ASAM XIL TestStand Steps 1.4.0 Win32/64bitEng ASAM XIL TestStand步骤1.4.0下载
ASAM XIL TestStand Steps包括多个自定义步骤,支持使用TestStand重用HIL系统的序列。
ASAM XIL TestStand Steps是一款附加软件,提供了一组自定义步骤。这些步骤可帮助您在TestStand中使用ASAM XIL API访问VeriStand软件并自动执行任务。借助这些自定义步骤,您可以复用硬件在环(HIL)系统的测试序列,并结合ASAM XIL API标准,在测试自动化工具和测试平台之间进行通信。ASAM XIL TestStand Steps支持实时序列、项目控制、通道读写访问、日志记录等功能。
发布日期:2020/12/14
包含的版本:1.4完整版,版本号1.4.0
Windows 7 (SP1) 32-bit
Windows 7 (SP1) 64-bit
Windows 8.1 32-bit
Windows 8.1 64-bit
Windows 10 32-bit
Windows Server 2012 R2 64-bit
语言:英文English
文件大小: 174991360 字节 (166.88 MB)
修改日期: 2022-03-25 10:46
MD5: f7a53fcc67a7dfc4b67aeb00f6790425
SHA1: b0bddd286f1b77d9f5d2c9386429c6b477c933b9
SHA256: 4b7a0791c01d4f1dfb6789d1306cedfb7aa74eb65ede578a913c370140bff1ce
CRC32: 7561f60f
注册登录视觉论坛账号,购买附件查看下载地址
ASAM XIL TestStand Steps1.4.txt
(585 Bytes, 下载次数: 0, 售价: 10 圆)
ASAM XIL Steps for NI TestStand 1.4 ReadmeDecember 2020 This file contains important information about the ASAM XIL Steps for NI TestStand, including installation instructions, new features, a partial list of bugs fixed for ASAM XIL Steps for NI TestStand 1.4, and known issues.
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features Known Issues Bug Fixes Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 ASAM XIL Steps for NI TestStand Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022 Legal Information OverviewThe ASAM XIL Steps for NI TestStand are sets of custom steps that allow you to reuse test sequences developed for other hardware-in-the-loop (HIL) systems that use the ASAM XIL API. System RequirementsRefer to the TestStand Readme for system requirements and supported operating systems for ASAM XIL Steps For NI TestStand 1.4. Supported Operating SystemsASAM XIL Steps for NI TestStand 1.4 supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Embedded Standard 7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install these updates. Note Refer to ASAM XIL Steps for NI TestStand Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport. Application Software SupportASAM XIL Steps For NI TestStand 1.4 supports the following application software versions, including service packs. Application Software | Versions Supported by ASAM XIL Steps For NI TestStand 1.4 | | TestStand | 2017, 2019, 2020 | | VeriStand | 2018, 2019, 2020 | Microsoft Visual Studio SupportIf you are using the ASAM XIL Steps For NI TestStand 1.4 .NET Class Library, .NET Framework 4.0 (minimum) is required. The ASAM XIL Steps for TestStand .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support. Installation InstructionsNI installs ASAM XIL Steps for NI TestStand using NI Package Manager. If you do not already have NI software installed, ASAM XIL Steps for NI TestStand installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Note If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New FeaturesASAM Steps for NI TestStand 1.4 introduces the ability to perform the following actions: - Support for TestStand 2020.
Known IssuesYou can access the software known issues list online. Visit ASAM XIL Steps for NI TestStand 1.4 Known Issues for an up-to-date list of known issues. Bug FixesYou can access the software bug fixes list online. Visit ASAM XIL TestStand Steps 1.4 Bug Fixes for a list of fixed bugs for the release. Finding ExamplesTestStand examples for the ASAM XIL Steps for NI TestStand are located in the \Examples\ASAM XIL directory. You can modify example sequences to fit an application, or you can copy and paste from one or more examples into a sequence that you create. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. ASAM XIL Steps for NI TestStand Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021ASAM XIL Steps for NI TestStand will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021 may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022 may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi. Legal InformationCopyright © 2020 NI. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Members of the NI Alliance Partner Program are business entities independent from NI and have no agency, partnership, or joint-venture relationship with NI. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 378185C-01 |
