模块及实时控制器驱动程序NI-SYNC23.8.0
     楼主| 发表于 2023-12-11 09:31:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
    NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
    NI-Sync 2023 Q4
    发布日期:2023/10/11
    包含的版本:2023 Q4完整版,版本号23.8.0
    语言:英文English
    文件大小: 2527377408 字节 (2.35 GB)
    修改日期: 2023-10-12 09:48
    MD5: 6c511a6ec0455e54c0c9c2e18fe1df44
    SHA1: 37e164f369f9276a50bdda511f79b61a91b5445a
    SHA256: 94d7d6fb091977a8e7210c21df71709009ea17ff52800fd599181b19a15c16a2
    CRC32: c710386c
    请注册登录机器视觉论坛账号,购买附件查看下载地址下载地址
    Sync 2023 Q4.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Sync 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for NI-Sync 2023 Q1.
    • NI-Sync Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Sync Documentation: New features, behavior changes, and other documentation
    NI-Sync 2023 Q1 supports the following operating systems:
    • NI Linux Real-Time (RT)1, 2
    1 Certain features are unavailable on NI Linux RT targets. Refer to NI-Sync Limitations on Linux Desktop and NI Linux Real-Time for more information about target support and functionality.
    2 IEEE 1588-2008 protocol instances on ARM-based targets running NI Linux RT are configured to be "slave only" by default. For more information about this issue, refer to Why Doesn't My ARM-Based Linux Real-Time Target Act as a 1588 Master?.
    Note NI-Sync no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    NI-Sync 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by NI-Sync
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Download the NI-Sync 2023 Q1 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    When installing NI-Sync, the "NI-Sync Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. This package supports applications using NI-Sync with LabVIEW 2022 or later.
    The NI-Sync 2023 Q1 release includes the following new features:
    • Added support for Linux DT Example Finder
    • Added support for Linux DT Hardware Configuration Utility and Reset Configuration
    The NI-Sync 2022 Q4 release includes the following new feature:
    • Added new properties for IEEE-1588 protocol
    The NI-Sync 2022 Q3 release includes the following new feature:
    • Support for LabVIEW 2022
    The NI-Sync 21.8 release includes the following new feature:
    • Support for PXI-6683H on DEB and RPM Linux desktop distributions
    Refer to NI-Sync Help, accessible from Help»LabVIEW Help..., for information about using NI-Sync with LabVIEW.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Sync are located in the \examples\instr\niSync directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • For signal-based examples that use clocks and triggers directly, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
    • For time-based examples that use time references such as IEEE 1588-2008 or GPS as a basis for synchronization, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
    NI-Sync no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux RT, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux RT, visit ni.com/r/b7g5wi.
    GMT+8, 2025-12-8 07:58
