查看: 1090|回复: 0
[NI软件产品] NI VeriStand Custom Devices 2024 Q1 Win11 32/64bitEng NI VeriStand自定义设备24.0.0
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2024-3-13 18:10:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VeriStand Custom Devices自定义设备
    VeriStand Custom Devices为VeriStand添加了硬件支持。
    VeriStand Custom Devices是VeriStand的附加软件工具。该附加软件为HIL测试应用的其他硬件和总线类型提供支持。您可以使用VeriStand System Explorer来配置自定义设备,以满足实时测试应用的需求。VeriStand Custom Devices包括以下自定义设备:数据共享框架;嵌入式数据记录仪;发动机仿真工具包;FPGA附加软件;仪器附加软件;路由和故障分析(NI-SWITCH和SLSC开关);扫描引擎和EtherCAT;SLSC 12201;SLSC EDS;同步;以及Telemetry和System Monitor。
    发布日期:2024/1/22
    包含的版本:2024 Q1完整版,版本号24.0.0
    文件大小: 610267136 字节 (582.00 MB)
    修改日期: 2024-01-23 10:13
    MD5: bbdcfb1d08a311b13db2a2738d676c56
    SHA1: 4bf04fd5265ee33e3f89220a25bbcef190ffef39
    SHA256: 23e5390ae25f225244c2ee7c2e0589ccc9864e152126426e2f4a8228490e4840
    CRC32: c46d7c1e
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    VeriStand自定义设备2024Q1.txt (608 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q1版未更新自述文件,参考2023Q3版
    VeriStand 2023 Q3 Readme
    This file contains installation instructions and compatibility information for VeriStand 2023 Q3.
    • VeriStand Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • VeriStand Documentation: Detailed documentation about how to use your product
    VeriStand 2023 Q3 installs with the following:
    • NI-DAQmx 2023 Q3
    • NI-VISA 2023 Q3
    • NI-SLSC 2022 Q4
    • NI-XNET 2023 Q2
    • NI R Series Multifunction RIO 2023 Q3
    Refer to the following sections for system requirements that apply if you use models, LabVIEW functionality, and .NET APIs.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only VeriStand installed. You need the following additional software to perform other tasks with models:
    • To develop a model using MathWorks Simulink® software, you must be a licensed user and have MathWorks MATLAB® software (64-bit version) and MathWorks Simulink software installed on the host computer.
    • To compile a model developed using MathWorks Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: MathWorks Real-Time Workshop® (Simulink Coder®). Refer to the NI website for a list of compilers that are tested and supported.
    Note  You do not need the full VeriStand environment to generate a compatible model. Instead, you can install VeriStand Model Generation Support Toolbox for Simulink or the VeriStand Model Framework.
    If you use other modeling environments, contact your model vendor for specific requirements.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    • Microsoft .NET Framework 4.6.2, which uses Microsoft .NET Common Language Runtime (CLR) 4.6.2.
    • A .NET environment capable of interacting with .NET Framework 4.6.2-based assemblies, such as Microsoft Visual Studio 2015 or later.
    VeriStand 2023 Q3 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 11 64-bit version 22H2
    • Windows 10 64-bit version 22H21
    • NI Linux Real-Time (Intel x64-based)2
    1 NI software installs VC2015 Runtime and .NET 4.6.2.
    2 VeriStand no longer supports Phar Lap ETS or NI Linux Real-Time (ARM-based) targets.
    Recommended PXI Linux RT System Image
    When formatting a disk with a PXI Linux RT system image for VeriStand 2023 Q3, select Linux RT System Image 2023 Q3 and enable support for the LabVIEW 2023 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Install VeriStand with either the online installer or with installation media.
    • Disable automatic virus detection programs.
      Note   Some virus detection programs interfere with the installer.
    • Activate VeriStand when prompted by the installer or activate later with NI License Manager.
    • To use LabVIEW with VeriStand, install the like-numbered version of LabVIEW on the host computer.
    • Check your computer for viruses and enable your virus detection.
    Online Installer
    Download the VeriStand installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installation Media
    If you purchased this product with media, insert the VeriStand installation media and follow the instructions that appear on the screen.
    The following sections describe issues to be aware of when you upgrade to VeriStand 2023 Q3.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2023 Q3. To access the documents, refer to the VeriStand Release Notes.
    Primary Control Loop (PCL) Timing Source
    As of VeriStand 2023 Q2, the System Explorer default for the PCL DAQ timing source is Signal From Task (Sample Complete). This default applies to new projects under the following conditions:
    • Setting the timing source to DAQ Timing.
    • Setting the timing source to Automatic Timing when a NI-DAQ device has at least one analog input hardware-timed single point channel.
    Note  This behavior will not change for existing, upgraded projects.
    Uncompiled Models
    VeriStand does not support communication with uncompiled models.
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Note  Models built with LabVIEW 2023 Q1 and later no longer support simulation subsystems developed using the LabVIEW Control Design and Simulation Module add-on.
    Take the following actions to ensure your models are 64-bit compatible:
    • Recompile all Windows models for 64-bit.
    • Recompile all PharLap models for Linux RT.
    Beginning with VeriStand 2021, the VeriStand Model Framework contains changes to the files used to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled for Linux RT 64-bit with previous versions of the Model Framework, choose from the following options to continue to use the models:
    • If you do not need to modify your model, continue to use the model as-is.
    • If you need to modify model functionality, and do not require the latest Model Framework version updates, recompile the model against the deprecated Model Framework files. These files are installed at \VeriStand\version\ModelInterface\custom\src\obsolete.
    Migrating Files from VeriStand 2010 through 2018 SP1
    VeriStand 2023 Q3 can open projects from VeriStand 2010 through 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    LabVIEW can no longer automate actions with legacy stimulus profiles. Consider migrating to modern stimulus profiles and real-time sequences.
    In addition, the following LabVIEW automation VIs are deprecated and no longer included with VeriStand:
    • NI VeriStand - Get Alarm Status.vi
    • NI VeriStand - Get Engine State.vi
    • NI VeriStand - Lock Workspace File.vi
    • NI VeriStand - Run Workspace File.vi
    • NI VeriStand - Stop Workspace File.vi
    • NI VeriStand - Unlock Workspace File.vi
    VeriStand Custom Devices Included with VeriStand Suite
    Beginning with VeriStand 2021, the VeriStand suite installer will include custom devices for both offline and online installation. To install custom devices separately, refer to the release page for each Custom Device on the VeriStand Add-ons support page.
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q3 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q3 .NET API Help.
    Note  If you install VeriStand with a compatible version of LabVIEW, you can access a subset of VeriStand related materials in the LabVIEW Help. This includes information about VeriStand VIs and extending VeriStand functionality. To access this help from LabVIEW, select Help»LabVIEW Help.
    VeriStand includes the following types of examples:
    • VeriStand Project — An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\VeriStand 2023\Projects\Example directory.
    • Stimulus Profile Editor — VeriStand Stimulus Profile Editor examples are located in the \National Instruments\VeriStand 2023\Examples directory.
    • ASAM XIL and Custom Device Sample Configurations — Configuration examples for ASAM XIL and custom devices are located in the \National Instruments\VeriStand 2023\Examples directory.
      Note   On the Windows OS, the default location of the directory is C:\Users\Public\Public Documents.
    • LabVIEW API — LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2023\examples\NI VeriStand directory or in the \National Instruments\LabVIEW 2023\examples\NI VeriStand Custom Devices directory.
    VeriStand no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-6 06:10
