查看: 996|回复: 0
[RTE运行引擎] NI LabVIEW 2021 SP1 f4 Runtime x64Win10 64bitEng LV2021SP1f4运行版下载-64位21.1.4
     楼主| 发表于 2024-2-6 10:55:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2021 SP1f4 Runtime(LV2021SP1f4只更新了运行版,未更新专业版)
    发布日期:
    23-5-16
    包含的版本:
    2021 SP1f4(21.1.4)运行版
    语言:
    英文
    程序位数:
    64位
    文件大小: 409907200 字节 (390.92 MB)
    修改日期: 2023-05-16 09:51
    MD5: 6757c091875d3c37924b7ac11bb5f1d9
    SHA1: d509e59523f4f05e68eb6239780523a5ce5ffd3c
    SHA256: 514a359de35e70100ca22e47e2bc60c489566c8219bb59f38f79e1030f01c863
    CRC32: 05c2e63f
    注册登录视觉论坛会员,购买附件查看
    LV2021SP1f4x64RTE.txt (614 Bytes, 下载次数: 1, 售价: 1 圆)
    LabVIEW 2021 SP1 Readme for Windows
    January 2022
    LabVIEW 2021 SP1 (64-bit)
    LabVIEW 2021 SP1 has the following requirements:
    Operating SystemWindows 10
    Windows Server 2019
    Windows Server 2016
    Windows 10
    Windows Server 2019
    Windows Server 2016
    Note  You cannot access LabVIEW using a Guest account on Windows.
    • Use the serial number that is included with your software to activate LabVIEW. For more information on LabVIEW activation, refer to Activating a Product.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021 SP1.
    LabVIEW 2021 SP1 adds two Place VI Contents VIs to the Functions palette. OpenSSH Exec and PuTTY SSH Exec execute a system command on an SSH server specified by user@host with OpenSSH or PuTTY (plink) respectively.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2021 SP1 (32-bit) and LabVIEW 2021 SP1 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2021 SP1 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW (64-bit).
    LabVIEW 2021 SP1 (64-bit) supports a limited number of modules and toolkits. The following table compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    ✓1
    Database Connectivity Toolkit
    Digital Filter Design Toolkit
    FPGA Module
    MathScript Module
    ✓2
    Real-Time Module
    Sound and Vibration Toolkit
    Unit Test Framework Toolkit
    VI Analyzer Toolkit
    Vision Development Module
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2021 SP1.
    LabVIEW no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    374715T-01
    GMT+8, 2025-12-8 08:02
