查看: 694|回复: 0
[NI软件产品] ASAM XIL TestStand Steps 1.2.0 Win32/64bitEng ASAM XIL TestStand步骤1.2.0下载
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2024-3-22 16:21:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    ASAM XIL TestStand Steps包括多个自定义步骤,支持使用TestStand重用HIL系统的序列。
    ASAM XIL TestStand Steps是一款附加软件,提供了一组自定义步骤。这些步骤可帮助您在TestStand中使用ASAM XIL API访问VeriStand软件并自动执行任务。借助这些自定义步骤,您可以复用硬件在环(HIL)系统的测试序列,并结合ASAM XIL API标准,在测试自动化工具和测试平台之间进行通信。ASAM XIL TestStand Steps支持实时序列、项目控制、通道读写访问、日志记录等功能。
    发布日期:2020/5/15
    包含的版本:1.2完整版,版本号1.2.0
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    语言:英文English
    文件大小: 167847936 字节 (160.07 MB)
    修改日期: 2022-03-25 10:44
    MD5: cb33dc22707fb2d0f3c8e75f0041c120
    SHA1: 07bbe646ce7c1e93e1374bdc64c16a5ab8f749f4
    SHA256: 8370a7f7ee36afff0137935f73b707f89afd32a1addc8d11a3b5a2d35a852644
    CRC32: 6a7a8554
    注册登录视觉论坛账号,购买附件查看下载地址
    ASAM XIL TestStand Steps1.2.txt (585 Bytes, 下载次数: 0, 售价: 10 元)
    ASAM XIL Steps for NI TestStand 1.2 Readme
    May 2020
    This file contains important information about the ASAM XIL Steps for NI TestStand, including installation instructions, new features, a partial list of bugs fixed for ASAM XIL Steps for NI TestStand 1.2, and known issues.
    ASAM XIL Steps for NI TestStand Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The ASAM XIL Steps for NI TestStand are sets of custom steps that allow you to reuse test sequences developed for other hardware-in-the-loop (HIL) systems that use the ASAM XIL API.
    Refer to the TestStand Readme for system requirements and supported operating systems for ASAM XIL Steps For NI TestStand 1.2
    ASAM XIL Steps for NI TestStand 1.2 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  Refer to ASAM XIL Steps for NI TestStand Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    ASAM XIL Steps For NI TestStand 1.2 supports the following application software versions, including service packs.
    Versions Supported by ASAM XIL Steps For NI TestStand 1.2
    TestStand2017, 2019
    VeriStand2018, 2019, 2020
    If you are using the ASAM XIL Steps For NI TestStand 1.2 .NET Class Library, .NET Framework 4.0 (minimum) is required. The .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    NI installs ASAM XIL Steps for NI TestStand using NI Package Manager. If you do not already have NI software installed, ASAM XIL Steps for NI TestStand installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    • Added support for VeriStand 2020 R1
    You can access the software and documentation known issues list online. Visit ASAM XIL Steps for NI TestStand 1.2 Known Issues for an up-to-date list of known issues.
    TestStand examples for the ASAM XIL Steps for NI TestStand are located in the \Examples\ASAM XIL directory. You can modify an example sequences to fit an application, or you can copy and paste from one or more examples into a sequence that you create.
    ASAM XIL Steps for NI TestStand will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021 may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022 may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    © 2020 National Instruments. All rights reserved.
    378185A-01
    GMT+8, 2025-7-23 12:08
