查看: 1102|回复: 0
[NI软件产品] NI Linux Real-Time Offline Installation Support 2024 Q1 Win11 32/64位多国语言 NI Linux Real-Time离线安装支持24.0.0
    前天 16:03
     楼主| 发表于 2024-3-5 16:07:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Linux Real-Time离线安装支持用于支持离线访问NI Linux Real-Time终端驱动程序。
    NI Linux Real-Time离线安装支持是一个软件工具,当上位机或目标无法访问ni.com或其他已发布的feed时,该软件可帮助您在NI Linux Real-Time终端上安装NI驱动程序。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    发布日期:2024/1/22
    包含的版本:2024 Q1完整版,版本号24.0.0
    语言:英文/多国语言
    文件大小: 9354614784 字节 (8.71 GB)
    修改日期: 2024-01-23 09:43
    MD5: 0f638edc2102f474ed7bf8d4f87787b4
    SHA1: d6bdfc0152bf1a4b951369dc78e091f13b1c77cc
    SHA256: 4895c78a1020b2a44272bb4bd13d3ea444bdd206a9ae62ac8083d30fd228e6fa
    CRC32: 6e95026c
    请注册登录机器视觉论坛账号,购买附件查看下载地址,充值请联系在线客服
    NI Linux Real-Time离线安装支持2024Q1.txt (650 Bytes, 下载次数: 1, 售价: 10 圆)
    2024Q1未更新自述文件,参考2023Q3版
    NI Linux Real-Time Offline Installation Support 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI Linux Real-Time Offline Installation Support 2023 Q3.
    • NI Linux Real-Time Offline Installation Support Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI Linux Real-Time Offline Installation Support Documentation: New features, behavior changes, and other documentation
    Software Support
    NI Linux Real-Time Offline Installation Support contains a package repository of all the packages located on the ni.com feed specific to the user-specified release version. The software package repository installer and offline installation support allows you to install software packages onto your Linux Real-Time targets when the target and host PC are in a secure environment that cannot access ni.com.
    The offline support bundle contains all packages available on ni.com and uses Linux’s package-based system to install software to the target. The support files allow the host PC to act as a server from which the target retrieves its packages.
    Installing NI Linux Real-Time Offline Installation Support should meet the requirements for LabVIEW and the LabVIEW Real-Time Module. Refer to the LabVIEW and LabVIEW Real-Time Module release notes for more information.
    NI Linux Real-Time Offline Installation Support 2023 Q3 supports the following operating systems:
    Note  The NI Linux Real-Time System Image listed in the Software Support section must be installed on the real-time target.
    Software Support
    NI Linux Real-Time Offline Installation Support 2023 Q3 supports the following application software versions.
    Software
    Versions Supported by NI Linux Real-Time Offline Installation Support 2023 Q3
    NI MAX20.5 and later
    NI Linux RT System Image2023 Q2
    Installation InstructionsInstallation on Machines with ni.com Access
    Download the NI Linux Real-Time Offline Installation Support 2023 Q3 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    For more detailed installation instructions and additional information, refer to Installing Software to Offline NI Linux Real-Time Targets.
    Installation on Machines without ni.com Access
    • Using a machine with access to ni.com, visit ni.com/downloads.
    • On the NI Linux Real-Time Offline Installation Support download page, click Install Offline in the right sidebar.
    • In the Offline Installer window, select a file and click Download to download NI Linux Real-Time Offline Installation Support as an ISO file.
    • Download the ISO file and transfer it to the PC without ni.com access.
    • Install NI Linux Real-Time Offline Installation Support from the ISO file.
    NI Linux Real-Time Offline Installation Support no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    GMT+8, 2026-2-25 06:56
