查看: 1098|回复: 1
[NI软件产品] ASAM XIL TestStand Steps 2024 Q1 Win11 32/64bitEng ASAM XIL TestStand步骤24.0.0下载
     楼主| 发表于 2024-3-22 16:34:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    ASAM XIL TestStand Steps包括多个自定义步骤,支持使用TestStand重用HIL系统的序列。
    ASAM XIL TestStand Steps是一款附加软件,提供了一组自定义步骤。这些步骤可帮助您在TestStand中使用ASAM XIL API访问VeriStand软件并自动执行任务。借助这些自定义步骤,您可以复用硬件在环(HIL)系统的测试序列,并结合ASAM XIL API标准,在测试自动化工具和测试平台之间进行通信。ASAM XIL TestStand Steps支持实时序列、项目控制、通道读写访问、日志记录等功能。
    发布日期:2024/1/22
    包含的版本:2024 Q1完整版,版本号24.0.0
    语言:英文English
    文件大小: 174221312 字节 (166.15 MB)
    修改日期: 2024-01-23 09:43
    MD5: 45f86daa50b17c0c397f43f1d8722f05
    SHA1: c79beedab90b0299ce02f9dab174f43451ac3dfc
    SHA256: da324d31b0e2be00c01428b4426410478107da636e4cea8a7df607f289f34052
    CRC32: d0c8e76a
    注册登录视觉论坛账号,购买附件查看下载地址
    ASAM XIL TestStand Steps2024Q1.txt (592 Bytes, 下载次数: 0, 售价: 10 圆)
    2023Q1未更新自述文件,参考2023Q1版本
    ASAM XIL TestStand Steps 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for ASAM XIL TestStand Steps 2023 Q1.
    • ASAM XIL TestStand Steps Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The ASAM XIL TestStand Steps includes custom steps to reuse sequences for HIL systems with TestStand.
    For more information on system requirements for ASAM XIL TestStand Steps, refer to the TestStand readme.
    For more information on supported operating systems for ASAM XIL TestStand Steps, refer to the TestStand readme.
    ASAM XIL TestStand Steps 2023 Q1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by ASAM XIL TestStand Steps 2023 Q1
    TestStand2017, 2019, 2020, 2021, 2022
    VeriStand2018, 2019, 2020, 2021, 2023
    If you are using the ASAM XIL TestStand Steps .NET Class Library, .NET Framework 4.0 (minimum) is required. The ASAM XIL TestStand Steps 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the ASAM XIL TestStand Steps installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Added support for VeriStand 2023
    • Added support for TestStand 2022
    TestStand examples for the ASAM XIL TestStand Steps are located in the \Examples\ASAM XIL directory. You can modify example sequences to fit an application, or you can copy and paste from one or more examples into a sequence that you create.
    ASAM XIL TestStand Steps no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2020–2023 National Instruments Corporation. All rights reserved.
  • 签到天数: 7 天
    发表于 2024-10-18 15:00:19 | 显示全部楼层 来自:广东省东莞市 移动
    GMT+8, 2025-12-8 07:37
