查看: 1003|回复: 0
[NI驱动程序] NI-VNA 14.0.3 Win32/64bitEng 矢量网络分析仪14.0.3下载
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2024-4-9 15:11:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-VNA
    NI-VNA为使用NI PXI矢量网络分析仪的客户提供支持。
    NI-VNA是控制所有NI PXI矢量网络分析仪所需的NI仪器驱动程序。您可以配置测量扫频、触发器和时域。您也可以自定义自动化测量并执行用户校准。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及底层实用程序。NI-VNA包含了交互式软面板和示例。
    NI-VNA 14.0.3
    发布日期:2014/10/7
    包含的版本:14.0f3完整版,版本号14.0.3
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Vista
    Windows XP 32-bit
    Windows 8
    Windows 7
    语言:英文English
    文件大小: 708461344 字节 (675.64 MB)
    修改日期: 2023-01-21 09:52
    MD5: 18e049d351088334f9cd1b9eaf1b9d9e
    SHA1: 3d348accecf652b31ed06a185e77063a11737052
    SHA256: 12d01b7f51161385d6cb6bf384f547551c9cd24dc1780bf5e4784ac448c0d5c2
    CRC32: 0d772dbf
    注册登录视觉论坛账号,购买附件查看下载地址
    VNA14.0.3.txt (480 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VNA 14.0 Readme
    Thank you for using NI-VNA. This file contains important information about NI-VNA and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI-VNA
    NI-VNA 14.0 includes the following new features:
    • Adds support for LabVIEW 2014 (32-bit and 64-bit)
    • Adds support for output triggers
    • Adds support for loading sweep settings from a configuration file
    NI-VNA 2.0.1 adds support for several bug fixes.
    NI-VNA 2.0 includes the following new features:
    • Support for the NI PXIe-5632
    • Adds support for LabVIEW 2012, and removes support for LabVIEW 8.6
    NI-VNA 1.2 includes the following new features:
    • Adds support for LabVIEW 2011, and removes support for LabVIEW 8.5
    • Performance improvement: CPU utilization
    The NI-VNA instrument driver supports the following devices on all Supported Operating Systems.
    • NI PXIe-5630
    • NI PXIe-5632
    Device-specific information about these modules is included in the NI Vector Network Analyzers Help.
    NI-VNA 14.0 and later supports the following operating systems:
    • Windows XP (32-bit)
    Note:  NI-VNA 14.0 and later does not support Windows Server non-R2 editions.
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows 8.1/8/7/Vista: 512 MB
    • Windows 8.1/8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP SP3: 256 MB
      • Windows 8.1/8/7/Vista: 1 GB
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-VNA. To add support for ADEs installed after installing NI-VNA, modify your NI-VNA installation or launch the NI-VNA installer again.
    • NI LabVIEW 2011 SP1 (32-bit and 64-bit), 2012 SP1 (32-bit and 64-bit), 2013 (32-bit and 64-bit), 2014 (32-bit and 64-bit)
    • LabWindows/CVI 9.0.1 or later
      • Windows 8.1/8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        $(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
    Item
    Installed Location on Windows 8.1/8/7/Vista/XP
    NI-VNA\Drivers\niVNA
    NI-VNA Function Panel\Drivers\niVNA\niVNA.fp
    NI-VNA Examples\niVNA\Examples
    NI-VNA Header files\Include
    NI-VNA Import Library files (32-bit)\Lib
    NI-VNA Import Library files (64-bit)\Lib_x64
    NI-VNA DLL (32-bit)\Bin
    Additional File Locations for Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    Item
    Installed Location on Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-VNA DLL (64-bit)\Bin
    Documentation for NI-VNA is located at Start»All Programs»National Instruments»NI-VNA»Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI Vector Network Analyzers HelpHTML/Windows HelpContains information about hardware and software for NI RF vector network analyzers. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to fundamental RF vector network analyzer concepts
    • Hardware device information
    • A complete reference for all NI-VNA programming functions and VIs
    NI-VNA ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI–VNA palette VIs are available from the Functions»Measurement I/O»NI–VNA palette.
    NI–VNA functions are available in LabWindows/CVI from the Instrument menu. To load the NI–VNA function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niVNA\niVNA.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–VNA examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–VNA or by directory structure at instr»niVNA.
    • Click the Search tab to search all installed examples by keyword. For example, search for "VNA" to locate all NI RF vector network analyzer examples.
    You can also access all the installed NI–VNA examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–VNA»Examples.
    NI-VNA versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, NI-VNA 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-VNA 2.0.1. The first version released under the new numbering scheme is NI-VNA 14.0.
    • Click Change/Remove.
    • Select NI-VNA 14.0 from the dialog box that appears.
    • Select Driver Runtime.
    • Click Remove to uninstall the product(s); click Modify to change the components that are installed.
    For Windows 8.1/8, complete the following steps:
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    As part of the NI-VNA 14.0 installation, the following software is installed. To completely remove the NI-VNA 14.0 installation from your system, you must also remove all of the following packages:
    • NI Measurement & Automation Explorer (MAX) 14.0
    • NI-VISA Run-Time Engine 5.0
    You can access the software and documentation known issues list online. Refer to the NI-VNA Known Issues at ni.com for an up-to-date list of known issues in NI-VNA 14.0.
    The following items are changes in NI-VNA 14.0 from NI-VNA 2.0.1.
    ID
    Fixed Issue
    372001Fixed an issue in which the NI-568x RF power meter instrument driver returns an error during ni568x Fetch after calling niVNA Initialize.
    385555Fixed an issue in which NI-VNA returns an error during niVNA Load Calibration and Configuration Data From File when loading a file sourced from the NI-VNA Soft Front Panel.
    384845Fixed an issue in which the NI-VNA Soft Front Panel ignores floating point multiplier or divisor settings when configuring multiple source setup.
    The following items are changes in NI-VNA 2.0.1 from NI-VNA 2.0.
    ID
    Fixed Issue
    378613Fixed an issue in which the NI PXIe-5632 periodically paused when sweeping with a low number of points and high IF bandwidth.
    375439Fixed an issue in which NI-VNA source power calibration incorrectly calibrated power when performing a segmented sweep.
    374013Fixed an issue in which NI-VNA incorrectly reported source-unleveled errors when performing a power sweep.
    374015Fixed an issue in which the NI-VNA Soft Front Panel freezed while performing a source power calibration during a power sweep.
    Licenses and Notices
    NI-VNA contains third-party software for which the following licenses and notices apply:
    • NI-VNA FOSS notices
    • Microsoft DotNet 2.0 License
    • Microsoft DirectX 9.0 License
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    NI-VNA Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016 2003
    NI-VNA will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-VNA that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2010–2014 National Instruments. All rights reserved.
    374800A-01
    GMT+8, 2026-2-3 07:43
