查看: 1191|回复: 0
[NI软件产品] NI Linux Real-Time Offline Installation Support 20.5.1 Win64多国语言 NI Linux Real-Time离线安装支持20.5.1
    前天 16:03
     楼主| 发表于 2024-3-19 14:53:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Linux Real-Time离线安装支持用于支持离线访问NI Linux Real-Time终端驱动程序。
    NI Linux Real-Time离线安装支持是一个软件工具,当上位机或目标无法访问ni.com或其他已发布的feed时,该软件可帮助您在NI Linux Real-Time终端上安装NI驱动程序。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    发布日期:2022/3/25
    包含的版本:20.5.1完整版,版本号20.5.1
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:英文
    文件大小: 4102352896 字节 (3.82 GB)
    修改日期: 2022-03-25 16:18
    MD5: 038dadc1df59bdc729655025c3cafa31
    SHA1: ebc1dc9dda88d0feb5ba9a8a7bcc3fa5743a9b98
    SHA256: 3da3dfa8618a013e6a04ae97a44fa2612cf2ecafc9692521d1532ea0f6237a85
    CRC32: 13564d39
    请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服
    NI Linux Real-Time离线安装支持20.5.1.txt (649 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Linux Real-Time Offline Installation Support 20.5 Readme
    September 2020
    This file contains important information about the NI Linux Real-Time Offline Installation Support, including installation instructions and supported hardware.
    Software Support
    NI Linux Real-Time Offline Installation Support Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI Linux Real-Time Offline Installation Support installs the necessary software to manage an offline NI Linux Real-Time target.
    NI Linux Real-Time Offline Installation Support 20.5 has the following requirements:
    • At least 4.0 GB of disk space
    Note  NI Linux Real-Time must be installed on the real-time target.
    NI Linux Real-Time Offline Installation Support 20.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  Refer to NI Linux Real-Time Offline Installation Support Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Software Support
    NI Linux Real-Time Offline Installation Support 20.5 supports the following software versions.
    Software
    Versions Supported by NI Linux Real-Time Offline Installation Support 20.5
    MAX20.0
    NI Linux Real-Time System Image20.5
    Installation InstructionsInstallation on Machines with ni.com Access
    If the PC you need to install the NI Linux Real-Time Offline Installation Support on can access ni.com, refer to the following installation instructions.
    NI installs NI Linux Real-Time Offline Installation Support using NI Package Manager. If you do not already have NI software installed, NI Linux Real-Time Offline Installation Support installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note: To begin your software download using NI Package Manager, click the Download button, located in the right sidebar of the download page. If you prefer to install from a downloaded ISO file, refer to the Installation on Machines without ni.com Access section.
    For more detailed installation instructions and additional information, refer to Installing Software on NI Linux Real-Time Targets.
    If the PC you need to install the NI Linux Real-Time Offline Installation Support on cannot access ni.com, refer to the following installation instructions:
    • Locate a PC with access to ni.com and go to ni.com/downloads.
    • Click the Individual Offline Installers link on the download page to download NI Linux Real-Time Offline Installation Support as an ISO file.
      Note: The Individual Offline Installers link is located in the informational note in the right sidebar of the download page below the Download button, which downloads software using NI Package Manager.
    • Transfer the ISO file to the PC without ni.com access.
    • Install NI Linux Real-Time Offline Installation Support from the ISO file.
    For more detailed installation instructions and additional information, refer to Installing Software to Offline NI Linux Real-Time Targets.
    The following list details the hardware models supported in NI Linux Real-Time Offline Installation Support 20.5:
    CompactDAQ Controller
    • cDAQ-9132
    • cDAQ-9133
    • cDAQ-9134
    • cDAQ-9135
    • cDAQ-9136
    • cDAQ-9137
    CompactRIO Controller
    • cRIO-9030
    • cRIO-9031
    • cRIO-9032
    • cRIO-9033
    • cRIO-9034
    • cRIO-9035
    • cRIO-9035 Sync
    • cRIO-9036
    • cRIO-9037
    • cRIO-9038
    • cRIO-9039
    • cRIO-9039 Sync
    • cRIO-9040
    • cRIO-9041
    • cRIO-9042
    • cRIO-9043
    • cRIO-9045
    • cRIO-9046
    • cRIO-9047
    • cRIO-9048
    • cRIO-9048 (TPM)
    • cRIO-9049
    • cRIO-9053
    • cRIO-9054
    • cRIO-9055
    • cRIO-9056
    • cRIO-9057
    • cRIO-9058
    • cRIO-9063
    • cRIO-9064
    • cRIO-9065
    • cRIO-9066
    • cRIO-9067
    • cRIO-9068
    CompactRIO Single-Board Controller
    • sbRIO-9607
    • sbRIO-9627
    • sbRIO-9637
    • sbRIO-9651
    • sbRIO-9603
    • sbRIO-9608
    • sbRIO-9609
    • sbRIO-9628
    • sbRIO-9629
    • sbRIO-9638
    Academic
    • NI ELVIS RIO CM
    • NI ELVIS III
    CompactRIO Chassis
    • NI 9147
    • NI 9149
    Controller for FlexRIO
    • NI 7931
    • NI 7932
    • NI 7935
    PXI Hardware
    Refer to NI Linux Real-Time Operating System PXI Hardware Support.
    USRP Software Defined Radio Stand-Alone Device
    • USRP-2974
    The following sections detail considerations for using LabVIEW NXG 5.0 with NI Linux RT System Image 20.5.
    LabVIEW NXG Hardware Support
    NI Linux RT System Image 20.5 supports the following devices in LabVIEW NXG 5.0
    • cRIO-9040
    • cRIO-9041
    • cRIO-9042
    • cRIO-9043
    • cRIO-9045
    • cRIO-9046
    • cRIO-9047
    • cRIO-9048
    • cRIO-9048 (TPM)
    • cRIO-9049
    • cRIO-9053
    • cRIO-9054
    • cRIO-9055
    • cRIO-9056
    • cRIO-9057
    • cRIO-9058
    • USRP-2974
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    NI Linux Real-Time Offline Support will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2020–2020 National Instruments Corporation. All rights reserved.
    378289C-01
    GMT+8, 2026-2-25 03:03
