查看: 1185|回复: 0
[NI软件产品] NI Vehicle Communication Measurement and Calibration Toolkit 2024 Q1 Win11 64bitEng 车辆通信测量和校准工具包VCMT24.0.0
    3 小时前
  • 签到天数: 3815 天
    连续签到: 8 天
     楼主| 发表于 2024-4-12 15:11:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Vehicle Communication Measurement and Calibration工具包
    Vehicle Communication Measurement and Calibration工具包为ECU设计和验证提供NI-XNET设备支持。
    Vehicle Communication Measurement and Calibration工具包是Vehicle Communication工具包(NI-VCOM)的软件附加工具。该附加工具可与支持NI-XNET的设备配合使用,帮助您测量和校准用于电子控制单元(ECU)设计和验证的应用程序。通过通用测量与校准协议(XCP)和CAN校准协议(CCP),您可以将此附加软件与校准数据库文件(A2L)配合使用,以读取和写入内部ECU变量和特性。此外, Vehicle Communication Measurement and Calibration工具包还提供了LabVIEW专用Windows API、C/C++专用Windows API以及Web校准数据库查看器。
    发布日期:2024/1/22
    包含的版本:2024 Q1基本版,完整版,版本号24.0.0
    语言:英文English
    文件大小: 1222498304 字节 (1.14 GB)
    修改日期: 2024-01-23 10:11
    MD5: 009d82b959be0ab83fe86c7ca1c0e66f
    SHA1: f47e01d6d652afafd45c7eae934818d2f836c104
    SHA256: 2cf6320a785440195ab102f1443b311c238e0728f53c5895adc87fc1feaf7b17
    CRC32: fc3f03f1
    注册登录视觉论坛账号,购买附件查看下载地址
    VCMCT2024Q1.txt (598 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q1未更新自述文件,参考2023Q1版
    Vehicle Communication Software Suite 2024 Q1 Changes
    Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2024 Q1.
    Vehicle Communication Toolkit New Features
    • Base and Full Versions:
      • Upgrades supported version of LabVIEW to 2024 Q1
      • Upgrades supported version of VeriStand to 2024 Q1
      • Adds support for a Bus monitor
      • Adds support of byte array data type signals in the NI-VCOM custom device and LabVIEW API
    • NI-VCOM has a new database viewer for RBS, the Calibration Toolkit, and the Diagnostic Toolkit. The new database viewer allows a more hierarchical and dense view of database content and provides a smoother search experience.
    • The Read Signal - State RBS VI in the NI-VCOM LabVIEW API is now named Read (State VCOM).vi. Update the name of the VI if you use this API in your NI-VCOM application.
    Vehicle Communication Software Suite 2023 Q3 Changes
    Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2023 Q3.
      • Adds support for J1939 protocol
      • Adds support for CAN and LIN virtual devices
      • Adds support for multiple VCOM custom devices, each with unique configurations, in the same VeriStand project containing multiple controllers. Each controller can be associated with one VCOM custom device.
      • Adds support for LabVIEW API signal selection in the Read and Write VIs.
      • Adds support for deploying configuration files to remote targets from the WebUI rather than manually copying files between machines.
      • Adds performance improvements for importing large .arxml files and large numbers of signals.
    • Full Version Only:
      • Adds support for optional Diagnostic Toolkit
      • Adds support for AUTOSAR Global Time Synchronization
    • The VeriStand Custom Device is now called NI:VCOM rather than Provetech:RBS
    • The VeriStand Custom Device API is now located on the NI-VCOM:Restbus simulation palette
    • The Measurement and Calibration Toolkit is now configured automatically.
    • The VCOM custom device now creates channels that are not scalable by default, but you can set them to be scalable if necessary.
    Vehicle Communication Measurement and Calibration Toolkit 2023 Q1 Readme
    March 2023
    This file contains installation instructions and compatibility information for Vehicle Communication Measurement and Calibration Toolkit 2023 Q1 (Measurement and Calibration Toolkit).
    • Measurement and Calibration Toolkit Release Notes: Known issues and other notes about this release
    • Measurement and Calibration Toolkit Documentation
    Measurement and Calibration Toolkit 2023 Q1 has the following requirements:
    • At least 3 GB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for supported LabVIEW versions.
    Measurement and Calibration Toolkit 2023 Q1 supports the following operating system:
    • Windows 10 (64-bit)
    Measurement and Calibration Toolkit 2023 Q1 supports the following communication buses:
    • CAN/CAN-FD
    • FlexRay
    • Automotive Ethernet
    Measurement and Calibration Toolkit 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by Measurement and Calibration Toolkit 2023 Q1
    LabVIEW (32- and 64-bit)2020, 2021, 2022, 2023
    You must install the Vehicle Communication Toolkit before installing the Measurement and Calibration Toolkit. Refer to the Vehicle Communication Toolkit (Full) Readme or the Vehicle Communication Toolkit (Base) Readme for installation instructions.
    Download the Measurement and Calibration Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "Measurement and Calibration Toolkit Support for LabVIEW" package supports applications using the Measurement and Calibration Toolkit with LabVIEW 2020 or later. When installing the Measurement and Calibration Toolkit, this package will be recommended if you have already installed LabVIEW 2020 or later and it installs to the LabVIEW VI library.
    Refer to the Vehicle Communication Toolkit documentation, accessible from ni.com/docs, for information about the Measurement and Calibration Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Measurement and Calibration Toolkit are located in the LabVIEW\examples\Vehicle Communication Measurement and Calibration Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    A demo ECU application for the Measurement and Calibration Toolkit is located in the %Public%\Documents\National Instruments\NI-VCOM\Examples\Measurement and Calibration Toolkit\Demo ECU directory.
    GMT+8, 2026-3-4 11:19
